vlasis
Φωτογράφος!
http://www.perreaux.com/products/eloquence/250i_-_250w_stereo_integrated_amplifier/gallery.cfm
Dimensions
Width: 426mm (16.8") Depth: 344mm (13.5") Height: 149mm (5.9") Weight: 25kg (55lb) Amplifier
Rated Power Output (per channel): 250Wrms into 8Ω
500Wrms into 4Ω Maximum Power Output (prior to clipping, per channel): 360Wrms into 8Ω
530Wrms into 4Ω Total Harmonic Distortion + Noise
Typically:
20Hz to 20kHz:
0.002% @ 1kHz, 250W into 8Ω
0.010%, 250W into 8Ω Frequency Response
20Hz to 20kHz:
5Hz to 60kHz:
+0.00dB, -0.15dB
+0.00dB, -0.50dB Damping Factor: 800 @ 1kHz, 250W into 8Ω Signal to Noise Ratio (unweighted): better than 98dB, ref. 250W
Dimensions
Typically:
20Hz to 20kHz:
20Hz to 20kHz:
5Hz to 60kHz:
+0.00dB, -0.15dB
