Dune HD Pro 4K
Εξωτερικους υποτιτλους σε iso kai bd folder αρχεια τους δεχεται?
Επισης μπορεις να εχεις το kodi και να παιζεις τις ταινιες με τον εσωτερικο του player όπως το zdmc στο zidoo?
το
Dune HD Ultra 4K
  • Price
    • MSRP: 1499 EUR (price may be different depending on the region)
    • Availability: Nov-Dec/2018
ΚΑΛΑ ΚΡΑΣΑ !!!:headbang::headbang:
υπερβολικα μεγαλη η τιμη του αλλα τουμπανο!
  • Media processor: Realtek RTD1295 SoC
  • 4K support: 4Kp60 video decoding, 4Kp60 video output, 4K HEVC 10-bit, HDR, HDMI 2.0a
  • RAM: 2 GB
  • Flash memory: 16 GB
  • Connectors: 3.5" SATA HDD rack, external SATA port (data+power), 1x USB Type-C host, 1x USB 3.0 host, 3x USB 2.0 host, HDMI 2.0a, 2nd audio-only HDMI output, RCA composite video, RCA analog stereo audio, optical S/PDIF, coaxial S/PDIF, Hi-Fi RCA analog stereo audio, Hi-Fi XLR balanced analog stereo audio, 6.35mm headphone audio output, coaxial S/PDIF input, optical S/PDIF input, AES/EBU audio input, Ethernet 10/100/1000 Mbit/s, HDMI 2.0 input, 1x IR input, 3x IR output, 1x IR learn, RS232 port, 12V trigger input, 12V trigger output, 220-240/110-120V AC input
  • Ethernet: 10/100/1000 Mbit/s
  • Wi-Fi: 802.11b/g/n/ac, Dual Band 2.4/5GHz
  • Bluetooth: Bluetooth 4.x
  • Front panel display: Multi-segment VFD
  • Media sources: Internal HDDs (SATA), external HDDs (USB), USB devices (USB flash drive, USB card reader, etc), external optical disc drives (USB), PC and NAS in local network (SMB, NFS, UPnP/DLNA, HTTP), other Internet and local network media sources
  • Video codecs: MPEG2, MPEG4, XVID, WMV9, VC1, H.264, H.265, H.265 10-bit, VP9; support for very high bitrate video (up to 100 Mbit/s and higher)
  • Video file formats: MKV, MPEG-TS, MPEG-PS, M2TS, VOB, AVI, MOV, MP4, QT, ASF, WMV, BD ISO, BDMV, DVD-ISO, VIDEO_TS
  • 3D video formats: MVC, Side-by-side, Top/Bottom
  • 4K video formats: H.265 up to 4Kp60 HDR, H.265 10-bit up to 4Kp60 HDR, H.264 up to 4Kp24
  • Video output modes: Wide range of supported output resolutions and framerates (up to 4Kp60)
  • Video output framerate: Automatic (according to the played content) and manual; 23.976 Hz support
  • Audio codecs: MPEG-1/2 layer I/II/III, AAC, LPCM, WMA, WMAPro, FLAC, multichannel FLAC, Vorbis, WavPack, APE (Monkey's Audio), ALAC (Apple lossless), SACD (Super Audio CD) (**), AC3 (Dolby Digital), DTS
  • Audio file formats: MP3, MPA, M4A, AAC, WAV, WMA, FLAC, Ogg/Vorbis, WavPack, APE (Monkey's Audio), ALAC (Apple lossless), SACD (Super Audio CD) (**), AC3, DTS, DTS-WAV
  • Subtitle formats: SRT (external), SUB (MicroDVD) (external), text (MKV), SSA/ASS (MKV, external), VobSub (MP4, MKV, external SUB/IDX), PGS (Blu-ray, TS, MKV)
  • Picture file formats: JPEG, PNG, BMP, GIF
  • Playlist file formats: M3U, PLS, CUE (**)
  • Photo viewer functions: Slideshow, transition effects, picture rotation, zoom, browse playlist, repeat, shuffle
  • Network file browsing: SMB client and browser, NFS client, UPnP/DLNA client and browser
  • Applications: Dune HD applications (install from file or app store), Android applications (install from file or app store)
  • Plugins and extensions: Full support for Dune HD PHP plugins API, Dune HD skins, dune_folder.txt mechanism
  • Filesystems: FAT16/FAT32 (read-write), EXT2/EXT3/EXT4 (read-write), NTFS (read-write), exFAT (read-write), HFS/HFS+ (Mac OS Standard/Extended) (read-only), BTRFS (read-write)
  • Widevine DRM: Widevine DRM L1
  • Android OS: Android 7.1
  • RCU: Premium IR RCU with learning function
  • Case: Fanless brushed aluminum case
  • Power: AC ~220-240/110-120V, 50/60Hz
  • Dimensions (W x H x D): 430mm x 72mm x 310mm
http://dune-hd.com/eng/products/full_hd_media_players
Νεα αναβαθμιση εχουμε απο προχθες, την Version "181123_2026_r13" (BETA version)
Υποψιν & προσοχη σε αυτο, υπαρχουν πια ΔΥΟ (2) διαφορετικες ver του ιδιου player, η tv292a & η tv292b. Οι διαφορες τους ειναι στην μπροστινη οθονη και στο remote με αυτο της a να ειναι μαλλον το καλυτερο...
