Ηχεία monitor vs σπιτικά
deleted user 10898
What’s the Difference Between Home Stereo Speakers and Studio Monitors?
Pop music is made to be played back on home stereo systems. Wouldn’t it make sense to use the same kind of hi-fi speakers for monitoring and mixing? Yet recording professionals prefer dedicated monitor speakers for studio work. Here’s why!
Technical Differences
Let’s first talk about technical differences. Home stereo or hi-fi speakers are almost always “passive” speakers; i.e. they require an external (power) amplifier with speaker outputs. Studio monitors, with very few exceptions, are “active” or “powered” speakers, which means the power amplifier is built into the speaker cabinet. So you have to connect it to a line source with a volume control, i.e. an audio interface or a dedicated monitor controller.
How do you know a speaker is active or passive?
There’s a quick way to check: An active or powered speaker must have a mains inlet.
Active speakers offer some advantages. Usually, they contain not only one power amplifier but several. The woofer, the tweeter and (if available) the mid-range speaker each get their own power amplifiers, which results in a punchier, more accurate dynamic response. That’s because the woofer, which requires lots of power on each bass note and kick drum hit, won’t take away any energy from the other speakers – as it might on a passive speaker, powered by only one amp for all speakers. Having dedicated power amplifiers for each speaker also makes it easier to build top quality crossovers. Not only because the crossover can be placed before the power amps, but also because active circuitry can be used to obtain steeper filter slopes. This reduces overlap between the woofer, mid-range speaker, and tweeter, which results in a clearer, more detailed sound image.
Home stereo speakers are usually passive. There are only two speaker terminals on the rear to connect them to a power amplifier.
Different Tools for Different Tasks
When music professionals listen to music, they do it with a different mindset than music consumers. Enthusiasts simply want to enjoy the music they love as best as they can. It doesn’t really matter if the sound they hear is an accurate reproduction of what the artist intended. All that matters is the listeners’ subjective impression. Most music consumers therefore prefer speakers that seem to enhance their listening experience.
Many hi-fi speakers accomplish this by boosting the bottom end and top end. The resulting “smiley curve” makes the music appear more powerful and crisp.
Musicians, producers, and engineers want something different. They need to hear the plain truth. They want speakers that add no extra sugar and hide no imperfections. It’s no different in the home studio. If there are wrong notes, extraneous noises, or imperfect sounds, you want to address those issues before anyone else may notice. So you need speakers that give you quite a bit more detail than usual hi-fi speakers.
At the mixing stage, you need to hear if the balance is perfect. There is a fine line between loud and too loud, between powerful drums and the drums overpowering the vocals. And there’s an even finer line between solid bass and booming bass, between crisp treble and harsh treble. It takes accurate and linear speakers to make such mix decisions with any degree of certainty.
Studio monitors are usually powered speakers with power amplifiers built into the cabinet. Powered speakers have a mains inlet on the rear, and the audio input usually has an XLR connector.
How to Find the Right Pair of Monitor Speakers
When you go shopping for studio monitors, don’t get trapped into a consumer mentality.
Most dealers will demo studio monitors playing a Steely Dan CD or something else that’s extremely well recorded. It’s their way of giving you an enjoyable buying experience. But how could listening to a perfect recording tell you anything about a speaker’s ability to reveal flaws? As a result, you may end up buying the pair of speakers that sounds the most impressive. Unfortunately, this may not be the most accurate and linear pair but more hi-fi sounding speakers with a sort of smiley curve.
It’s much better to bring your own music or music that you know has little flaws. Don’t be vain! Don’t listen for speakers that make your mixes sound particularly impressive. Listen for speakers that reveal all the flaws and mistakes that you wish you could have addressed. Only if your music sounds great on the most revealing studio monitors will it sound great on any playback system!
The German company Klein & Hummel was a pioneer of the powered speaker concept. This is the amplifier board of an O98 3-way speaker from the 1980s.
http://www.neumann.com/homestudio/en/difference-between-home-stereo-speakers-and-studio-monitors
Πάντως για κάποιο μυστήριο λόγο
ακόμα και οι πλέον φανατικοί υπερμαχοι (θεωρητικως και δημοσίως)
των "studio monitors" εντός ή εκτός εισαγωγικων...
για τις κατ οίκον ακροάσεις τους επιλέγουν ηχεία που εντάσσονται
στην ευρύτερη κατηγορία των "home stereo speakers".
