Mr Spock
demokratischer - sektor
- δεν συνηθίζω να βάζω τις αναγραφόμενες τιμές στα διάφορα προϊόντα , αλλά εν προκειμένω θα γίνει μία μικρή εξαίρεση λόγω υπερ-οικονομικής περίπτωσης . . .
Pyle Phono Preamp
The PP444 is an MM-only phono preamp built around a Texas Instruments NE5532P op-amp chip. It comes with a DC 12-volt power adapter and has an input sensitivity of 3mV at 50k ohms. A green LED indicates that the extremely small and lightweight unit is plugged in and ready . . .
. . . Breakfast In America (MFSL 1-471). This album is known for having many elements spread across the soundstage, but also for its awful, overhyped cymbal sound especially on “Gone Hollywood.” The Pyle delivered a satisfying sound, without greatly over-emphasizing the cymbals and overall produced a rocking performance . . .
. . . Even though for $19 the Pyle PP444 sounds great, extreme disappointment crept in when I played the Raconteurs’ excellent “Now That You’re Gone”/”Sunday Driver” single (colored vinyl 7”, Third Man Records TMR-586) released by the Third Man Vault in December. An overly soft snare drum sound marred “Now That You’re Gone” and “Sunday Driver” didn’t rock nearly as much as it should have, but those in the market for a $19 phono preamp probably won’t know the difference . . .
https://www.analogplanet.com/content/19-pyle-phono-preamp-anything-crap
http://www.pyleaudio.com/sku/PP444/Ultra-Compact-Phono-Turntable-Preamp
Pyle Phono Preamp
- Converts Phono Signals to Line Level Signals
- State-of-the-Art Circuitry Accommodates Magnetic Pickups
- Ultra-Low Noise Operation Improves Sound Performance
- Connects to Turntables and Other Studio Equipment
- Input Sensitivity: 3mV at 50K Ohms (Phono)
- Dedicated RCA and 1/4'' Output Connectors
- Output: 2V max (P-P) at 10K Ohms
- DC 12-Volt Power Adapter Included
- Frequency Response: 20 Hz ~ 20 KHz ±2dB
- S/N Ratio (A-WTD): 70 dB - Output Level: 2V
- THD: 0.08% @ 1KHz and 3mV Input | S/N Ratio: 70dB
- Input Sensitivity/Impedance/Phono 3 mV / 50K Ohms
- Load Impedance: 10K Ohms - Reference Voltage: 1V d
- Dimensions (W x H x D): 3.54" x 2.13" x 1.02"
- Sold as: Unit
- Weight: 0.85 lbs.