Το λογισμικο που ποσταρα αφορα την ver A.
Eδω μπορειτε να παρετε αυτο που εχετε..
Νέα αναβάθμιση και εφαρμογή για κινητά....
http://dune-hd.com/dunecontrol/
Recent Changes
Update 3 (190328_2127.apk, firmware version 190330_0254_r13):
  • Now Playing: Added automatic scrolling of too long text strings.
  • Now Playing: Added BACK icon at the top left corner -- another convenient way to switch to Navigator tab.
  • Now Playing: Too small cover images are now visually increased to fit available space.
  • Now Playing: Volume control, when dragging, now immediately shows the actual (discrete) volume level.
  • Navigator: Added automatic scrolling of too long text strings in the title bar.
  • Navigator: Show "(empty)" text in empty folders.
  • Navigator: More correct handling of scroll position after orientation changes.
  • Remote: Added autorepeat feature: press and hold button to generate repetitive button presses (supported for arrows, REW/FWD, P+/P-, V+/V- buttons).
  • Remote: Button presses now work quicker (on button press, not on button release).
  • Remote: Bugfix: REW/FWD buttons were mixed with PREV/NEXT.
  • Setup: Bugfix: IP address text field could be reset in some cases.
  • General: Optimized network communication between mobile app and Dune.
  • General: Mobile app now more quickly and smoothly detects changes of Dune UI state.
  • General: Improved handling of network errors.
  • General: Improved handling of app switching to/from background mode and handling of mobile device lock/unlock.
  • General: Reduced visual blinking during app start.
  • General: App icon updated.
  • Misc other minor fixes.
Update 2 (190301_1357.apk, firmware version 190301_1357_r13):
  • A lot of bug fixes.
  • Added support for more screens, menus, dialogs which were not supported in the mobile app previously.
  • More complete support for photo viewer: added ability to conveniently scroll through the photos in the current playlist by dragging the current photo left/right; simple support for zooming a photo (on mobile screen only) (use double-tap to exit zoom mode).
  • Improved handling of Android apps: when entering an Android app, Remote tab is shown automatically; when returning from the Android app, Navigator tab is shown back; when starting media playback while an Android app is active, the Android app is put into background and the media player is shown.
  • Improved handling of screen saver: actions in the mobile app (navigation, playback, etc) now stop the screen saver (and reset its timer).
  • Improved handling of UI elements (such as controls in setup screens) which do not fit into screen width: such UI elements are wrapped to the next line.
  • Fixed problem that navigation buttons (left/right/up/down) did not work via IP Control in mouse emulation mode.
Update 1 (190211_1700.apk, firmware version 190210_0252_r13):
  • Added support for folders with large number of items, all items can now be accessed (via scroll) in all places (file browser, Movies, plugins, etc) (previously only first 36 items were accessible).
  • Added text editing support -- for all places in Dune UI where text can be entered/edited (dialogs, setup, file renaming, etc).
  • Added simple support for photo viewer: current picture, PLAY/PAUSE/STOP/PREV/NEXT buttons, swipe left/right on the current picture also does PREV/NEXT. Photo viewer status is shown in Navigator tab, Now Playing can be used to control background music playback.
  • Improved support for Full Blu-ray Menu playback mode: PLAY/PAUSE/STOP/PREV/NEXT buttons, indication of current playback position (time seek is not supported).
  • Improved support for Movie Information screens (Movies, Kartina.TV, plugins).
  • Added support for various screens, menus, dialogs which were not supported in the mobile app previously (Kartina.TV / Search, Kartina.TV / Start, Setup / Video, etc).
  • Fixed the problem with "tabs" view type in Dune UI skins.
  • Various other fixes and improvements in the mobile app.
