Analog News
Mr Spock
demokratischer - sektor
- Specifications
Type
Bi-Axis inertia controlled Dynamic and Eddy Current Damping Dynamic Balance type tone arm
Overall length 306mm. With head shell: max 326 mm
Effective length 241mm (i.e. tonearm pivot point to cartridge stylus point)
Overhang 15mm
Offset angle 21.5 degree
Height 59mm lifts up to 92mm
Height adjustment range 39mm-72mm at sub arm center
Depth 36mm without connecting cable
Optimum cartridge weight 15-35 grams, including headshell
Horizontal tracking angle error -1.1 degree - +2.2 degree , 0 degree at inner band of record, 2.2 degree at outside
Tracking force adjustment range 0-38 grams by 0.2 grams step
Sensitivity Horizontal:less than 50 mgrams, Vertical:less than 40 mgrams
Net weight 1,380 grams
Output connection 5P connector
Headshell connection EIA standards 4 Pin connector
Accessary
  • low resistance (0.046 ohms/m, 54pF/m) high quality arm cable,
  • milled aluminium headshell weight 15.4 grams.
  • mounting template for the arm
  • overhang guage for the headshel
A
AKARL
Mr Spock
VPI Introduces Cliffwood Dedicated MM Phono Preamp
Michael Fremer | Nov 16, 2017
VPI just announced a stand-alone dedicated moving magnet phono preamplifier based upon the circuit in the Player turntable's built-in unit.
VPI's aims not to complete with specialty electronics manufacturers but rather to provide a VPI branded phono preamp to VPI entry level customers who buy the Cliffwood turntable. The price in black and clear silver finish will be $500.00. Initially the Cliffwood phono preamp will be available only in the United States.
Here are the specs:
Low-noise op-amp design, regulated linear power supply
Gain 44db
Input loading: 47K Ohm -180pF
Maximum input level: 125mV
Input sensitivity: 3mV for 500mV output
Frequency response (50K Ohm load):17Hz (-3dB) to 75KHz (-0.2dB
) RIAA accuracy (50K Ohm load): +/-0.18dB 100Hz to 75KHz
Power requirements: 110VAC @ 100mA
Read more at https://www.analogplanet.com/conten...dedicated-mm-phono-preamp#Ld45Qryyp0W2x8p6.99
Ultra Audio
VPI PRIME SCOUT : ANALOGUE PRODUCT OF THE YEAR
https://www.stereophile.com/content/stereophiles-products-2017-joint-analog-components-year
With the Prime Scout turntable, VPI nudges their well-loved, budget-priced Scout in the direction of their more upmarket Prime (darned if I know where they got the name). The result is a belt-drive turntable with a curvy solid plinth, a damped aluminum platter, and a sturdy outboard motor. It's bundled with VPI's JMW 9 tonearm, an aluminum-and-stainless-steel unipivot with an effective length of about 9.5".
Read more at https://www.stereophile.com/content...nt-analog-components-year#A4gYrW5ZyUL5g0Sy.99
Mr Spock
Pro-Ject Audio Jukebox E: Πικάπ με ενισχυτή
Όλα σε ένα είναι το νέο από την Pro-Ject. Η εταιρία ανέπτυξε και κατασκεύασε το νέο πικάπ-σύστημα Jukebox E που έχει ενσωματωμένο ενισχυτή 2x20W αλλά και Bluetooth.
Το πικάπ μοιάζει σαν τα άλλα μοντέλα της Pro-ject και έρχεται μαζί με ένα ζευγάρι ηχείων βάσης. Το όλο σύστημα κοστίζει 599 ευρώ.
Υπάρχει οθόνη με ενδείξεις, οι ακροδέκτες για τα ηχεία βρίσκονται στο πίσω μέρος, έχει ρυθμιστικό έντασης στην πρόσοψη και είναι ειδικά φροντισμένο ώστε να μην επηρεάζει η λειτουργία του ενισχυτή… το πικάπ.
Η Prio-Ject με το Jukebox E απευθύνεται σε όσους αρχίζουν τώρα με το hi-fi και θέλουν ένα εισαγωγικό σύστημα που να τα έχει όλα… και κυρίως να παίζει καλά. Μακριά από τα πλαστικά… της Κίνας.
Το Jukebox θα είναι μια ολόκληρη σειρά συστημάτων με βάση το πικάπ. Στα επόμενα μοντέλα θα υπάρχει ακόμη και ενσωματωμένο Steamer με app, υποπλατό, βραχίονα τύπου S και μεγαλύτερο ενισχυτή.
