Audio Spectrum questions from the UK
gonis
Luger
Συγκριτικά με τις φωτό...εγώ βλέπω άλλα γούφερ...τι παίζει?
άλλη σειρά?
Φαίνεται να έχουν πιο στενή μπαφλα και σίγουρα διαφορετικά γουφερ.
Μόνο ο Πετροπουλος μπορεί να απαντήσει.
και είπα να μην το γράψω...ιδέα μου θα ναι...:D
Emmanouil 1964
Hello Massimo . :hi:
The speakers in 1995 ( Audio Spectrum Hermes TLS ) had 660.000 drachmas .
In the Euro today 1950e .
The basic salary in Greece in 1995 was 125.000 drachmas . ( 367 Euro )
Take Hermes with closed eyes !
* I would like to tell us how much the transport is for Greece . ( for Hermes )
THANK YOU .
[QUOTE = "Emmanouil 1964, post: 2316059, member: 35753"] Welcome Massimo. : hi:
- If the back has a label like this, send us a photo of it.
- We'll say this day the speaker was made.
- [/ QUOTE]
Unfortunately, all the speakers I have seen have no labels. Only the Xanadus have the name plaque on it. The Hermes have the Audio Spectrum plaque on the front, but no serial numbers. It feels strange and a bit dodgy, but they are all factory sealed. All the speakers have never been used and perfectly packaged.
I don't know and I don't want to ask too many questions or the man might start thinking too much about them.
[DOUBLEPOST=1530657565][/DOUBLEPOST]
yes according to the article HERMES is an easy load that could match with a low power amplifier. Minimum load 3,8 Ω at 100 Ηz.
Wish I was still in Scotland I would drive near you to buy a pair! or two!
That sounds great. my Arcam ∂ 290 gives 140W at 4Ω. That should be fine!
toulou
Δικαναλίδης
...I will definitely try to get the Hermes, and may be I keep the Axxia as well for a small set up....
Wise decision.
I forwarded this thread to a friend with lots of experience on Audio Spectrum speakers.
He suggests that given the Arcam and the music you say you listen to, the Axxias will suit you best.
Xanadus definitely crave for very robust amplification, and are less "musical" than the Axxias. As a member already mentioned though, give them the amp they are asking for, and they will deliver some GREAT sound!
But whatever you do, I repeat, you will never-ever again get a chance to lay your hands on speakers like the Hermes... for free!
I would like to tell us how much the transport is for Greece . ( for Hermes ) -
What is the weight of the Hermes? in the magazine they say 80kg. Is that for each speaker??? That is VERY heavy. :o
[DOUBLEPOST=1530659644][/DOUBLEPOST]
how can I get in touch with Petropoulos?
Να κανω τον Σερλοκ...:p
Ετσι οπως το βλεπω στη φωτο ο Ερμης ειναι ενα τριδρομο Αρτεμις, μια υλοποιηση λιγων τεμαχιων γιαυτο χωρις αριθμηση υποθετω...:cautious: παιζει να εχει και συλλεκτικη αξια ...
gonis
Luger
Good morning from Athens:)
George Petropoulos was the manufacturer and owner of the company (Audio Spectrum).I have to talk to him for several years but I have his phone,I hope it’s active.
I send it to you with pm.
4ων δρόμων :)
Οπωσδήποτε θα έχουν αλλαχτεί τα woofer.
Αν παρατηρήσετε τις βίδες που συγκρατούν όλα τα μεγάφωνα..
Δείχνουν να είναι φτηνού τύπου για ηχείο τέτοιας κλάσης..
Ποτέ η AS δεν έβαλε ασημένιες βίδες στα ηχεία της..
Πάντα χρησιμοποιούσε μαύρες..
Απόδειξη ότι έχει "ανοιχτεί¨" το ηχείο..
Το τελευταίο μοντέλο HERMES nείχε σχεδόν την διπλάσια τιμή απο το προηγούμενο το TLS..
Εδώ φαίνονται συγκεντρωτικά τα περισσότερα μοντέλα σε δύο διαφορετικές χρονικές περιόδους.
"Massimo most models are shown here in two different time periods."
1996
Οσον αφορά την ωμική αντίσταση η AS συνήθιζε στα προσπέκτους της, στα τεχνικά χαρακτηριστικά να χρησιμοποιεί τον όρο
"Σύνθετη Αντίσταση" και έδινε 2 τιμές.
Μέση τιμή αντίστασης και ελάχιστη τιμή αντίστασης..
Πιθανόν γιαυτό να υπάρχουν τόσες απόψεις..!:)
Αυτό είναι ενα φυλλάδιο εποχής 1990
πωωω τι ξέθαψες...:hi::hi::hi:
έχεις καμιά φωτό από το εσωτερικό των ηχείων που είχαν στο προσπεκτ?
Υ.Γ. Είχαν ηχείο και με το όνομά μου!?Xaris:party::p
Christos Kourmouzoglou
