Chameleon Audio
New demo item Icon Audio CD X2 cd player .
2 years warranty
3 outputs
1 coaxial
1 analog tube
1 analog transistor
http://www.chameleonracks.com/en/cd-player-λαμπατο
Specifications and Features
Easily upgraded (valves, capacitors, resistors etc)
Latest 192kHz 24bit upsampling technology
Sanyo mechanism
Class A, all Triode output stage
Signal to noise level -105dB
Freq response better than 20hz-20kHz +0 – 5db
Distortion 0.005%
Dynamic range 110dB
Coaxial digital output
Valves 12AX7/ECC82
Japanese steel EI transformers with low oxygen copper
Audiophile components
No “surface mount” parts used
Solen Polypropylene audio capacitors
Jensen Copper foil caps option
Ceramic valve holders for minimum leakage
Gold plated RCA sockets
CD-R compatible
Output 2v (0db reference standard).
220/240volts approx (adjustable to 115v)
Power Consumption: 70w
Comprehensive manual supplied
Spare mechanisms available at low cost.
Full instructions for valve change included
CE, ROHS, WEEE compliant where applicable
Size W41 D35 H12cm (Carton: 44x40x18 9kg)
Τιμη απο 1550e μονο 850e
2 years warranty
3 outputs
1 coaxial
1 analog tube
1 analog transistor
Sanyo mechanism
Distortion 0.005%
Dynamic range 110dB
Valves 12AX7/ECC82
CD-R compatible
120,8 KB Προβολές: 1