Εφαρμογη:
General Information
Dune Control is a new mobile application for iOS and Android mobile devices for remote control of Dune HD media players.
Current Status
Dune Control is currently available only as an APK file for Android mobile devices.
The iOS version is currently in the process of releasing to Apple App Store and it will be available only via Apple App Store (when released). The iOS version has 100% exactly the same functionality and look as Android version.
Public release in Google Play and Apple App Store is expected in Aprile/2019.
Features
Dune Control has the following main features:
  • Remote:
    • Fully replaces the standard IR remote control.
    • Uses Wi-Fi to connect to the local network.
    • Automatically searches for Dune HD devices in the local network.
    • Allows to control multiple Dune HD devices and easily switch between them.
  • Navigator:
    • Browse and choose media content via Dune UI shown directly on your mobile device.
    • Access local and network sources, Favorites, Recent, My Collection, Movies, Dune HD PHP plugins, etc.
    • The menu shown on the mobile device mirrors the menu shown on the TV screen.
    • Enter text into text fields in Dune UI using native keyboard on your mobile device.
    • Photo viewer mode: view photos from the Dune HD device on the mobile device, control photo slide show.
  • Now Playing:
    • See the information about the currently played media content, including (when available) movie poster, movie title, music cover, music album/artist/track information.
    • Control the playback (play/pause, stop, previous/next, playback position, volume).
Supported Models and Firmware Versions
Full functionality (including Navigator and Now Playing) is available only on the latest generation of Dune HD media player models (starting with Dune HD Neo 4K), and only when using the latest firmware version (190330_0254_r13 or newer).
Limited functionality (Remote only) is available on all Dune HD media player models with all firmware versions.
Download
APK for Android mobile devices:
Εξαιρετικό scraper! Από περισσότερες από 1000 ταινίες δεν αναγνώρισε μόνο τέσσερις. Το καταπληκτικό είναι ότι δεν δουλεύει μόνο σε δίσκο usb , αλλά και στους φακέλους δικτύου.
Το άλλο που κάνει είναι ότι, αν πατήσεις για παράδειγμα στο όνομα του ηθοποιού, βρίσκει σε ποιές ακόμα παίζει από τις ταινίες που έχεις.
Το μηχανάκι έχει κρύψει το Android στην εμφάνιση και λειτουργικότητα των Dune, έχοντας προσθέσει επιπλέον συν. :thumbsup:
Έκανε επιτέλους, αυτο που ζητούσαν διακαώς οι πελάτες στα ερωτηματολόγια που τους έστελναν, αυτό που κάνει ο ανταγωνισμός εδω και χρόνια.
Αυτο έπρεπε να έχει γίνει 6 χρόνια πρίν.
Μεγειες-μεγειες... ;)
Νεο beta update με υποστηριξη UltraHD (BD4K) BD Menu και επιτελους Netflix 5.1 audio support (for Realtek models)
Version "190412_0053_r13" (BETA version)
Download: dune_firmware_tv292a_190412_0053_r13.dff (ZIP)
Changes since 190330_0254_r13:
This version adds a lot of new features such as UltraHD (BD4K) BD Menu (for
Realtek models), Netflix 5.1 audio support (for Realtek models), CUE sheets
supports, improved support for various music formats (WavPack, APE, FLAC),
various improvements in the music player, various improvements related to
the use of Hi-Fi audio output (for Max 4K and Ultra 4K models), "TV" menu
item, initial setup wizard improvements, and various other improvements.
NOTE: There were big changes in the core parts of the firmare, so some
functions may be potentially broken in this version.
- New feature: A new graphical design for the internal audio player: now it
shows a bigger album picture, with the information about track / album /
artist below it (similarly to how "Now Playing" screen looks in the new
Dune Control mobile app), and uses a new background picture.
- New feature: Screensaver is now supported in the internal audio player
(same as was previously implemented on Sigma platforms).
- New feature: Added support for CUE sheets (same as was previously
available on Sigma-based models) in internal player.
- New feature: Added a decoder for WavPack audio files (same as was
previously available on Sigma-based models) in internal player.
- New feature: Realtek models: Added a support for playback of audio files
in APE (Monkey's Audio) format (same as was previously available on
Sigma-based models) for internal player. (On Amlogic models, APE playback
was already supported.
- New feature: Realtek models: Added a new decoder for FLAC audio files
(same as was previously available on Sigma-based models) in internal
player, for improved compatibility with various FLAC file format
variations. This in particular fixes problems with impossibility to time
seek in some FLAC files. (On Amlogic models, there were no such
problems.)
