Daniel Weiss - Ενδιαφέρουσα συνέντευξη
Κώστας Φ.
Ευχαριστούμε τον γνωστό-άγνωστο φίλο για το heads-up... Ήταν ό,τι καλύτερο για να συνοδεύσει το πρωινό μου καφεδάκι. Ομολογώ ότι σε πολλά σημεία μου φύγανε γελάκια (φέρνοντας στο νου μου τις μούρες κάποιων ότ-αν διαβάσουν τις απαντήσεις). :116:
Απολαύστε υπεύθυνα.
Κώστας Φ.
Μερικά highlights...
What do you see as the most significant misconception about digital audio?
Many people think it makes a difference if they play from a normal hard disk or from a solid state disk. That’s one thing.
But some people claim that they keep hearing differences between FLAC and WAV, and that would be the only theoretical difference I think.
Yes, but I don’t see how a FLAC decoder could influence jitter. So I think people hearing a difference between FLAC and WAV for instance, either have a defective FLAC decoder—which is very unlikely and easily testable—or they have a placebo effect going on. So those people I recommend to do a blind test.
Do you think that network connection is going to replace a direct connection to a computer, so we leave USB and firewire for network playback?
Yes, probably. You’d have to have a DAC which accepts ethernet connection.
Is there any kind of product you’d like to build, but that you don’t think there’s a commercial outlet for?
Yes, there’s one. One project on our list is a special testing device that allows you to test for instance whether mains cables have an influence on the sound. But I don’t know whether it’s a good idea to do something like that.
Now there is the NAD M2, Lyngdorf, Devialet… Will you ever do a digital amplifier?
Oh yes, definitely. We did one earlier on but we are going to do a different one now. Smaller and cheaper.
Is it traditional class D or are you building something new?
I don’t know yet.
You’re still experimenting with technologies for that?
Initially I wanted to do some standard class A/B, but I think I’ll go class D again because it’s the future.
There’s been a lot of criticism towards class D for increasing distortion with frequency. Do you have any concern about that?
I don’t think so. It depends on the implementation. With today’s technology you can make it very good.
Are there any specific class D amplifiers you’ve heard that you really like?
Yes, the Hypex modules for instance. They are very good.
How do you audition the equipment that you build? Do you do listening tests at all?
No, basically I don’t do that. I have some Strax headphones for some listening, but I don’t judge the electronics based on listening tests.
Does anyone else in the company do that?
No.
So it’s purely an engineering product?
Yes.
Aren’t you worried then that you’re missing some parameter that you’re not able to measure?
There might be, but we try to measure a lot of different parameters. Of course you’re never sure you’ve covered it all. But so far it’s worked out well.
Do you have people testing the equipment for you?
In pro audio we do have that, we have some trusted ears, so to speak. They tell us right away.
Not in consumer audio?
Not in consumer audio, no. So far. Of course we get reactions from customers, but we don’t change anything based on those reactions. So far they have been very good. There haven’t been any comments saying “this and this is bad”. So it’s not been an issue so far.
Κώστας Φ.
Χάρηκα που κι ο Weiss βλέπει Εthernet στο μέλλον. To - όνειρό - μας θα γίνει κάποτε πραγματικότητα και στο home audio δλδ...
Απάντηση: Daniel Weiss - Ενδιαφέρουσα συνέντευξη
απίθανος είναι ο άτιμος!
αν εσένα σου φύγανε "γελάκια", μάθε πως εγώ έλιωσα στο γέλιο, σε πολλά σημεία, αλλά ιδίως σε αυτό:
-I evaluate them based on the specs usually. I don’t do listening tests, I look at the specs.
-Well it seems to work.
-So far, yes.
μπουαααααααααααααααααααααααααααααααααααααχαχαχχαχαχαχαχααχαχαχαχαχαχαχα!!!!!!!!!!!!
καλά, με τα καβλώδια έχει μεγάλο πάθος ο άνθρωπος, ε/
-So you wouldn’t recommend a €1000 digital cable?
-No. No, I wouldn’t.
-So that money would be better spent on something else.
-Yes, on acoustic treatment maybe.
2 "Νο" σε σειρά! Τι άλλο να κάνει ο μάστορας? να πει 3 "Νο"???
αν έχεις λεφτά για ξόδεμα, ρίξτα σε "acoustic treatment" λέει ο "άσχετος"!
μπουααααααααχαχαχαχχαχαχαχαχαχαχαχα τρις!!!!!!!!!!!!!
