ΗΧΕΙΑ REFERENCE KLIPSCH RF-25
ΠΡΟΚΕΙΤΑΙ ΓΙΑ ΤΑ ΗΧΕΙΑ RF-25 ΤΗΣ KLIPSCH ΣΕ ΑΡΙΣΤΗ ΚΑΤΑΣΤΑΣΗ. ΜΠΟΡΟΥΝ ΝΑ ΧΡΗΣΙΜΟΠΟΙΗΘΟΎΝ ΣΕ HOME CINEMA Η ΣΕ STEREO ΣΥΣΤΗΜΑ. ΕΙΝΑΙ ΠΟΛΥ ΕΥΑΙΣΘΗΤΑ ΚΑΙ ΜΠΟΡΟΥΝ ΝΑ ΕΡΓΑΣΤΟΥΝ ΚΑΙ ΜΕ ΠΟΛΥ ΜΙΚΡΟ ΕΝΙΧΥΤΗ. ΔΕΧΟΝΤΑΙ ΜΕΓΙΣΤΗ ΙΣΧΥ ΚΟΡΥΦΗΣ 400WATT. ΣΥΝΙΣΤΩΝΤΑΙ ΓΙΑ ΛΕΙΤΟΥΡΓΙΑ ΜΕ ΠΟΛΥ ΜΙΚΡΟ ΛΑΜΠΑΤΟ ΕΝΙΣΧΥΤΗ ΛΟΓΩ ΜΕΓΑΛΗΣ ΕΥΑΙΣΘΗΣΙΑΣ. ΤΙΜΗ: 480 ΕΥΡΩ
e-mail: [email protected]
RF-25 Floorstanding Loudspeaker
Detailed Description
The Reference Series RF-25 floorstanding loudspeaker was first introduced in 2003 and manufactured by Klipsch until 2006. Featuring the same dynamic quality, superior sound and cosmetic appeal as the RF-35 model, the RF-25 came in a smaller package with a more affordable price tag.
RF-25 Specifications
frequency response45Hz-20kHz ±3dBpower handling125 w max continuous (500 w peak)sensitivity97dB @ 2.83 volts/1 meternominal impedance8 ohms compatiblecrossover frequency2633HztweeterK-137 1" (2.54cm) Titanium dome compression driverhigh frequency horn6" square 90°x60° Tractrix® HornwooferTwo K-1123-OB 6.5" (16.51cm) Cerametallic® cone / cast polymer frameenclosure materialMDFenclosure typeBass reflex via rear-firing portinput connections2 sets of binding post speaker terminals (connected via brass strap jumpers)dimensions38.9" (98.8cm) x 8.5" (21.6cm) x 13.8" (35cm)weight44 lbs. (20kg)finishesBlack Ash, Light Cherry wood-grain vinylbuilt from2003built until2006
Antonis N.
