Mr Spock
demokratischer - sektor
...This tonal characteristic is consistent with most so-called audio improvements in our resolution-obsessed age. It typically takes the form of a rising top end for a more etched, articulated, analyzed, and detailed presentation that is almost always slightly to considerably wrong when it comes to the correct reproduction of voices and acoustical instruments. But it must appeal to thousands, if not tens of thousands of listeners because so many contemporary speakers exhibit it, despite the fact that almost no venue where music is actually performed exhibits it. On the contrary, the response in your typical concert or recital hall drops quite precipitously above 4kHz, and sometimes the drop begins as low as half that frequency (see Robert E. Greene’s invaluably informative TAS essay “Records and Reality...
...On casual listening the two editions are so similar they could be different samples off the assembly line. But on critical listening, I noticed three consistent differences: (1) The Anniversary sounds ever so slightly smoother; (2) the tweeter sounds fractionally—and I do mean hair-splittingly—better integrated; (3) the whole presentation sounds slightly purer, akin to what you might hear from a really good electrostatic such as the Sanders Model 10e or my Quad 2805...
Specs
Type: Dynamic three-way vented
Driver complement: 11.81" Harbeth bass unit; 7.87" RADIAL2 mid; 0.98" ferro-cooled soft-dome tweeter
Frequency response: 35Hz–20kHz ±3dB free-space, grille on
Impedance: 6–8 ohms
Sensitivity: 86dB/1W/1m
Amplifier power requirements: 35Wpc minimum
Power handling: 650W program
Dimensions: 17" x 29.5" x 15.27"
Finishes: Silver eucalyptus, walnut, olive wood
Stands: Approx. 17", sufficient to bring tweeter to ear level
Weight: 83 lbs. each
http://www.theabsolutesound.com/articles/harbeth-monitor-402-40th-anniversary-edition-loudspeaker/
https://www.harbeth.co.uk/hifi-speaker/20/Harbeth-Monitor-40.2-loudspeaker
- οτιδήποτε έχω ακούσει από αυτήν την εταιρεία , μου άρεσε . . . παρά τις όποιες αντισυμβατικότητες , πχ οι λεπτές καμπίνες τους που πάλλονται συμμετέχοντας στο τελικό ηχητικό αποτέλεσμα ( κάτι που έχω συνηθίσει να το θεωρώ ως σχεδιαστικό φάουλ ) , όμως το αποτέλεσμα τους δικαιώνει