Μπράβο φιλαράκι, μου έφτιαξες τη μέρα! Άξιος! :119::119::119:
είναι πολύ ωραίος τύπος, με άφθονο χιούμορ:
Kent was asking me to wipe out the Sabre name from the chip, but I forgot to do it (laughs).
If we did a DAC which is worse than the one we used to do, it would still be considered a good DAC because it’s Weiss. Maybe I shouldn’t say that… (laughs)
και αντίθετα με κάτι "κόπρους", είπε πολλές φορές "δε ξέρω"! Τον πάω σου λέω, τον πάω με 1000!!!
χιούμορ:
-Do you have a turntable at home?
-I do have one, yes. But I never use it (laughs).
και η "σκληρή" πραγματικότητα:
-I don’t judge the electronics based on listening tests.
-Does anyone else in the company do that?
-No.
-So it’s purely an engineering product?
-Yes.
καλημέρα σας...:126:
την μαχαιριά αυτή? :413: :142::142:
We try to make the whole design as transparent as possible. That’s why we don’t do any tube stuff.
m1ts0s
News poster
Ρε παίδες, τι λένε αυτά τα ηχεία τα Chario που δεν έχω ξανακούσει να αναφέρονται πουθενά?
Re: Απάντηση: Daniel Weiss - Ενδιαφέρουσα συνέντευξη
Έεεεε????? :203: :111:
m1ts0s
News poster
Απάντηση: Re: Απάντηση: Daniel Weiss - Ενδιαφέρουσα συνέντευξη
What is your personal system at home like?
I don’t have anything special. I have Chario speakers, an Italian high-end brand.
καλά βρε χριστιανέ, απ'ολόκληρη τη συνέντευξη, σ'αυτό το "nothing special" κόλλησες?
m1ts0s
News poster
Ε αφού όλα τα άλλα πάνω-κάτω ήταν γνωστά για όποιον παρακολουθεί avsite :138:
vlasis
Φωτογράφος!
Eγω παντως καταλαβα οτι ο Κουν φου και ο Εαρ λαδωνουν τον Weiss για να πει αυτα που λεει και βγαινουν αυτοι λαδι απεναντι μας αδερφια!!!!!!!!!!!!!!!!
Αισχος δις !!!!!
Ο Weiss ειναι εγκαθετος των δυο αυτων ψηφιακων- ντιτζιταλικων -βλαμμενων ................................επιτελους ξεσκεπαστηκαν τα τομαρια!!!!!!!!!!!!!!!!!!!!
Ακους εκει ο αλλος.....ο Κρητικος ...που θελει και ethernet στον κονβερτορα του!!!!!!!!!!
Πω πω πω αισχοι............ατελειωτα!!!!!!!!!!!!!!!!!!!!!
m1ts0s
News poster
Κάτι ξέρει τελικά αυτή η Meridian και αυτός ο Stuart και βάζουν CAT5 :138:
vlasis
Φωτογράφος!
Ωχ...ετοιμαζεται ...να γραψει.......απο κατω μου ειναι......τον βλεπω!!!!!!!!!!!!!!
:138::137::143:
Kotsidis John
Photography
εχω πληροφοριες πως ο κυρ Βαις εχει (κρυφα) στα σκαρια ενα νεο σουπερ ντακ με λαμπες, πολλες , για πρωτη του φορα...
Για ποιον το κατασκευαζει ξερετε???
themiloc
Re: Συνέντευξη Weiss + Συγκριτικό
Σορρυ Κώστα, δεν είχα δει οτι είχε ήδη μπει!
Manos58
εγχειρισμένη
Και πάνω που ήμουν έτοιμος να πουλήσω το καινούργιο μου dac και να πάρω κεφαλή των 2 χιλιάδωνε για να ακούσω μουσική ,τσουπ αυτός ο απίθανος τύπος,Ελβετός,Βαϊς και ΞεΒαϊς ,όπως διάλο τον λένε και μας ρίχνει την μπόμπα(οχι χαρακίρι).
τελικά οι αποκεντρωμένοι βλαμμένοι του φόρουμ (Κρητη-Θεσ/νίκη) κάτι ξέρανε και γκρινιάζανε τόσα χρόνια......................
ακούς εκεί να φτιάχνει ηλεκτρονικά πράγματα χωρίς να τα ακούει:201:.............decadance
Και χωρίς κα(β)λώδια επίσης...........:141:
:405::405:
Katerinanota
