surround formats
ενα ενδιαφερον αρθρακι τρεχει στο htm
πηγη
http://blog.hometheatermag.com/askhometheater/surround_formats_defeating_overscan_glassesless_3d/
What's Up Front That Counts
I have an Onkyo TX-NR807 receiver, which provides seven channels of amplification, and it can do 7.1, Dolby Pro Logic IIz, and Audyssey DSX. Which of these surround formats do you recommend?
Kurt Miller
As you probably know already, 7.1 places three speakers in front (left, center, right), two speakers to the sides (surround left and right), and two speakers in the rear (back surround left and right). To take advantage of this setup, you need content with 7.1 discrete channels of audio, which is practically non-existent—some Blu-ray movies have 7.1 channels, but virtually all of them have been artificially derived from the original 5.1 soundtrack. Alternatively, the AVR can synthesize the back-surround channels from a 5.1 source.
Either way, I'm not a big fan of 7.1 because it places more emphasis on the surround channels with four speakers than on the front three channels, which is exactly opposite of the way it should be. Humans have the ability to sense the direction from which a sound is coming, but this ability is much more acute in front of us than behind us. Thus, we don't need so many surround channels to convey a sense of envelopment. If we're going to add channels, they should be in front, not in the rear.
That's the idea behind Dolby Pro Logic IIz and Audyssey DSX. Dolby Pro Logic IIz is an extension of IIx, which can artificially expand two channels to 5.1; it can also expand 5.1 to 6.1 or 7.1. IIz adds the ability to synthesize two so-called "height" channels with speakers placed above the front left and right speakers, which is intended to enhance the ambience of the entire soundfield.
Audyssey DSX does much the same thing, but in addition to two height channels, it can also create what are called "wide" channels, for which speakers are placed outside the boundaries of the front left and right speakers. So if the main left and right speakers are at ±30 degrees from the center, the left and right wide speakers would be at ±60 degrees. Unlike Dolby Pro Logic IIz, Audyssey DSX requires a 5.1-channel input; it can't expand two channels.
As for which is better, that depends on your situation and preferences. DSX is more flexible, offering height and/or wide channels, whereas IIz offers only height. But Dolby can expand 2-channel sources, while Audyssey requires 5.1. In my view, either one is preferable to straight-ahead 7.1 because they add channels to the front rather than the rear.
Γιαννα
