Από την ΤΣΕΧΙΑ!
Classic is the new range of loudspeaker systems descending from the previous
Suona. Classic is synonym of certainty of shape and style as well as of elegance.
Completely handmade with the same care reserved for the „XN“ range, the Classic
emploies well known Scandinavian drivers. Vitality and gracefulness are the most
evident characteristics of the Classic range,opening new, more affordable
possibilities of choice near to the XN range. Completely handmade, each model is
available in cherry, walnut, maple and bird´s eye maple veneers.
[align=center]Mia[/align]
Mid-bass frequency unit: 130 mm, polypropilene membrane
High frequency unit: 27 mm, treated fabric soft dome
System type: damped bass-reflex with rear port
Frequency response: ( -3 dB on reference axis ): 60 - 20000 Hz
Connection: 1 pair of XAVIAN binding posts
Nominal impedance: 8 ohm
Crossover frequency: 3000 Hz
Sensitivity ( 2,83V / 1m ): 85 dB
Recommended power amplification: 30 - 120 W
Dimensions (HxWxD): 170 x 290 x 203 mm
Net weight: 5,5 kg
[align=center]Trionfa[/align]
Mid-bass frequency unit: 180 mm, carbon - fibers impregnated paper membrane,
low distortion "motor" - long excursion,
38 mm aluminium voice coil
High frequency unit: 25 mm, "Sonotex" coated fabric dome, 6 radial magnets
"motor" structure - Hexadym, Sonomax suspension
System type: 3 chambers, damped bass-reflex
Frequency response: ( -3 dB on reference axis ): 28 - 20000 Hz
Connection: two pairs of fully exposed gold plated binding posts, bi-wiring
Nominal impedance: 4 ohm
Crossover frequency: 2600 Hz
Sensitivity ( 2,83V / 1m ): 90 dB
Recommended power amplification: 70 - 200 W
Dimensions (HxWxD): 210 x 1100 x 350 mm
Net weight: 27 kg
Net weight: 5,5 kg
Net weight: 27 kg
