Το home cinema του Argi
Απάντηση: Το home cinema του Argi.
Ολο ερωτήσεις είσαι .
Ολα θες να τα μάθεις?
Περίμενε θα έρθει η ωρα να τα μάθεις όλαααααα.
απο που Αναργυρε..:118:
με sub τι παιζει..:118:
ολαντ
να δωσω αυτο που εχω και να μεινω για λιγο χωρις σαμπ
μεχρι να ερθουν τα ερθ ελλαδα
αυτο καλο δειχνει....εεε..:112:
[reliops=Earthquake Sound Supernova Mk VI 15" 30-10 Hz sweep][youtube]dcTDl0uUHWg[/youtube][/reliops]
All distortion measurements were made within an 80 kHz bandwidth.
At 20 Hz and 100 dB output, THD+N was a little less than 6%, which is terrific performance.
http://www.hometheaterhifi.com/images/stories/2009/march-2009/earthquake-supernova-mk-6-subwoofer-20-hz-small.gif
At 40 Hz, distortion dropped to about 2%. Again, this is very good performance.
http://www.hometheaterhifi.com/images/stories/2009/march-2009/earthquake-supernova-mk-6-subwoofer-40-hz-small.gif
Plotting THD+N vs. Frequency, we can see that distortion stayed well below 5% from about 12 Hz to 130 Hz. This is actually quite amazing for having the driver in a relatively small enclosure. The peak at 140 Hz is an anomaly that I can't explain. But, it is well below any crossover frequency that you are likely to use, so it is irrelevant.
http://www.hometheaterhifi.com/images/stories/2009/march-2009/earthquake-supernova-mk-6-subwoofer-thd+n-vs-fr-small.gif
For frequency response, I was limited to measuring from 3 meters away due to the fact that sound was coming from opposite sides of the subwoofer at all times. I tried to smooth the response using the three EQ bands, but was only able to make minor improvements. You can see from this how much effect a room has on a speaker's response, and my room has a lot of wall treatments. Taking into account the peaks and valleys that are obviously room effects, I would say the MKVI is flat down to 20 Hz.
http://www.hometheaterhifi.com/images/stories/2009/march-2009/earthquake-supernova-mk-6-subwoofer-fr-small.gif
I was able to obtain a maximum output (measured 1 foot from the passive radiator) of 110 dB at 15 Hz, and 115 dB at 20 Hz.
Το σαμαπακι ειναι σουπερ ισως οτι καλυτερο κυκολφορει
παταει καθε τι αλλα στα λεφτα του και ακομα περισοτερο.
Αν σκεφτεις οτι με 4 χιλιαρικα (και κατι ψιλα ) βαζεις 4 στον χωρο σου και πες μου τι σε νικαει με 4 15ιντσα στο χωρο σου.
Που βουτανε για πλακα στους 15 κυκλους και σου αναγουλιαζουν τα σωθικα.
Οσο αφορα το δικο μου
Απλα θα ερθει τελος αυγουστου.
ΟΚ , ας μην πω αλλα, με τα μυαλα που κουβαλαμε
η αλλη λυση ειναι να παρω τον ενισχυτη της κλιπς, και το παθητικο σαμπακι της.Ακριβο μεν δυνατο in the other hand.
Και ο ενισχυτης σηκωνει ακομα ενα.
.Βεβαια το ποσό φευγει, με τοσα και πιο λιγα βαζω 2 ερθ στον χωρο μου.
Θα δω τι λεφτα θα εχω και αναλογα θα πσωνισω.:126:
Απο που Αναργυρε αυτη η τιμη..:118:
Re: Απάντηση: Το home cinema του Argi.
Δυστυχώς εμένα δεν μου αρέσουν οι μετρήσεις του reviewer και το γεγονός ότι είναι στο 1 foot δηλαδή 33 ΕΚΑΤΟΣΤΑ είναι πολύ πολύ περίεργο.
Αυτό σημαίνει ότι στα 3-4 μέτρα τα 110dB στα 15Hz δεν θα είναι ούτε 80dB - ΔΗΛΑΔΗ άχρηστα.
Και είναι λογικό γιατί ούτε το μέγεθος της καμπίνας βοηθάει ούτε ο ενισχυτής που είναι μικρός.
Αργύρη φιλικά πάντα κι επειδή το ξαναέψαξα στη θέση σου θα πήγαινα καρφωτός σε SVS PB-13Ultra.
Μην περιμένεις σοβαρό output σε χαμηλές από το MKVI.
Ούτε user feedback υπάρχει πουθενά OYTE κανένα σοβαρό ανεξάρτητο review.
Αν θες ακούς αν όχι....wish for the best...:109:
Και εγω Σωτηριε πιστευω οτι το svs 13 ultra θα ειναι καλυτερο αλλα κανει ποιο ακριβα και θελει σιγουρα 2 μινιμουμ
Φυσικα τωρα με την αλλαγη των ηχειων τον βλεπω να αλλαζει ολο τον χωρο και τα ηχοαποροφιτικα......:137:
Ετοιμαζεται για το φθινοπωρο.....:138:
Αμα φυγει η ντουλαπα, βλεπουμε, μαλλον θα παω για ενα παθητικο κλιπς με ενα αναλογο ενισχυτη.Και στην πορεια δοκιμαζω αλλο ενα.Οσο αφορα τον χωρο ειναι σχεδον τουμπανο.
Ας φυγει πρωτα το teu και μετα εχουμε καιρο για παιχνιδια.
ειπαμε , να φυγουν τα αλλα και μαλλον βλεπω sv, ας φυγει το σαμπακι .Και βλεπουμε
σωτηρη , κανουν νερα με το σερβις
James.z.2007
