Καλώδια και Hi-Fi
Απάντηση: Καλώδια και Hi-Fi
μην ξυνεις πληγες μην αναεβασω λινκ με καλωδια υγρου αερα.Με τιμες εξαιρετικα μπανιαριστικες
Audio Magic Liquid Air Cables
Last time around we wrote about the liquid metal cables from Teo Audio. In this case performance comes at a price - the disadvantage of the Teo approach is the extremely high cost of the liquid metal itself - over $100,000 per gallon! Not surprising these cables, especially at length as with most speaker cables, can get pretty pricey.
Taking an alternate approach to the concept of a liquid conductor, Audio Magic has developed a cable line using conductive liquid polymer as the conductor material in their new "Liquid Air" series of audio cables. It must be something about using liquid as a conductor, because Audio Magic's Liquid Air cables have many of the positive attributes of the Teo cables, but the lower materials costs bring these cables into reach for many more audiophiles. Prices begin at $650/1m pair for the interconnects, and $1700/8ft speaker cables.
There are 4 models in this series of cables - the entry level Liquid Air, the Sorcerer, the Illusion and the Clairvoyant Liquid Air, with interconnects, digital, and speaker cables in each series. The various models allow systems in many price ranges the opportunity to take advantage of this new liquid polymer technology. All of the cables are treated with cryogenics and Audio Magic's proprietary MST treatment.
As with the more expensive liquid metal conductor cables from Teo Audio, the Liquid Air cables from Audio Magic are available for in-home audition through the Cable Library. Well worth testing in your system
Θα εχουμε καποια καλυτερη τιμη εαν βαλω σε ολο το συστημα τετοια?:139::111:
Εγω για να πεισθώ θέλω υγρό άζωτο στα καλώδια.
Αμα τα βγάλουν ετσι να μου πείτε.
ΝΑι αμε ξεκίνα να πουλήσεις μερικά ακίνητα και βλέπουμε.
Οι τιμές τους, για κάτι καινούριο και ξεχωριστό, δεν είναι τρελές.
650 δολάρια τα διασύνδεσης.
Αυτό που με ανησυχεί είναι κάποιοι συνειρμοί που έχω με το <<Εξολοθρευτής II>> :138:
Απάντηση: Re: Καλώδια και Hi-Fi
Οι τιμές τους για κάτι καινούριο και ξεχωριστό δεν είναι τρελές.
Εππππ....
Μη μου τα ΜΙΤ τάρατε :137:
τι σε ανησυχει ?
εισαι απο κραμα μιμιτικου μεταλλου ?
οχι
αρα δεν κινδυνευεις
Χαλαρώσαμε?
Για ακούστε και αυτό που συνέβη σε φίλο μου σήμερα και σας το μεταφέρω όπως μου το διηγήθηκε...
Λοιπόν έχει στη κατοχή του ο φίλος μου τελικό λαμπάτο ενισχυτή πολύ δυνατής μάρκας του χώρου.
Το αρχικό φτηνό καλώδιο ρεύματος των 5 ευρώ που τον συνόδευε πήρε πόδι με τη μία και τη θέση του πήρε, χωρίς πολλά-πολλά, φιρμάτο και περί οπής καλώδιο ως όφειλε να έχει ένα σοβαρό ενισχυτικό!!!
Ο ενισχυτής λοιπόν είχε κάποιο θεματάκι με τη ρύθμιση του ρεύματος πόλωσης, που περιέργως εμφανιζόταν μόνο στο σπίτι του, και δεν μπορούσε ποτέ να ρυθμιστεί σωστά.
Είχε δοκιμάσει τα πάντα μέχρι που απελπίστηκε και έβαλε επάνω το αρχικό φτηνό καλώδιο της συσκευής.
Το αποτέλεσμα...
Το ρεύμα ρύθμισε μια χαρά και το συνολικό άκουσμα του τελικού ενισχυτή ήταν καλύτερο και ποιο ισορροπημένο.:118::118::118:
Για να μην βιαστήτε να βγάλετε συμπεράσματα θα πω πως όταν έβαλε το ακριβό καλώδιο στον προενισχυτή του σετ το ηχητικό αποτέλεσμα ήταν καλύτερο.
xkaragi
