The iPad Air is the most significant upgrade to the 9.7-inch iPad in its history. It’s lighter, more portable, more usable and faster than any previous iPad. It doesn’t fundamentally change what you can do with a tablet, but if you’re in the market for one the iPad Air really is the best iPad to date. Competition is definitely more stiff among the smaller tablets thanks to the Nexus 7, but in the nearly 10-inch tablet space it seems like Apple is going to continue to enjoy a great position there.
Απο το πρωί ευτυχής κάτοχος ενός λευκού 16 cellular.
Τα βάρος πραγματικά κανει τη διάφορα, ειναι πούπουλο παιδιά!
Απο οτι κατάλαβα έχουν έρθει μόνο 16 cellular και 32 cellular.
Τουλάχιστον σε I storm, public, πλαίσιο σε mall, golden hall και Κολωνάκι!
Απο ταχύτητα ειναι σφαίρα και πανέμορφο επίσης!
Overview of the iPad Air
The iPad Air has mostly incremental but still significant improvements over the excellent 3rd and 4th generation iPad displays. Compared to the 4thgeneration, the screen Reflectance decreased by 23 percent, the Peak Brightness increased by 7 percent, and the Contrast Rating for High Ambient Light increased by 32 percent – all good. Absolute Color Accuracy and Image Contrast fidelity are very good (but somewhat below the Kindle Fire) and are discussed in detail below. The emphasis for the iPad Air is in reduced size, thickness, and weight. The most important under the hood display improvement is the switch from a-Si amorphous Silicon LCDs up to a much higher performance IGZO LCD backplane, which was discussed in our iPad 3 Display Shoot-Out article last year. The switch to IGZO produces an impressive 57 percent improvement in display power efficiency from previous Retina Display iPads – so the iPad Air doesn’t get uncomfortably warm like the earlier iPads. More on these issues below.
Το πήρες βρε;Η διάρκεια μπαταρίας είναι αξιοζήλευτη!
47% υπόλοιπο μετά από 10 ώρες χρήση, χωρίς παιχνίδια.
Ναι, πριν μία βδομάδα. Καμία σχέση με τα προηγούμενα μοντέλα. Ξεχωρίζει αμέσως για την ταχύτητα, το βάρος και το μειωμένο πλάτος. Το κρατάω άνετα με το ένα χέρι.Το πήρες βρε;
Κι όμως, επειδή κι εγώ από το iPad 3 έκανα τη μετάβαση, αντιλήφθηκα αμέσως τη διαφορά στην επεξεργαστική ισχύ. Δεν μιλάω για παιχνίδια που δεν πολυ-ασχολούμαι. Η αμεσότητα στην απόκριση, η συμπεριφορά στο iOS 7, η πλοήγηση στο Google Earth, η αλλαγή wallpaper (στο 3 καθυστερούσε αρκετά) κλπ Όταν ξαναπιάνω το iPad 3 για μία απλή συνηθισμένη χρήση, μου κακοφαίνεται.Καλορίζικο!
Για το βάρος σίγουρα ξεχωρίζει..αλλα το θέμα ταχύτητας ειναι μονο για τα benchmark test. Σε καθημερινή χρήση (Internet browsing, YouTube, social media, και κανα Mkv) δεν εχει καμια διάφορα απο ενα ipad3..το οποίο ειναι ήδη αρκετό για τα παραπάνω..
Μονο σε πολυ απαιτητικα games και καμια πολυ εξειδικευμένη εφαρμογή. Κοινώς, ένας απλός χρήστης, δεν θα διαπίστωση καμια διάφορα απο ενα ipad3, σε θέματα ταχύτητας.
Μεγειές Alex!Ναι, πριν μία βδομάδα. Καμία σχέση με τα προηγούμενα μοντέλα. Ξεχωρίζει αμέσως για την ταχύτητα, το βάρος και το μειωμένο πλάτος. Το κρατάω άνετα με το ένα χέρι.
