Kii Audio
JOHN MARKOU
Münchhausen
Καθόλου. Μάλιστα ετοιμάζω νέο βιβλίο, με τίτλο:
"Life and death in sound".
Δομημένο ως εξής:
Chapter one: Definitions
1a. What is a little bit of less life in sound (for my tastes)
1b. What is a little bit of more life in sound (for my tastes)
1c. What is a little bit of less death in sound (for my tastes)
1d. What is a little bit of more death in sound (for my tastes)
1e. What is the exactly right amount of life in sound (for my tastes)
1f. What is the exactly right amount of death in sound (for my tastes)
2a. What is a little bit of less life in sound (for my wife's tastes)
2b. What is a little bit of more life in sound (for my wife's tastes)
2c. What is a little bit of less death in sound (for my wife's tastes)
2d. What is a little bit of more death in sound (for my wife's tastes)
2e. What is the exactly right amount of life in sound (for my wife's tastes)
2f. What is the exactly right amount of death in sound (for my wife's tastes)
3a. What is a little bit of less life in sound (for my best friend's tastes)
3b. What is a little bit of more life in sound (for my best friend's tastes)
3c. What is a little bit of less death in sound (for my best friend's tastes)
3d. What is a little bit of more death in sound (for my best friend's tastes)
3e. What is the exactly right amount of life in sound (for my best friend's tastes)
3f. What is the exactly right amount of death in sound (for my best friend's tastes)
4a. What is a little bit of less life in sound (for my second best friend's tastes)
4b. What is a little bit of more life in sound (for my second best friend's tastes)
4c. What is a little bit of less death in sound (for my second best friend's tastes)
4d. What is a little bit of more death in sound (for my second best friend's tastes)
4e. What is the exactly right amount of life in sound (for my second best friend's tastes)
4f. What is the exactly right amount of death in sound (for my second best friend's tastes)
5. ...For my forth best friend's tastes
6. ...For my fifth best friend's tastes
7. ...For my son's tastes
8. ...For my dog's tastes
9. ...For my enemy's tastes
10. ...For my donkey's tastes
Etc etc etc
Chapter two: what is taste
Chapter three: a little bit of bullshit
Chapter four: a day at the zoo with my friends
Chapter five: the reviewer's wife and her small tits
At least βαρετό to death. Not my pick.
[DOUBLEPOST=1493331523][/DOUBLEPOST]
DSP: Den Sagapise Pote. (oute a little bit)
Agapi Mono. (for my tastes)
Life Mono. (for the reviewer's tastes)
I'd point the finger to Supertramp:
Τράτζικ..
To λες και μόνος σου Τρατζικ. :fuckyou:
dapost
Rehdeko & Harbeth lover
"If I use Dirac Live equalization to correct my room's sound, my current reference speakers, the Bowers & Wilkins Diamond 802 D3s, don't sound much different from the Kii Threes, but the correction makes for a smaller sweet spot with the B&Ws. Without EQ, the 802 D3s are a little brighter in the highs and, in the upper bass, have just a bit of warmth due to placement and room acoustics. The audible effect of a Dirac Live calibration with the Kii Threes was inconsequential."
Μα τι; Μοιαζει ο ηχος του 802 με του kii; Και οι χροιες; Μαλλον τα ισοπεδωσε ολα το dirac.
Τελικα παιζει καλα το kii; Αφου σε τοσο κοσμο δεν αρεσει καθολου! Δεν καταλαβαινω.
To μονο μειονεκτημα που του βρηκαν ειναι η ζωντανη καμπινα; Καυσοξυλο κι αυτο; Α, μαλλον γι αυτο δε θα αρεσει...
Υ.γ. Τοσο δυσκολο ειναι να μετρησει και παραμορφωση ο JA;) ;
Akis_G
"The Kii Three didn't just lift a veil away from the music—it removed a heavy cloak."
Μια συνηθισμενη πεπλοσηκώστρα !
Σιγα, κι ένα καλωδιο το κανει αυτό.
Α ρε ρηβγιουερς...:smg:
Τον Rubinson όσο τον διαβάζω, τοσο τον γουστάρω:
B&W, πολυκάναλος, Dirac, κανει τα reviews στα ενδιαφέροντα προϊοντα (kii, MQA κτλ), συμφωνώ με τις περισσότερες παρατηρήσεις του.
Θα γίνω οπαδός.
Akis_G
Θα γίνω οπαδός.
Καλα, για σενα οποιος εχει B&W είναι αδερφος!
:p
dapost
Θα γίνω οπαδός.
Ναι, σιγα μη δε σου αρεσε εσενα! Συναφι σου:
https://www.linkedin.com/in/kalman-rubinson-89b50111/
Σχολιάζει ο JA:
"Other than that rather lively enclosure, which raised my eyebrows, I was impressed by the Kii Three's measured behavior. Very impressed."—John Atkinson
Read more at https://www.stereophile.com/content/kii-audio-three-loudspeaker-measurements#6BFAUFDICtvmPEtl.99
Gojakla
Αρχαιολάγνος πιουριτανίστας
Σαν εταιρια ετοιμαζουν κατι αλλο; Καποιο αλλο προιον ή καποιο upgrade;
Γνωριζουμε;
Η ερωτησης προκυπτει απο την σκεψη μου μηπως προκειται για καποια "φουσκα" σαν εταιρια που δεν θα εχει καποια συνεχεια.
Οχι οτι με καιει και πολυ δλδς... οχι οτι θα καιει και εσας δλδς... just thinking loud.
zakman35
Πολλά ηχεία σε αυτήν την κατηγορία τιμής έχουν ζωντανή καμπίνα. Απλά αυτοί που το παραδέχονται τα χαρακτηρίζουν ως BBC Monitors, ενώ οι υπόλοιποι απλά Monitors.
Υπηρχε μια φημολογία για ενα μικρότερο ηχείο, και ενα floorstander... αλλα δεν βλέπω φως. Αν σκεφτούμε ποσο καιρό τους πήρε για να βγάλουν το Kii control στην αγορά, μάλλον θα πρέπει να περιμένουμε αρκετά. :D
Εγω σκέφτομαι μηπως έχουμε να κάνουμε με μια επίδειξη σχεδιαστικής ικανότητας...
"Κοιτάξτε πόσο καλο ηχείο μπορώ να φτιάξω, πάλι" , και μετα πάμε στο επόμενο project.
Gojakla
Δε σας προβληματιζει/βαζει σε σκεψεις το γεγονος οτι για καθε νεο project φυτρωνει και καινουριο ΑΦΜ, brand κλπ κλπ... ?
Όχι, γιατί;;
Εκτός του ότι ίσως να θέλει να τα σπάσει με παλιές συνεργασίες, είναι πιστεύω και για λόγους ιδιοκτησίας και φορολογίας.
nikos3391