Το ότι διέπραξαν ένα - σύμφωνα με τους ιδίους - λάθος, δεν σημαίνει ότι απαγορεύεται να διατυμπανίζουν το σωστό.;)
Ο λόγος για κάτι τέτοιο δεν είναι καθόλου μυστήριος και συναρτάται με μια κατάσταση γνωστή με τον όρο ΄΄αισθητηριακός κορεσμός΄΄.
Δεν αναφέρεται αποκλειστικά στην ακοή,αλλά στο σύνολο των αισθήσεων μέσω των οποίων εκτιμάμε μια καταναλωτική πράξη.
Gebreselassie
Μαύρος!
Ντάξει προφανώς ο συντάκτης αναφέρεται σε απλούς χομπίστες (που βρίσκονται πολύ μακριά από εμάς).
Θεωρώ (ευελπιστώ μάλλον) ότι δεν υπάρχει κάποιος ανάμεσά μας που να ψάχνει το ιδανικό για το σπίτι του... smiley curve. Κανένας εκ των σοβαρών (ή μη) πανάκριβων κατασκευαστών ηχείων και ενισχυτικών δεν ισχυρίζεται ότι πουλάει τέτοιον ήχο. Θα ήταν σαν να προσπαθεί καποιος να πουλήσει τρυπημένα ελαστικά αυτοκινήτων. Αντιθέτως η μόνιμη επωδός του καλού χαϊεντά (χομπίστα, εμπόρου, κατασκευαστή κλπ) είναι η "προσομοίωση του πραγματικού γεγονότος". Άρα όλοι λίγο ή πολύ στον ίδιο κουβά βράζουν και όλοι θα ήθελαν κατά βάθος να έχουν monitor ήχο.
Στο πρόβλημα απάντησε ο Bhutia.
Αυτοί που ανέκαθεν ενδιαφέρονται για τον monitor ήχο δεν έχουν πρόβλημα αν το ηχείο είναι πιο άσχημο κι από την Σαπφώ Νοταρά. Οι υπόλοιποι αγοράζουν με μάτι και αυτί μαζί, είτε γιατί οι ίδιοι το θεωρούν πρωτίστως έπιπλο και δευτερευόντως ηχείο, είτε γιατί το υποκειμενικά όμορφο παίρνει την έγκριση της συμβίας, είτε γιατί προσδίδει ένα επιπλέον κύρος στην κατασκευή, παρόμοιο με το κύρος που προσδίδει το ταμπελάκι της τιμής. Επιπλέον είναι λίγο ηλίθιο να πίνει μαλτ και να καπνίζει πούρο ο χαϊεντάς (έμπορος, χομπίστας κλπ) ακούγοντας σε χαμηλές εντάσεις (ήχου και φωτισμού) Jacintha Abisheganaden δίπλα σε ένα πλαστικό monitor κι ας παίζει αυτό θεϊκά. Φαντάσου το πλαστικό monitor δίπλα σε ένα πικάπ ας πούμε με ιντερκονέκτ σαν ανακόντα. Αίσχος!
Ημίθεος
... του οποίου προηγείται η κατανόηση της πραγματικότητας προσαρμοσμένη στην προσδοκία. Δες εδώ ένα παραλήρημμα. Η θλιβερά παραμορφωμένη αντίληψη της πραγματικότητας που λίγο-πολύ στοιχειώνει κάθε χαϊεντά...
Καλώς ή κακώς, έχω υπόψιν αυτό το δημοσίευμα...Ο γραφικός κύριος δεν ενδιαφέρεται ουσιαστικά περί υψηλής πιστότητας,αλλά για καταναλωτικά αγαθά που θα πατάνε εκείνα τα δικά του κομβία,αντί αυτός τα δικά τους.
C'est La Vie...Άλλοι υπάγονται στον αστερισμό του Gearslutz και άλλοι του...Gear...slurp :lolsign:
Καλά ρε άρρωστοι και οι δυό σας διαβάσατε όλο αυτό το κατεβατό της απύθμενης βλακείας?
Αντέξατε? εγώ διάβασα μόνο μιά παράγραφο στην αρχή μία στη μέση και μία στο τέλος και αυτήν όχι ολόκληρη.
