Epos ELS3 - 200€
Τα Epos ELS3 στα 200€ σε άριστη κατάσταση.
PM Παρακαλώ η τηλέφωνο (6978007221)
Ευχαριστώ
Μιχάλης
Description: Two-way, reflex-loaded, magnetically shielded, stand-mounted loudspeaker. Drive-units: 1" (24mm) aluminum-dome, neodymium-magnet tweeter; 5" (130mm) polypropylene-cone woofer. Crossover frequency: 3kHz. Power handling: 100W. Frequency range: 65Hz-20kHz. Impedance: 4 ohms nominal. Sensitivity: 87dB/W/m.
Dimensions: 10.5" H (270mm) by 6.75" W (174mm) by 7.5" D (195mm). Weight: 10 lbs (4.5kg).
kalelakos
