Grimm Audio LS1
Κάποιοι είναι παντελώς κουφοί...
Οι περισσοτεροι φιλοι του παραδοσιακου "χαϊ εντ" εχουν ενα θεματακι με την ακοη ή/και την επεξεργασια/αντιληψη των ακουστικων ερεθισματων, εξ'ου και η γνωστη απεχθεια περι των ελεγχομενων μετρησεων και των τυφλων ακροασεων. Δι φακτς οφ λαϊφ.
Δεν ειναι κακο. Αλλωστε, το χαϊ εντ ανεκαθεν ηταν κυριως λαϊφ σταϊλ παρα επιδιωξη "πιστης αναπαραγωγης". Και παλι, δι φακτς οφ λαϊφ..
deleted user 10898
http://grimmaudio.com/info/news/all/all/4554
We are very pleased to announce that the LS1 playback functionality has been upgraded with DSD and DXD capabilities. All LS1i (USB Interfaces) that will be shipping from now on will have a DSD 64fs and DSD 128fs playback function. Playback of PCM files at 24bit/384kHz ("DXD") is also supported. Existing LS1 customers can update their LS1 USB interface themselves, please read the update instructions linked at the LS1 web page. Additional news is that the LS1 USB Interface can now be used with Windows 8 and Linux. The USB Interface has also become more attractive and sturdy by using a metal case and an anodized stainless steel top cover.
deleted user 10898
http://www.ultraaudio.com/index.php...mm-audio-ls1-loudspeakers-and-ls1s-subwoofers
Can we come to a conclusion?
The Grimm Audio LS1-LS1s combination is a true recordist’s tool that can give a studio engineer deep insight into a recording. For this, it has received strong accolades from professionals in the recording business. At the same time, it lets the music lover at home better enjoy less good, even bad, recordings than any other speaker system I have ever used.
These days, I find it less and less interesting to try various components in my system; I much prefer to listen to music. Other audiophiles, to stay happy, need something to fiddle with all the time; this is not the system for them. The Grimm Audio LS1-LS1s let me get down to excellent listening for a good long time with no fiddling whatsoever. That’s my kind of speaker system. You do need a good source and a room whose acoustics have been properly addressed. But that’s it.
For most of us, the cost of $39,895/pair is not peanuts. In fact, it’s a lot of money -- but compared with other offerings, I do not for one second think that the Grimm system is overpriced. It is an honest and thoroughly well-designed loudspeaker system -- a world-class reproducer that offers excellent value.
You can’t argue about taste -- I can imagine someone missing a bit of coloration here or there -- but I found the Grimm LS1-LS1s system the most neutral and, overall, highest-performing speaker system I have ever tested. It was with more than a little regret I that I watched them depart.
Καλά λέει ο John Markou... καταρχήν ο ριβιούερ (άσχετα με το πως παίζουν) λέει ότι δεν είναι υπερτιμημένα.... και μετά μας λέει ότι στεναχωριέται που τα επιστρέφει (του τα παίρνουν πίσω)...:cautious:
Ερώτημα: αφού ξετρελάθηκε με την ουδετερότητά τους κλπ... γιατί δεν τα αγόραζε...? :rolleyes:
deleted user 10898
Χμμμ, υπάρχουν και άλλα ουδέτερα ηχεία που παίζουν εξαιρετικά αλλά δεν το κάνουν θέμα . Τι πρέπει να γίνει δλδ?
Να γίνουν θέμα.
Για ξεκίνημα θέμα να τα μάθουμε και εμείς...
SOCO said:
Eχω μερικες αποριες περι χαμηλων συχνοτητων, αν καποιος γνωριζει η εχει διαθεση να τις λυσει ...
Αποκριση συχνοτητας , βαθιες χαμηλες, ποσο εφικτο μπορει να ειναι κατι τετοιο με μικρων διαστασεων γουφερ-καμπινας(οπως το συγκεκριμενο σαμπ που ενσωματωνεται?) και ενσυνεχεια, διαβαζουμε μηκη -πλατη κυματος χαμηλων συχνοτητων , πως αυτα ειναι ως 3διαστατη απεικωνιση των 30hz ας πουμε και πως γινεται ακομη και ακουστικα να αναπαραγουν τοσο χαμηλες συχνοτητες ?
Χωρίς ιδιότητα...επίσημου μελετητή των LS1,μπορεί κάποιος να σκεφτεί τους εξής παράγοντες:
-Ισχυρό μαγνητικό σύστημα στις μονάδες εκπομπής,σερβοέλεγχος,ικανές διαδρομές κώνων εντός των προδιαγεγραμμένων ορίων παραμόρφωσης.
-Χρήση DSP για γραμμική απόκριση φάσης όχι μονάχα στο ύψος μετάβασης (70Hz εν προκειμένω) από το 8ιντσο mid-woofer στο υποβαθύφωνο woofer,αλλά κι επί των οκτάβων εκατέρωθεν.
-Ο δε προσανατολισμός του υποβαθυφώνου δεν επηρεάζει τη φασική συνοχή ως προς την εκπομπή του mid-woofer (από τη ζώνη του φάσματος που αναλαμβάνει το τελευταίο),αφού οι χαμηλές οκτάβες διακρίνονται από μεγάλα μήκη κύματος,όπου είναι άτοπη έτσι και αλλιώς η γεωμετρική ευθυγράμμιση.
-Η επιδαπέδια τοποθέτηση με ανωφερές μοτίβο εκπομπής ισοδυναμεί προς τοποθέτηση πάνω σε νοητή άπειρη μπάφλα.Χάρη σε μία τέτοια χωροταξία ως προς την οροφή του χώρου ακρόασης,θα ελαχιστοποιούνται φαινόμενα όπως τα αναλυθέντα στον παρόντα σύνδεσμο,με αποτέλεσμα να ταπεινώνονται ακυρώσεις και να εξομαλύνεται περαιτέρω η απόκριση,αυξάνοντας έτσι την ακουστότητα στις κατώτερες οκτάβες.Το τέχνασμα εδώ είναι ότι η απόκριση του μπάσου θα γίνεται αντιληπτή σε χώρο σφαιρικό ως προς τον ακροατή,επιτελούμενη όμως ουσιαστικά σε χώρο ημισφαιρικό ως προς την ίδια τη μονάδα εκπομπής.
Eγω ημουν ασαφης ως προς τον παραλληλισμο πως λογω μικρων μοναδων μπορει να πετυχει ενα τετοιο αποτελεσμα ,ετσι και με τα "ακουστικα" αυτα που φοραμε στο κεφαλι:) ως απορια πως μπορουν και αυτα με τοσο μικρες μοναδες να αναπαραξουν τοσο χαμηλες συχνοτητες !! τι πραγματικα συμβαινει ?
Eγω ημουν ασαφης ως προς τον παραλληλισμο πως λογω μικρων μοναδων μπορει να πετυχει ενα τετοιο αποτελεσμα ,ετσι και με τα "ακουστικα" αυτα που φοραμε στο κεφαλι:) ως απορια πως μπορουν και αυτα με τοσο μικρες μοναδες να αναπαραγάγουν τοσο χαμηλες συχνοτητες !! τι πραγματικα συμβαινει ?
Υφίσταται με την απόκριση να είναι δυνητικά ομαλότερη,όπως έχει αναλυθεί στην παρακάτω δημοσίευση:
http://www.avsite.gr/forum/threads/Ανατομία-Ακουστικής-Χώρων-remastered.79626/page-11#post-1657372
Mpermplis
