Sotis Audio
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Λαμπάτοι ολοκληρωμένοι και λαμπάτα DAC πό την Ιταλία!!!
ISIS
Digital to Analog 24bit 96Khz converter with Τube Current Sense© output stage.
We have built the most incredible D/A converter you have ever listened to.
The heart if ISIS beats with 6 PCM1704 converters, an innovative tube output stage and a low jitter line receiver.
The result is a perfect reconstruction of the musical event, smooth, rich in detail end with a great impact.
Features:
4 digital inputs
Tube Current Sense© output stage
Low jitter line receiver
6 Burr-Brown PCM1704 converters
Digital filter with selectable response
Hardware protection circuit
Alphanumeric display
Dark blue or black chassis with stainless steel and oak-wood finish
HORUS
Single-Ended, Class A Triode, Integrated Stereo Amplifier with AVVT AV32B power tubes.
Horus is a sonically exceptional amplification system, comprehensively equipped and easy to use. It’s the perfect solution for audiophiles who want their music systems to take the minimum amount of space and want to eliminate unnecessary complexity.
Features:
4 line inputs
recorder output
24 steps volume control
11 W output power
gold plated RCA connectors and speaker plugs
dark blue or black chassis with stailless steel and oak finish
SETHI
EL34 parallel single ended integrated amplifier.
Sethi is an integrated amplification sytem that where the Horus constructive and design principles apply.
Sethi is dedicated to the listener's first approach to high quality music reproduction: essential but with a realistic and breathtaking sound.
Features:
3 line inputs
13 W output power
Black chassis with Perspex and alluminium finish
Ο σχεδιαστής πρέπει να είναι λάτρης του αρχαίου αιγυπτιακού πολιτισμού.
Πολύ ωραία ονόματα έχει δώσει στις συσκευές του!
takis17
