Blue Circle Audio
AG8000 Hybrid Monoblock Power Amplifer
Τιμή: 14500.00 USD
Technical Information
All specs are "per channel"
Four separate chassis: 2 monaural amplifiers, each with its own separate external power supply.
150 watts into 8 ohms
True balanced topology
Tube input stage (two 6922's), Blue Circle's new solid state output stage
Two pairs of binding posts for shot-gun bi-wiring
Stainless steel chassis with high temperature powder coated BC blue steel cover standard. Other colours or stainless steel covers are available as options
Solid wood, purple heart and walnut laminated faceplate
BCC1.0 isolation cones standard.
Custom Blue Circle Polypropylene cap bypass in both B+ and low voltage power supply
Over 300,000uF power supply
2500 watt power supply transformer
DC power connection rated up to 34 amps
HexFred(tm) Ultra Fast Soft recovery diode in B+ and low voltage power supply
Dimensions: 10.5" (267mm) x 9.5" (241mm) x 22" (559mm)
Weight: amp: 30lbs
power supply: 40 lbs
AG3000 Dual Mono, Balanced Preamplifier
Τιμή: 11500.00 USD
Inputs: 2 balanced XLR
Outputs: 2 balanced XLR
4 volume controls, 2 per channel, to individually control both the positive and negative phase of the signal.
Individual phase switch for each channel.
Outboard power supply is housed in a matching full sized chassis featuring completely true dual mono B+ power supply using custom manufactured Blue Circle polypropylene capacitors (not just used as "bypass" capacitors as many manufacturers do.)
Power supply features 4 separate toroidal transformers to maintain low noise and accurate phase balance.
High speed Hexfred rectifiers
Full 35 amp capacity locking DC power connector umbilical from power supply to preamp.
Custom made Blue Circle power cord fitted with ground lift switch for ultimate system compatibility.
desmios2025
