clarke tech c2500
ψηφιακός - δορυφορικός δέκτης.
Άψογος με το τηλεχειριστήριό του.
στα 30 ευρώ.
http://www.clarketech.altoma.biz/produkte?template=detail&entryid=28&lang=en
General Data
Size: (W X H X D) 260 X 54 X 232(mm)
Operating temperature: 0°C ~ +45°C
Weight (Net): ~ 1,8 kg
Connector
SCART: 1x TV, 1x VCR FBAS,RGB
Tuner: 1x LNB in , 1x Loop Through
RF Modulator: IN/OUT IEC 169-2
RCA/Cinch: 1x Video, 2x Audio and Y/ Pb/ Pr
Data: 9 Pin D-Sub, RS232C
S/P DIF: optisch
A/V Decoding
Video formats: 4:3 [letterbox][pan&scan] & 16:9
Video resolution: 720 x 576 [PAL] 480 [NTSC]
Audio decoding: MPEG Audio Layer I & II
Transport stream: MPEG ISO 2
LNB Control
Polarisation: 13/18V [max. 400 mA]
22 KHz tone: +/- 2KHz
DiSEqC: 1.0 / 1.1 / 1.2 / USALS
Amplitute: 0,8V, +/- 0,2V
RF-Modulator
Frequency: 470 MHz bis 860 MHz
Output channel: CH 21-69
TV standard: PAL
Features
Channels total: 10000
Color: Black/Silver
Display: 4 Digits 7 Segment
USB: max. 500mA
Cardreader: 1 Cardreaderr [ Conax ]
Power Supply
Input voltage: AC 90-240V, 50Hz/60Hz
Power consumption: Max. 25 W
System
Flash: 2 MB
RAM: 16 MB
EEProm: 32 KB
Processor: 32 bit
Tuner
Input symbol rate: 2-45 MS/s
Signal level: - 25 bis - 65 dBm
Frequency range: 950 MHz bis 2150MHz
ztv
