The A450m Mono Block
MSD-A450M Mono Block Amplifier Specifications
Maximum power output 450W @ 8 Ohm, 1 KHz
800W @ 4 Ohm, 1 KHz
1000W @ 2 Ohm, 1 KHz
Frequency Response, 20-20000Hz +0, -0.2 dB from 1W to 450W, 8 Ohm
-1dB at 100KHz
THD+N at maximum output <0.04% from 20-20,000Hz, 8 Ohm, (<0.01% at 1KHz)
Input sensitivity for 450W, 8 Ohm 1.9Vrms Balanced and Unbalanced input.
Input Impedance 94K Ohm Balanced, 47K Ohm Unbalanced
Balanced input CMRR > 60dB @ 1KHz.
Input power AC 120 V 60 Hz, 240 V 50Hz, factory set for destination country only
Power consumption 1400W Max.
Weight: Net 80 lbs (38.5 kgs), Shipping 112 lbs (50 kgs)
The P2000 Pre Amp
MSD-P2000s Specifications
LINE AMPLIFIER SECTION
Frequency Response, 20-20,000 Hz +/- 0.1 dB
THD+noise at 2 Vrms, 20-20,000 Hz <0.025%
Input Impedance 50 kOhms
Maximum Gain 20 dB
Signal to Noise ratio, A weighted 98 dB
Maximum Output at 1kHz 6 Vrms
Cross talk at 1 kHz -92 dB
Cross talk at 10 kHz -92 dB
The P2000t Tube Hybrid Performance Pre-Amp
MSD-P2000T Specifications
THD+noise at 1 Vrms, 20-20,000 Hz <0.05%
Maximum Gain 23 dB
Signal to Noise ratio, A weighted 90 dB
Maximum Output at 1kHz 8 Vrms
Crosstalk at 1 kHz -90 dB
Crosstalk at 10 kHz -90 dB
Input Power AC 110-120 V, 60 Hz
Power consumption 30 W
Size 19" W x 4 1/2" H x 13" DWeight Net 13 lbs (5.8 kgs), Shipping 16 lbs (7.2 kgs)
