Άλλο ένα νέο μοντέλο από τη RANE στο χώρο των performance mixers με μαγνητικά faders χωρίς επαφές, που εξασφαλίζουν μακροζωία και "ελαφριά" αίσθηση.
Technical specifications
* Universal internal power supply works anywhere you can plug into 100-240 VAC.
* All four inputs are now Phono/Line switchable - plug in 4 turntables or 4 CD players, or any combination.
* Both 1/4" and 3.5 mm headphone jacks are now provided on the front.
* The Transform switches are now Kill switches.
* Operation is simplified by putting all the controls on top, increasing the width by one inch. Text is now readable in the dark under black light.
* The three long-lasting non-bleed magnetic faders did not change, as they are still the best in the business!
Επίσημο link
Επίσημο link
