Manufacturer's rated output: 7x 105W RMS
Max output at onset of clipping: 138.3W RMS @ 1% THD
Fidelity firewall output: 128.7W RMS @ 0.09% THD
Frequency response: 20Hz-20kHz ±0.4dB inputs (one for phono); 8x channel direct input/output; 1x coaxial digital input; 2x component video input; component video output; 5x S-video inputs; 3x S-video outputs; 5x composite video inputs; 3x composite video outputs; FM aerial; AM loop antenna
Sound formats supported: Dolby Digital; Dolby Digital 6.1 Matrix; Dolby Pro-Logic II; DTS; DTS-ES (Matrix and Discrete); DTS-ES Extended Surround; DTS Neo:6; Widescreen 7.1
Dimensions: 434(w) x 171(h) x 416(d)mm
Weight: 17kg ,χρωμα χρυσο.αριστη κατασταση.εχει 7.1 εισοδους για υποστιριξη uncompressed pcm hd audio(blu ray hdvd).remote προγραμματιζομενο.ΤΙΜΗ 450 EURO.
34,3 KB Προβολές: 76
74,1 KB Προβολές: 77