- New feature: Added a new main screen item "TV" which can be used as a
convenient shortcut for quick start of the preferred TV application. The
TV application can be any Dune HD application or any Android application.
Added a feature for automatic searching of suitable community TV
applications in Internet (similarly to how comminity Movies extensions
are searched). The new setup section "Setup / Applications / TV" can be
used to modify reconfigure "TV" item and to hide it.
- New feature: The initial setup wizard now has "auto" and "manual" modes,
"auto" mode tries to avoid asking any questions and configure everything
automatically. No questions are asked in case of Ethernet connection, and
only Wi-Fi network is asked to be configured in case of Wi-Fi connection.
- New feature: The initial setup wizard now allows to skip network
configuration by choosing "None" option.
- Improvement: Added a special optimization which disables Android feature
to automatically scan of all the connected user storage devices for media
files (which can be used by some Android applications). This Android
feature was almost never useful, but was causing unneeded background
activities and system load (especially when a huge HDD with a lot of
files is attached), which could nevatively affect the performance of the main
functionality of the player.
to automatically create Android system folders and files (used by some
Android applications) on the connected user storage devices. This Android
feature was almost never useful, but was causing unneeded writes to user
storage devices and appearance of undesired files on the storage devices.
Now such folders and files are created only on a dedicated partition of
the internal flash memory.
- Realtek models: New version of BD Menu playback engine:
- New feature: BD Menu playback mode now supports Ultra HD BD images
(BD4K).
- New feature: When using the new Dune Control mobile app, in BD Menu
playback mode, the name of the currently played file is shown in the
mobile app.
playback mode, it is now possible to time seek (change playback
position) in the mobile app; also the current playback position in
the mobile app is now disabled more correctly.
- Improvement: Improved support for remote controls with a reduced set
of buttons:
- Playback menu can now be shown by first pressing INFO RC button
to show INFO OSD and then pressing POP UP MENU RC button.
- Playback can now be stopped by choosing "Exit player" action in
the playback menu.
- Improvement: Optimized the performance of handling of BD Menu for
some BD images, some BD images and some BD scenes in some BD images
now start faster.
- Bugfix: Some BD images did not work correctly in some cases.
- Bugfix: When starting BD Menu playback simultaneously with the
internal player working in background mode, a hint about TOP MENU RC
button could be wrongly displayed on the screen.
- New feature: Realtek models: When using Netflix application,
multichannel (5.1) audio playback is now supported.
- New feature: Amlogic models: when playing IPTV stream via HTTP/TS or HLS
media streaming protocol, the user can not record the currently played
stream to the local storage by pressing "REC" RC button (same as it was
previously implemented on Sigma based models).
- New feature: Amlogic models: the use can now see the current bitrate of
the currently played media stream in the INFO OSD menu (same as it was
- Improvement: Amlogic models: Improved playback of HLS streams in some
cases.
- Improvement: Kartina.TV application updated to include some new features,
improvements and fixes which were previously implemented in Kartina.TV
STBs.
- Improvements for PHP plugins and PHP API:
- Added "style=smart_label" feature for button GUI controls.
- Updated/improved UI translations for some languages.
- Some other minor improvements/fixes.
Υπάρχουν και προβλήματα στον παράδεισο...:D
Αρνήθηκε πεισματικά να δώσει ήχο από το Unbreakable σε αρχείο που έχει ήχο LPCM 5.1. Όσο κι αν άλλαξα τις επιλογές σε PCM, bitstream, auto, δεν έδινε κάτι. Το κουφό είναι ότι στην ίδια ταινία δεν εμφάνιζε ούτε τους εξωτερικούς υπότιτλους. :headbang:
Το ίδιο αρχείο στο Prime 3.0 και Oppo έπαιξε κανονικά.
Safety Last * tl;dr *
Σε πολύ λίγες ταινίες δεν παίζει τους εσωτερικούς αγγλικούς υπότιτλους.
Σε κάποια Atmos απο το δίκτυο, απο pause δεν επαναφέρει τον ήχο αν δεν κάνεις λίγο FF-REW.
Μικρό το τίμημα της ευκολίας :p
Αν τα αναφερεις στο support τους, λογικά θα τα λύσουν.
Ενώ οι εξωτερικοί ελληνικοί υπότιτλοι παίζουν κανονικά (πάντα τους έχω σε ANSI), οι εσωτερικοί ελληνικοί σε σειρές (συνήθως του Netflix, μάλλον UTF-8) εμφανίζονται σαν ιερογλυφικά. Κάποια ρύθμιση που πρέπει να αλλάξω;
MichaelK
