Bullying (Kii Audio Three)
gonis
Luger
Hello Christos,
congratulations on your new Kii Threes, we hope you will enjoy listening to your whole music collection and have a great time.
We plan to ship the first Kii Control units by the end of the year. Please see the attached pictures for a first glimpse on what it looks like.
The size is approximately 11x15cm.
The Kii CONTROL will offer three additional inputs for the Kii THREE:
Coax, Optical and USB (up to PCM 24/384kHz and DSD64/DSD128), the inputs are located on the backside connector panel as shown on picture 1.
It offers lossless volume control inside the DSP of the Kii THREEs remotely adjusted from the Kii Control.
The volume knob also offers mute or dim functions and manual power on/off (standby).
The Kii CONTROL also has IR remote capability, preset functions plus additional functionality accessible via a software menu on the OLED display.
A dedicated input button (labeled XLR) will switch to the existing hardware input on the speaker, which you can continue to use as Analog or AES input.
That means it can indeed handle your complete setup just fine.
Your Vinyl/Phono setup would be connected to the analog inputs on the speakers.
The Accuphase Tuner could be connected digitally to the Kii Control via SPDIF (Coax) and
the Marantz CD Player can be connected digitally to the Kii Control, too, via Toslink (optical).
So you can easily switch between all your sources and control the volume via the Kii Control.
I hope this answers your questions,
All the best from the Kii Team,
Tom
Τώρα δλδ τι είναι ετούτο ? τηλεχειριστήριο? Μπά. Εχει optical coaxial και ethernet νομίζω.
Αμάν ρε Χρήστο , όλο μαλακίες ψωνίζεις και μας βάζεις να μαντεύουμε. Τι σκατά είναι πάλι αυτό?
Για να ξέρω τι γκάζια θα χώσω μετά στον ear. !!
Μάλιστα. Μαλλί με τελίτσα.
Ωραία όλα αυτά , αλλά αν λέω αν συνδέσεις το tuner accuphase και το marantz cd Player επάνω στο κοντρόλ , που θα έχεις τα μηχανήματα? στο τραπεζάκι έμπροσθεν ? δεν νομίζω ότι είναι και πολύ εργονομικό το όλο σύστημα. Και φυσικά ,αν έχεις το κοντρόλ στο ρακ , μαζί με τα μηχανήματα , δεν θα έχεις τηλεχειρισμό . Πάλι σκατά τα έκανε ο Μπρούνος. Ακούς ear?
Αν και το ir δεν είναι και ο πιό σύγχρονος τρόπος ελέγχου συσκευών...
Τι να σου κάνω ρε κιαρατά που με κατέβασαν Αθήνα άρων άρων. Αμα ήμουν εκεί θα πίναμε μπύρες παρέα και θα στα έλεγα Live , τα κάλαντα.
Είναι στα όρια της γυφτιάς το ότι δίνει ir και δεν έχει περιλάβει το remote.
χμμμμμμμμμ..... Σα να θυμίζει κάτι χαιεντάδικα brands ή είναι η ιδέα μου?
gonis
Luger
Ειναι θέμα κοινωνικής πολιτικής.
Το rc ευνοει την παχυσαρκία,παράγοντα κινδύνου για καρδιαγγειακή νόσο,και οχι μόνο,με ταυτόχρονη επιβάρυνση του συστήματος υγείας.:D
Αντίθετα το σήκω-κάτσε ειναι μια μορφή άσκησης με ευεργετικά αποτελέσματα.:p
Τι εννοεις; το kii control δεν εχει το remote μεσα στο πακετο; το γραφει καπου αυτο;
Δεν γνωρίζουμε αφού δεν έχουν παραδοθεί στα πελατάκια, αλλά όπως περιγράφεται δεν το έχει.
Γιατί, έχει το Grimm όταν πάρεις το ενσύρματο παπαρέλο; :)
Ασε Χρήστο , δεν ξέρεις πόσο βλαστημάω που ο προ μου δεν έχει RC, μόνο για το volume ρε γμτ. Οι τρελαμένοι ιάπωνες παρόλο που είχαν την λύση έτοιμη δεν το έβαλαν γιατί είναι λέει high end. Και οι high end owners πρέπει να σηκώνονται και να ξανακάθονται επί του καναπέως 50 φορές την ημέρα αν κάνουν 3ωρη ακρόαση. Το ΔΙΑ τους.
Όταν τα ηχεία είναι στραμμένα περισσότερο προς τα έσω, εστιάζοντας τις δέσμες των 2 ηχείων μπροστά από τη θέση ακρόασης, τότε υπάρχει ή αίσθηση πιο συμπαγούς κέντρου στη μουσική σκηνή, και ταυτόχρονα είναι πιο ευρεία η θέση ακρόασης, πιο ευρύ κι όχι σημειακό σουιτ σποτ. Γενικά, η αφεντιά μου, αυτής της σχολής είναι, της μεγάλης κλίσης προς τα έσω, φυσικά μέχρι του ορίου του λοβού. Σε αυτήν την τοποθέτηση, περιορίζονται σημαντικά οι αντανακλάσεις από τους πλαινους τοίχους. ;)
H Bose εδώ και 10ετίες ισχυρίζεται πως πρέπει να ισχύει το αντίθετο!!! :D
Direct/Reflecting® speaker technology
At a live performance, much of the sound you hear is reflected off the walls, ceiling and floor. Only a small percentage reaches you directly. It's this combination of reflected and direct sound that makes live music sound live. With conventional speakers, virtually all of the sound is radiated directly into the room. Much of the spaciousness of the live performance is lost.
Bose® Direct/Reflecting® speaker technology delivers a blend of reflected and direct sound similar to a live concert. You experience the power, impact and emotion of a concert hall performance in your own home.
Stereo Everywhere® speaker performance
Because many conventional speakers radiate sound into the listening area in a single direction, you hear balanced stereo sound only in one small "sweet spot." Many Bose® speakers use either proprietary Direct/Reflecting® speaker technology or an Articulated Array® speaker design to deliver balanced stereo sound almost anywhere in the listening area, an experience we call Stereo Everywhere® speaker performance.
  • loggeo
naples7
