vet
Audio, Δημοσιογράφος
![](/forum/proxy.php?image=http%3A%2F%2Fdemandware.edgesuite.net%2Faauj_prd%2Fon%2Fdemandware.static%2F-%2FSites-masterCatalog_Harman%2Fdefault%2Fdw84acf22c%2FJBL_ControlXWireless_Red_001_dvHAMaster.png&hash=5cf61301c73f6cd21f77542bb3ae1529)
Battery-powered stereo Bluetooth® speakers without the wires
Stream via Bluetooth® or use the rear 3.5mm input for stereo or mono playback. Unlike other stereo speakers, there’s no need for an interconnect cable or wire between each speaker. Use one or both speakers inside or outside your home, without the restrictions of a transmitter or wired cable connection.
Features Battery-powered stereo Bluetooth® speakers without the wires
30W Class-D digital amplifi cation
High Defi nition Imaging (HDI) waveguide with 1" (25mm) CMMD® Lite tweeter
5.25" (133mm) polypropylene graphite- fi lled cone woofer
Rugged, contemporary design for indoors or on-the-go
Ability to add an additional pair of speakers
Stereo or summed mono modes with channel assignment Boundary compensation switch Top Surface Volume and Playback Control
Frequency response: 62Hz–20kHz (-6db)
Signal-to-noise ratio: >75dB
Power supply: AC 100–240 VAC, 50–60Hz
Battery type: Lithium-ion Polymer (7.4V, 2600mAh)
Battery charge time: 2.4 hours @ 0.5C Playback time: Up to 4 hours (varies by volume level and audio content)
Bluetooth® transmitter power: 0-4dBm Bluetooth® transmitter frequency range: 2.402 – 2.480GHz Bluetooth® transmission range: Up to 10m (from source)
Speaker range: Up to 30m (between primary and secondary speakers)
