Από την Ελβετία
Περισσότερα:
http://www.piega.ch/ls/c40_e.htm
The Piega C 40 is limited only by the number of pieces we can produce.
At the moment, we are able to build in a week two pairs of C 40s which are then immediately shipped throughout the world. (Which is, incidentally, two more than any other company can produce.)
So we ask for your patience if you decide to enhance your life with one of our masterpieces.
And if you do, it's absolutely understandable, since the C 40 embodies almost exactly what we envisioned as the perfect loud-speaker when Piega was founded.
The C 40 cabinet is crafted of pure sand-cast aluminum. The "C" in C 40 is based on the loudspeaker's design. If you're ever asked by a technical expert the reasoning behind the C 40's design, you can explain that this unique design yields exceptional rigidity and unparalleled sound transmission.
If the question comes from a less knowledgeable colleague, simply explain that the design was created to convey lightness and elegance.
We have put our hearts into the C 40, as well as only the most technologically advanced materials and engineering.
A total of five bass drivers are responsible for the lower sound registers. In the neighboring frequency range, you will be catapulted into the highest acoustical spheres by the coaxial mid-range and tweeter ribbon system.
The result: when you listen, you will immediately forget everything we've told you so far about the C 40 and be captivated only by the music.
copyright 1996 - 2004 PIEGA SA, CH-8810 Horgen
Περισσότερα:
