Ηλεκτρονικό τσιγάρο
Y
Yiannis_B
ΠΟΤΕ δεν φορτίζουμε παράλληλα μπαταρίες, και υποθέτω ότι αυτό ακριβώς γίνεται με τους USB φορτιστές που έχουν μέσα τα mods (-πολύ πιο εύκολα φτιάχνεις charger με τάση εξόδου μικρότερη από την τάση εισόδου, στην περίπτωσή μας USB_V= 5V, output = 4,2V max.)
Διαβάστε το link, και ας μην αναφέρεται στις δικές μας μπαταρίες.
http://www.rogershobbycenter.com/lipoguide/
Parallel vs. Series Charging
A wonderful gentleman from the Netherlands contacted me recently asking about parallel charging verses series charging. He wanted to know how best to charge six of his single-cell LiPo batteries at the same time. Parallel charging adapters are readily available, so that must be the best way, right?
Absolutely not! Parallel charging can be very dangerous. Even experts from well-known battery manufacturers "consider parallel pack charging to be highly dangerous and should not be attempted even by experienced users". The problem with parallel charging (or even using your batteries in parallel) is that, when hooking up batteries in parallel, you are doubling the capacity of the batteries while, and this is important, maintaining the voltage of one of the individual batteries. What this means is that your charger, which normally monitors the battery while charging to prevent overcharging, cannot see all of the individual batteries' voltages - it can only see one.
Another problem with parallel charging is the inequality of the batteries. If the two batteries (and the cells contained therein) were from the exact same production lot, had the exact same chemical composition and age and charge history and everything else - in other words, if they were completely identical - parallel charging would be okay. But a consumer (that's you) will never be able to replicate those conditions, or even come close. The more those parameters differ, and considering the questionable balance charging techniques that many battery chargers use, the higher the chance of over charging and thermal runaway (more on that in the next section).
But what about batteries that are built in parallel? Doesn't the fact that batteries are sometime constructed in parallel mean that parallel charging is safe?
Like I said before, if you can match all those parameters to be identical, parallel charging is okay. At the factory where they make the packs, manufacturers are constantly monitoring and testing the materials that make up the cells. Each cell is labelled with a UPC code that contains the entire chemical makeup and history for that cell. When a manufacturer assembles a battery, a computer scans and sorts the cells into compatible matches. Only then is it safe to parallel charge these cells. However, when you charge a LiPo battery at home, even if it is already constructed in parallel, you don't need any fancy parallel charging boards - the work is already done for you, and you simply need to charge it as you would a normal battery.
Please, please, don't use parallel charging cords. There is no safe way to use these. Parallel charging simply tempts fate. You will be able to find thousands of successful attempts to parallel charge batteries around the web. These are simply people that have not yet managed to burn their home down. Every battery expert I have talked to agrees on this.
Series charging, on the other hand, is perfectly safe (or rather, no less dangerous than straight-up normal charging) if you set up your charger the right way. If you want to charge six single-cell LiPo batteries — that are all the same capacity — you can wire them up in series, set up your charger as if it were a six-cell LiPo, and balance charge your LiPos. The act of balance charging them is essentially making the charger individually charge each cell, making sure they are all kept at safe levels. If you only have a single-port charger, series charging is the only safe way to charge multiple batteries at the same time, but wiring them up properly is pretty complex and not something a beginner should attempt.
And the absolute best way to charge multiple batteries at the same time is to have a multi-port charger, like the Hitec X4 mentioned above. If you find yourself needing to charge many batteries at once, do the smart thing and purchase a charger (or chargers) that will fit your needs.
Πάντα οι μπαταρίες σε multi-port charger!
Παρακάτω είναι ένα link στο datasheet του SX350J:
http://www.yihiecigar.com/products_info/YiHiEcigar-SX350J-293407.html
Γιατί δεν έχουν συμπεριλάβει USB charging σε Dual battery mode?
Δεν έχει σχέση με τα ampers, μια χαρά φορτίζονται 2 μπαταρίες που είναι σε σειρά με 0,5 Α. Αλλά σε τάση 8,4 V, όχι σε 4,2 που δίνει η USB.
H YiHi, ξέρει ότι είναι πολύ επικίνδυνη η παράλληλη φόρτιση, και γι αυτό την αποφεύγει.
Ν
Νίκος Σταθόπουλος
Δηλαδή ο διπλός φορτιστής που έχω για τις 18650 δεν κάνει?? Και αν ισχύει κάτι τέτοιο, αν βάζω να φορτίζω μια μπαταρία κάθε φορά, θα είναι οκ ή θα έχω πάλι πρόβλημα?
