BERENDSEN AUDIO
Preamplifier PRE 1
No capacitors in the signal path. A sound reproduction whose naturalness impresses. Precise operational amplifiers. Discrete output driver configuration in single-ended class-A mode.
Poweramplifier STA 150
Power amplifier. Generously designed toroidal-core transformer. High current filter capacitors. DC-coupled. Hand-selected matching power transistors. Broad frequency range. Intricate effective protection system.
The result? Something very simple: Extraordinary sound
Powerampflifier STA 150 and Special Edition STA 150 (SE)
Inputs: 1 line pair RCA
Outputs: 1 speaker pair
Power output (5 Hz - 20 kHz, 8 Ohm): 150 W
per channel
Power output (5 Hz - 20 kHz, 4 Ohm): 240 W
per channel
Output current: 40 A (150 SE: > 40 A)
Linearity (5 - 20kHz, 22 W, 8 Ohm):
+0.02 dB, -0.08 dB
THD+N (1 kHz, 100W, 8 Ohm):
< 0.1% (150 SE: 0.006%)
THD+N (20 kHz,100W, 8 Ohm):
< 0.3% (150 SE: 0.009%)
S/N-Ratio [ref. to 50mW, 8 Ohm]: > 78 dB
Input impedance: 47 kOhm (150 SE: 2.7 kOhm)
Gain: 29 dB (150 SE: 24.5 dB)
Input sensitivity [ref. to 1W, 8 Ohm]:
100mV (150 SE: 166mV)
Mode: Class AB (150 SE: Class AB, inverting)
Transformer: Toroidal 750VA
Filter capacitance: 60,000 &micro;F
(150 SE: 100,000 &micro;F)
Weight: 46 lbs./21 Kg (150 SE: 55 lbs./25Kg)
Size: 17.5" x 15.4" x 6.1"/445x390x155mm
CD-players by Berendsen allow the acoustic reproduction of even the most subtle sound differences. The CD-mechanism, control and converter board rest on damping elements and are thus decoupled from vibrations. Analogue and digital electronics are fed by separate power supplies. The energy is supplied by 30 VA toroidal-core transformers. The operation of the digital-to-analogue converters is based on the Delta-Sigma principle. All components have been meticulously selected with regard to sound-affecting parameters. In addition to that, a manufacturing methodology that makes our products sturdy and durable. It makes the beauty of sound not a momentary pleasure, but a lasting experience.
Phonostage Analog 1
Analog One is designed and built with the quality and technology that allow us to make full use of all the potential offered by phono components of superior quality.
Technical specifications
Phono Stage Analog 1
Inputs: 1 pair MM RCA; 1 pair MC RCA
Outputs: 1 pair line RCA
Input sensitivity MC: 0.15 mV - 2 mV
Input sensitivity MM: 3 mV - 7mV
De-emphasise: according to RIAA
Linearity: < +/- 0.05 dB
S/N-Ratio: > 74 dB
Input impedance MC: 1.43 k Ohm
Input impedance MM: 47 k Ohm
Gain matching, internal: +/-6 dB
Amplifier operation: Discrete single-ended class A
Impedance selection: Via additional RCA-jacks
Toroidal transformer: 2x30VA mu-metal shielded
Filter capacitance: 37,800 &micro;F
Weight: 17.5 lbs./8Kg
Size: 17.5" x 10,2" x 2.6"/445x260x65mm
Integrated Amplifier IPA 80
Inputs: 8 pair line RCA
Outputs: 1 speaker pair, 1 pre-out pair RCA,
2 pair tape RCA, 1 headphone jack
Remote control: Yes, handset included
Display: LED-Display, red
Power output: (5 Hz - 20 kHz,
8 Ohm):
80W per channel
140W per channel
Output current: > 20A
Linearity: (5Hz - 20kHz, 22W, 8 Ohm);
+0.02 dB, -0.08 dB
THD+N (1 kHz, 22 W, 8 Ohm): < 0.005%
THD+N (20 kHz, 22 W, 8 Ohm): < 0.009%
S/N-Ratio (ref. to 80 W/8 Ohms, Filter CCIR) : > 105dB
Input impedance: 10k Ohm
Transformers: 2 x Toroidal 200VA, 1 x Toroidal 30VA
Power consumption (without music): 50W
Power consumption (standby): 2W
Weight: 32 lbs./14,4 Kg
Size: 17.5" x 13" x 4.1"/445x330x105mm
Tsimis
