Odyssey Designs
All odyssey equipment manufactured in the USA
Unit is constructed of solid metal that is precision-machined using in-house computerized CNC mills.
Faceplate and backplate are 0.4" (10 mm)-thick brushed aluminum.
Laser engraving is used for all lettering. No silk screening.
Instead of an ordinary LED indicator on the faceplate, we offer a more unique indicator that features the Odyssey logo sand-blasted into glass. The glass assembly incorporates a special lighting effect that produces a lit 3-D holographic Odyssey image.
We only use parts of the highest quality, including low-tolerance Wima caps, metal film resistors, and ALPS potentiometers.
Units undergo a three-level QC process that includes: (1) Robotic testing of components prior to soldering and assembly; (2) Testing of units immediately following assembly, including a special tuning and optimization of the power supply system for noise reduction; (3) A 48-hour burn-in process. Final steps include a double-check of bias and offset, oscilloscope and spectral analyzer testing, and individual listening tests on our reference system.
All transformers are individually tested with 13 different parameters
A true Reference Status Phono Stage for both, MM and MC is standard
Reference-grade Audio Selection dampers are included as standard!!. These "feet" provide resonance control and surface de-coupling.
Standard finish is matte black. The following optional colors are available either for the faceplate only for the complete unit for an additional $75: "Wet-Black", Silver, Gold, Dark-Blue, Burgundy, "Copper" , "Hunter Green", and Purple. Please look up our "Options" page to see the products in the different colors and for our new plating options of pure Platinum !!!! , 24 K Gold, and 99% pure Silver.
Impedence: 6 ohm / 89 dB
Woofer: 1 x 6.8" mid-bass
Tweeter: 1 x 1" dome
Freq. Resp: 32-22,000 Hz
Weight: 140 lbs./pair
Dimensions: 45 x 8 x 15"
desmios2025