Ημίθεος
Να δγιαβάσεις εκεί που λέει για τις προδοσίες. Έχει πλάκα. Χιλιοειπωμένα και αναμασημένα είναι, αλλά δεν παύουν να έχουν πλάκα. Οι καλές οι λάμπες και τα κακά τρανζίστορ που έφεραν οι ιάπωνες, μετά το κακό το CD και πχιο μετά το κακό το mp3. Σαν εκείνο τον απίστευτο τύπο που προ ετών στον Ήχο κατακεραύνωνε τη μείωση του όγκου των αποθηκευτικών μέσων, με οργή γυμνασιάρχου. Λες και αν πάρεις ένα αρχείο 24/96 από ένα γομαροδίσκο 3,5 ιντσών και το βάλεις σε μια microSD, θα το κατακρεουργήσεις και θα χάσει τα δυναμικά του και θα του χαλάσεις και τη χωρίστρα... :roflmao:
Μιας και το έθιξες, παλιά που άκουγα Metal από βινύλιο τα μαλλιά μου μεγαλώναν πολύ πιο γρήγορα.... :roflmao::laugh:
Δεν θάσαι καλά Κωστάκη μου που θα κάτσω να διαβάσω όλο αυτό το κατεβατό βλακείας , και προσδοκιών.
Οσον αφορά στην χωρίστρα , αν κρίνω από το άβατάρ ςου έχεις ήδη πρόβλημα.! Χωρίστρας. :roflmao:
......ορεω πραμα να παγαινεις σε μια καφτερια...που δεν σε γουσταρουν....
μονο και μονο για να ακουσεις τις γιουχες σου....
και τουμπαλιν. αινωιτε........
να προσπαθεις ρε παιδακι μου να δειξεις οτι εσυ εχεις δικιο.....
τα δικα σου καλωδια ειναι πιο χοντρα και πιο μακρυα.....
να προσπαθεις να πσησεις αφτους που σε θεωρουν κεσρολα......
Τελος
Ενεργα vs σπιτικα ?
το λεει και ο τιτλος.....τα ενεργα δεν ειναι σπιτικα....
ενα πραμα σαν την σπανακοπιτα ...την ετοιμη ....vs μαμας......
ζητω τα λαπατα και το φρεσκο κρεμυδακι..........
deleted user 10898
αυτο είναι το ζουμί...
νομίζουν....
κάνουν την μουσική να μοιάζει...
σαν την σπανακόπιτα του αργυρη.
που νομίζει πως της μαμάς του είναι η καλύτερη.
(α, αργυρη εδώ μεσα σε γουστάρουμε, δεν σε γιουχάρουμε... γράψε ότι θες, όπως για το καλώδιο της τοστιέρας που έγραψες, δεν περνά απαρατήρητο μην νομίζεις, απλώς είναι θέματα που πλέον αποτελούν παρελθόν για τα διαβασμένα μέλη του avsite....)
εχεις δικιο...εδω δεν κολλαει το να θυμουνται οι παλιοι και να μαθαινουν οι καινουργιοι....
γιατι απλα δεν υαπρχουν καινουργιοι....
Και οπως ελεγε μια παροιμια .....παλιος γαιδαρος καινουργια περπατησια δεν γινεται....
Οσο αφορα τα ηχεια....ενεργα ανεργα....αεργα....οτι και αν ειναι ολα
ειχαν
εχουν
και θα εχουν τα κοινα τους.....
προφανως τα ενεργα ειναι μια σχετικα =(συγκριτικα) νεα μοδα....
οποτε .....και αυτη μερος του παιχνιδιου.....καλο ειναι να μπαινουν νεοι παικτες....να ταραζουν λιγο τα νερα......
Αν και τα νερα εχουν βαλτωσει ....ασοψετε η κριση......
deleted user 10898
εγώ νομίζω πως είναι απλώς θέμα άγνοιας, πραγματικής άγνοιας του αντικειμένου, και έλλειψης "ακροαματικής" παιδείας!
Εγώ λοιπόν, άκουγα τα focal solo 6 be σε εκθέσεις, σε ξενοδοχεία και "γήπεδα" με
metric halo και με άλλα dac, και δεν μου ΑΡΕΣΑΝ ποτε!
πάω για καλή μου τύχη μια φορά και έναν καιρό να ακούσω κάτι άλλο στο athensmastering και τα είχε στημένα. τα ακούω σκέτα, και με σαμπ, και έπαθα πλάκα. μεγάλη πλάκα που με οδήγησε στο εξής συμπέρασμα.... δεν θέλω κανένα άλλο ηχείο, μου αρκούν αυτά ή κάποια παρεμφερή, αλλά σε ένα χώρο που να πλησιάζει κάπως ένα studio.
Και ευχαριστώ τα μέλη εδώ που είχαν τις τεχνικές γνώσεις αλλά και την υπομονή και την όρεξη να γράψουν και να μου εξηγήσουν τα γιατί και τις λεπτομέρειες αυτής μου της εμπειρίας.
DimAster