Y
Yiannis_B
Είναι multi-port charger, άρα είσαι Ο.Κ, μπορείς να τις φορτίζεις και τις 2 μαζί. :thumbsup:
Διαβάστε και κανένα review πριν αγοράσετε...
http://lygte-info.dk/review/Review Charger Efest LUC V4 UK.html
Conclusion
The charger uses the correct algorithm has a good termination current and I like the design, but the high charge voltage is not acceptable.
The usb output does also work fine, but I do not know how much use it is in this type of charger. If it had been powered when the charger was powered, it would probably be more useful.
If Efest fixes the high charge voltage it will be a good LiIon charger, but before that happens it is not very good.
With 1A it is exactly the same, very good CC/CV charge curve, but to high a voltage.
It looks like the over charge protection in the 2600mAh cell tripped (The other cells I test with are unprotected).
Y
Yiannis_B
"The charger does a good CC/CV charge curve with a good termination current, but it charger to 4.28 volt, not 4.20 volt (Maximum 4.25 volt), this is not good."
Ο δικός μου από την άλλη. efest LUC V2, μετράει Ο.Κ. (4.218V με FLUKE 87 IV πολύμετρο, όταν έχω πάνω μια πλήρως φορτισμένη μπαταρία), μπορεί να το διορθώσανε στην πορεία.
Σε κάθε περίπτωση, δεν βλάπτει να το μετρήσετε μόνοι σας.
edit: Αυτό που μέτρησα είναι η κόκκινη καμπύλη (τάση), μετά την κίτρινη κάθετη γραμμή (τέλος φόρτισης), οπότε το σωστό είναι να μετρήσετε την τάση λίγο πριν σταματήσει η φόρτιση, να είστε δηλαδή αριστερά της κίτρινης γραμμής. Θα ξαναμετρήσω με DSO, και θα επανέλθω.
Τα κοινά σημεία είναι οι διπλές πακτωμένες μπαταρίες .
Μπορεί κάποιοι που βιάζονται να χρησιμοποιούν USB που φορτίζουν με 2Α από την πρίζα και δεν το μολογάνε ....
Η τα αφήνουν με τις ώρες και βράζουν λόγω ανεπάρκειας του ενσωματωμένου φορτιστή να κόψει
Τσέκαρε αν και πόσο ζεσταίνονται κατά την διάρκεια της φόρτισης .
Μην σε δούμε "φλαμπέ" φιλαράκι :acute:
να παρεις αυτο βρε Μανο αν θες διπλες μπαταριες και με usb .......:p
....σκεπτομενο μοντακι θαχεις ;)
η παρε αυτο με το οποιο το παιζεις αν θα εκραγει απο usb :p
.......ειναι μη σκεπτομενο βεβαια αλλα ομως πολυ ωραιο μοντακι :roflmao:
τωρα το κανεις και 150 watt και ποιος σε πιανει :D
δεν υποφέρεσαι... έλα αύριο για καφέ και για να πάρεις τον ντρίπερ σου....:smoke:
Δε με λέτε κορίτσια, υπάρχει θέμα με τη φόρτιση του Γίιιχιιιι απο USB;
Γιατί αν πρέπει να βγάζω τη μπαταρία, θα το δώσω πίσω να πάρω κι άλλο VS. :)
:dance2: :dance2: :dance2:
πρόβλημα δεν έχει, απλά επειδή είναι κάθετα κολλημένη η θύρα στην πλακέτα, θέλει προσοχή....;)
Edit. πες μας εντυπώσεις κλπ....
Εντυπώσεις κατ' αρχήν θετικές.
Είμαι προσεκτικός με τα USB και βάζω μακρύ καλώδιο. Αν και έχω 2Α φορτιστή, αργεί να φορτίσει αφού μάλλον αυτοπεριορίζεται στο 1Α. Το VS αντίθετα, φορτίζει ταχύτατα.
Άριστη ποιότητα κατασκευής αλλά μέτρια γωνιώδης αισθητική, λατρεύω την αποπάνω ατσάλινη πλάκα.
Μισώ την αλλαγή ρυθμίσεων με κλίση που απ' ό,τι διάβασα εδώ ευτυχώς θα απενεργοποιείται στο μέλλον. Ελαφρά δύσχρηστο menu.
Δεν αναγνωρίζει αυτόματα τα NI200 για να αλλάξει σε temp mode όπως το VaporShark. Εκτός αν κάνω κάτι λάθος... :rolleyes:
Γενικά, μια μπαταρία που πρέπει να δίνει σταθερό ρεύμα είναι όλα τα mods. :) Οι ατμοποιητές είναι πολύ σημαντικότεροι.
Βρέι, που είσαι συ; Έκανες λάθος κι αντί ψεκάσεις με το διπλάσιο αμονιαζόλ, ψέκασες με το διπλάσιο εξαφανιζόλ;
Christos Kourmouzoglou
