Zanden Audio Systems
The model 1200 is Zanden's stereo phono stage
Specifications
Equalization curve positions
RIAA, COLUMBIA, DECCA
Inputs : Low/High impedance M/C cartridge x 1
(selected by rotary switch on the front panel)
Input impedance: low: 4 ohm
hi: 40 ohm
Output impedance: 3Kohm
Gain: 36dB (1kHz, RIAA)
Frequency deflection: 0.5dB (20Hz?`20kHz)
Total harmonic distortion: 0.1% @ 300mv RMS output, 1kHz
Signal to Noise: -70dB (IHF-A, 5.0mv RMS)
Using vacuum Tubes: 6922 4 pieces, 6CA4 1 piece
Channel Balance : 0.5dB maximum
Dimensions: 398 (W)/103 (H)/405 (D)
Weight: 9kg
Zanden's model 7000-300B amplifiers are single-ended stereo triode designs.
Specifications
Input Impedance: 10k ohm
Output Load Impedance: 8 ohm (optional 4 ohm and 16 ohm available)
Nominal Power: 8‚v?{8‚v
Frequency Response: 6Hz-50KHz?i-3dB?j
Tube Complement: 300BH (WE-300B available) 2 pieces,
5687WB 2 pieces, 5U4GB 2 pieces
Dimensions: 290 (W)/290 (H)/469 (D)
Weight: 30kg
DAC
Specifications
Resolution : 16bits
Inputs : AES/ EBU (110 ohm balanced XLR connector)
75 ohm BNC (female) RCA 2 inputs
Output : 1.0Vrms/ 3K ohm RCA/ Unbalanced
Load Impedance Application : More than 10K ohm
DAC-IC : PHILIPS TDA-1541A (DOUBLE-CROWN)
Tube Complement : 6922, 6X4, 6CA4 2pieces
Dimensions : 398 (W)/103 (H)/254 (D)
Weight : 10kg
Zanden transport
Specifications
Pickup Mechanism: Philips CDM12 PRO2 with custom modification
Standard Digital Outputs: S/PDIF 44.1kHz
AES/EBU 44.1kHz
I2S (for new Zanden DAC)
master clock 44.1kHz
Clock Stability: 2 x 10-10
Dimensions: Transport 398(W) X 137(H) X 398(D)
Power supply: 352(W) X 60(H) X 390(D)
desmios2025
