Behringer MDX1600 Autocom Pro-XL Compressor & ULTRAGRAPH FBQ-PRO FBQ1502
1. Behringer MDX1600 Autocom Pro-XL Compressor
Παράθεση
Features
* Dual-channel compressor/limiter/expander
* Increases vocal presence and energy
* Compresses mono or stereo signals without loss of high frequencies
* Minimizes dangerous signal peaks
* Integrated dynamic enhancer
* De-esser
* Low-contour filter
* Stereo dynamic processor with couple function
* Auto and manual mode compression
* Separate IRC expander/gate
* Accurate 12-point meters for in/out level and gain reduction
* Switchable +4dBu or -10dBV operating level
* Sidechain I/O
* Servo-balanced XLR and 1/4" I/O
* Single rackspace
2. ULTRAGRAPH FBQ-PRO FBQ1502
(Audiophile 15-Band Stereo Graphic Equalizer with FBQ Feedback Detection System)
Παράθεση
Παράθεση
* Professional 15-band stereo graphic equalizer for live and studio applications.
* Revolutionary FBQ Feedback Detection system instantly reveals critical frequencies and can also be used as audio analyzer.
* Dedicated mono subwoofer output with adjustable crossover frequency.
* Additional low-cut filter removes unwanted frequencies, e.g. floor rumble.
* Highly accurate 4-segment LED output metering and input gain controls for easy level setting.
* Ultra-low noise audio operational amplifiers for highest signal integrity.
* Servo-balanced inputs and outputs with 1/4" TRS and gold-plated XLR connectors.
* Shielded toroidal power transformer for ultra-low noise performance.
* High-quality components and exceptionally rugged construction ensure long life.
* Conceived and designed by BEHRINGER Germany.
Ειναι σε υπερ-αριστη κατασταση εντελως καινουρια και αδουλευτα λογο αγορας επεξεργαστη ηχου.
Δεκτη Ανταλλαγη με καποιο Tablet ή με καποιο Broadcast stereo sound enhancement processor.
Tιμη: 170 Ευρω [Συζητησιμη τιμη]
Πληροφορίες Τηλέφωνο: 6947374093 Δημητρης
sitherion
