Passport data
Sensitivity dB -
90
Power, W -
150
Frequency Range -
40-21000 (± 2 dB)
Number of pages -
2.5
Type of acoustic design -
fazoinvertor
Drivers -
165-mm woofer and Woofer-head with cellulose cone
Height, mm -
1050
Width -
190
Depth, mm -
250
Weight -
20.0
Crossover kHz -
0.2 / 5.0
Nominal input impedance, Ohm -
8 The measurement results
Average THD,% (100 Hz - 20 kHz), 88 dB -
0.5
Average THD,% (100 Hz - 20 kHz), 82 dB -
0.3
Average THD,% (40 Hz - 100 Hz), 88 dB -
2.1
Average THD,% (40 Hz - 100 Hz), 82 dB -
1.9 Options AFC
Flatness, ± dB (100 Hz - 20 kHz) -
2.4
Imbalance dB (160 Hz-1300 Hz) -
1.2
Flatness, ± dB (160 Hz - 1300 Hz) -
1.1
Imbalance dB (1300 Hz-20 kHz) -
-0.6
Flatness, ± dB (1300 Hz - 20 kHz) -
2.8
Imbalance dB (angle 45 °) -
4.6
Flatness, ± dB (angle 45 °) -
4.3
Cutoff frequency, Hz (-10 dB level) -
43.8 Input impedance
The standard deviation of the resistance in Ohms -
7.1
The average value of the resistance in Ohms -
10.1
Maximum resistance in Ohms -
30.8
Minimum resistance in Ohms -
3.7 Design
The mean response, 2.83 dB in 1 m (100 Hz - 20 kHz) -
92.0
Average THD,% (100 Hz - 20 kHz), 94 dB -
0.6
Average THD,% (40 Hz - 100 Hz), 94 dB -
2.6
Magnetic shielding -
no
Independent connection -
yes
Execution -
Beech
Features -
spikes stand SEARCH THIS SITE:
