dsp-ax1 yamaha
Πωλειται ο πανισχυρος ενισχυτης yamaha dsp-ax1 σε πολυ καλη κατασταση μαυρο χρωμα.
Tιμη 350 ευρω.
Power output: 110 watts per channel into 8Ω (stereo)
Surround output: 110W (front), 110W (center), 110W (rear)
Frequency response: 10Hz to 100kHz
Total harmonic distortion: 0.005%
Damping factor: 200
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 86dB (MM), 96dB (line)
Channel separation: 60dB (MM), 60dB (line)
Output: 150mV (line), 1V (Pre out)
Video Connections: component, composite, SVHS
Dimensions: 471 x 211.5 x 473mm
Weight: 28kg
roberto_portale
