Marantz SR7010 - SR7011
Eδω μεσα γραφουμε εντυπωσεις αποριες για τον Marantz SR-7010
Αυτην την στιγμη τρεχει προσφορα για τα μελη του σαιτ ! Μετά από συνεννόηση με τον Θεόδωρο Τσουρεκά ιδιοκτήτη της Ηχοέκφρασης που εκανε το μελος "cantona "η τιμή για τα μέλη του avsite διαμορφώνεται στα 1230€ με 3 χρόνια εγγύηση !(ο ένας + από την Ελληνική αντιπροσωπία) οποτε και το νημα θα γεμισει σιγα σιγα ατμιζοντας τον χωρο !
Note the following bench test results for the amp section:
2 Channels Continuously Driven, 8-Ohm Loads: 0.1% THD=128.7 watts, 1.0% THD=168.8 watts
2 Channels Continuously Driven, 4-Ohm Loads: 0.1% THD=201.7 watts, 1.0% THD=235.3 watts
5 Channels Continuously Driven, 8-Ohm Loads: 0.1% THD=84.3 watts, 1.0% THD=113.1 watts
7 Channels Continuously Driven, 8-Ohm Loads: 0.1% THD=83.2 watts, 1.0% THD= 103.4 watts
What's new in the 2015 model compared to previous model (SR-7009)?
  • 32-bit DAC (AK4458VN) for all channels - advised by jdsmoothie in post number 212.
  • DTS:X with Neural:X upmixer (via firmware update fall 2015)
  • HDCP 2.2
  • HDMI 2.0a (HDR)
  • WiFi - 802.11n
  • Additional speakers that can be used to expand from 5.2.4 --> 7.2.4: SB or HT1
  • New iOS/Android Marantz Remote app (available now for Android and soon after for iOS) - only for 2015 models
Resetting the SR-7010.Note that for microprocessor and network reset, all user and Audysseysetup settings will be wiped out. The SAVE/LOAD configuration steps should be performed beforehand to save user and Audysseysettings.
(1) Soft reset. Un-plug the power chord for approximately 10 minutes.
(2) Microprocessor reset. Also known as the factory reset.
Turn OFF the unit
Turn ON the unit and simultaneously press the GAME and A-DSX buttons.
Wait until the display starts flashing in 1 second intervals, then release the two buttons.
(3) Network reset.
Turn OFF the unit
Turn ON the unit and simultaneously press the MOVIE and MUSIC buttons.
For those interested in powering the floor speakers with external amps and utilizing the internal amps of the SR-7010 to power the Atmos/ceiling height speakers, jdsmoothie has given the following manual amp assign configuration in post number 364:
Amp Assign: 11.1
Height Speakers: 4 Height Speakers
Height Layout: TF + TR (or whatever height speaker positions you are using)
Wide/HT 2: Top Rear (or whatever 2nd height speaker position you are using)
Pre-out: Front
Firmware Version
SR7010
1. 3/3/2016
-Add the "DTS: X" sound mode feature.
- When the customer connects the AV receiverto MAC Book laptopPC and then the specific MP3 music file (Album art size is bigger than 1000 x1000 pixels) is played on the iTunesvia AirPlay, the AV receiverreboots before starting the playback of the MP3 file. The symptom is a problem that the AV receiverreboots before starting the playback of the MP3 music file.
- The signal is not output from Top Middle Channel when the customer calibrates the AV receiverby AudysseyPro.
- Able to use Rear Height (instead of Surround Height) with Auro 3D Upgrade (SR7010and AV7702MKIIonly)
Sugah
Ζαχαρούλης
Έχει κάποιος εμπειρία το πως χειρίζεται τα 2 subwoofer ο ενισχυτής;
Πρεπει να ειναι και τς δυο μπροστά όπως ο Pioneer ή μπορεί το ενα μπρος και το άλλο πίσω όπως ο Γιαμαχας;
TERMATOGAZI
Bass!
οπου θελεις τα τοποθετεις , υπολογιζει gain και delay και μετα τα διορθωνει ως συνολο.
Με τις ακυρωσεις τι γινεται αν μπουν μπρος πισω τα sub; το εψαξε κανεις;
Καλοακουστος ο Marantz!!!!
TERMATOGAZI
Bass!
Καλοακουστος ο Marantz!!!![/QUOTE
ακυρωσεις υπαρχουν ακομα και με ενα sub λογω χωρου . τι γινεται τοτε?
Ειναι σοβαρο θεμα, θελει πολυ δουλεια, μελετη, μετακινησεις περα-δωθε....
Δεν εχω διαβασει κατι για τοποθετηση 2 sub μπρος- πισω, με απλοϊκη λογικη μου φαινεται πιθανο να μπλεκεις με πολλες ακυρωσεις. Δεν το εχω ψαξει (ενα εχω μονο ετσι κι αλλιως:)), ξερει κανεις κάτι παραπάνω; Απο περιεργεια... κανένα link?
[DOUBLEPOST=1461746443][/DOUBLEPOST]:offtopic:
Ο Marantz SR7010 ειναι φουλ εξοπλισμενος, αλλα δεν εχει ’’γκαζι’’ σε αντιθεση με τον Yamaha RX-A 3050. Στους προενισχυτες που αναφερεις, ο Yamaha CX-A5100 ειναι καλυτερος απο τον Marantz av7702 mkII ο οποιος ειναι made china, σε σχεση με τον av8802a που ειναι made in japan !!! και βγαζει αλλη ποιοτητα. Υπαρχει και ο Marantz av8801 στα 1500 με 1900 ευρω στο εξωτερικο, κι αυτος made in japan, αλλα δεν υποστηριζει τα Dolby Atmos, DTS X, Auro 3D, αν αυτα δεν σ’ ενδιαφερουν . Δες εδω για πολυ καλες τιμες www.smitsarnhem.nl, www.idealo.de, www.homecinesolutions.fr, www.idealo.fr
Έχω τον Marantz SR 6003 με τον οποίο είμαι πολύ ικανοποιημένος, αλλά σκέφτομαι πως ήρθε η ώρα για ανανέωση. Σκέφτομαι σαν επιλογή τον 7010, με δεδομένο πως έχω τελικό πεντακάναλο που θα δώσει το "γκάζι". Έτσι φαντάζομαι πως ο 7010 θα είναι καλή επιλογή σε σχέση με τον rx a3050.
gvts