Jukebox: New turntable from Pro-ject with built-in amplifier
http://www.hxoseikona.gr/nea/5986-pro-ject-audio-jukebox-e.html
- είμαι κάπως επιφυλακτικός με τέτοιου είδους combo , αλλά από την άλλη 600eu για πικάπ ( κομπλέ ) + ενισχυτή + ηχεία . . . οικονομικό φαίνεται
Mr Spock
Heed Audio Quasar phono preamplifier
Ken Micallef | Nov 21, 2017
Description: Solid-state moving-coil/moving-magnet phono preamplifier with standalone power supply. RIAA accuracy: 20Hz–20kHz, ±0.5dB. Frequency response: 3Hz–150kHz, ±3dB. Voltage gain: 50dB (MM), 62–78dB (MC). Moving-coil sensitivity: 100, 220, 600µV. Input impedance: 47k ohms (MM); 100/470/1000 ohms (MC). Output voltage: High Out, 775mV (0dBm)/22 ohms; Low Out, 220mV/100 ohms. Maximum output voltage: 7V (p–p). Output impedance: 50 ohms (High Out), 600 ohms (Low Out). Signal/noise (A-weighted): 80dB (MM), 66dB (MC). Channel separation: >90dB. Distortion (THD, 1kHz, 100mW): <0.08%. Power consumption: <10W.
Dimensions: Quasar & Q-PSU power supply (each): 3.75" (95mm) W by 3" (75mm) H by 8.7" (220mm) D. Weight (combined): 6.6 lbs (3kg).
Finish: Black.
Serial number of units reviewed: Quasar: 213030542. Q-PSU: 261030156.
Price: $1200. Approximate number of dealers: 20. Warranty: 3 years.
Manufacturer: Heed Audio Kft., Reviczky Gyula u. 9-11, Budapest H-1181, Hungary. Tel: (36) 1-294-7401. Web: heedaudio.com.
Conclusions
I spent many a night with Heed Audio's Quasar and Q-PSU, engaged in all the revelry and vinyl music-making excitement they created with boundless enthusiasm and deep soul. Like Heed's Elixir, the Quasar is very well built, and its jacks easily withstood the endless tugs and twists this audio reviewer subjected them to. It exhibited pleasing tonality from LP to LP, resolving each disc with its own unique character and a broad soundstage with a grain-free treble, and plentiful midrange and bass extension.
I'd long heard about this rather plain-looking, spartan phono stage—how it could transform the sounds of lesser systems, and challenge bigger comers with more hi-fi cred and glossier nameplates. The Heed Quasar is a mighty mite of musical authority, a twin-turbo phono stage that offers plenty of flexibility, a practically bombproof enclosure, and ample musical meat and value for the dollar. My brother already wants to buy one. Radically recommended!
https://www.stereophile.com/content/heed-audio-quasar-phono-preamplifier
Mr Spock
Ortofon SPU Wood A: Πάει για 100 χρόνια
Την επόμενη χρονιά, το 2018 δηλαδή, η Ortofon συμπληρώνει 100 χρόνια παρουσίας, εκατό χρόνια από την ίδρυση της.
Μια από τις κεφαλές που έρχονται για να σηματοδοτήσουν αυτό το μεγάλο γεγονός είναι η SPU Wood A που είναι ένα αριστούργημα τόσο οπτικά όσο και μουσικά, όπως λέγεται.
Για την κατασκευή της SPU Wood A η Ortofon έχει εφαρμόσει ότι το καλύτερο από τα εργαστήρια της σε Ιαπωνία και Δανία. Το ξύλινο κέλυφος της κεφαλής είναι επεξεργασμένο με βερνίκι Urushi για να του δώσει μια πυκνή, ισχυρή και θωρακισμένη επίστρωση.
Για την κεφαλή αυτή η Ortofon έχει σχεδιάσει αντάπτορες ώστε να ταιριάζει με SME, αλλά και APJ-1 για μεγαλύτερο μήκος με τι πρότυπο GM. Η κεφαλή έχει σφαιρική βελόνα με ακτίνα 18 μικρών, η δύναμη 30-50 mN σε γωνία 20 μοιρών και στάθμη εξόδου 0,18 mV. H εσωτερική αντίσταση είναι 2,5Ω, η συνιστώμενη αντίσταση φορτίου είναι πάνω από 10Ω.
Η SPU Wood A θα κυκλοφορήσει στην αγορά φέτος τον Δεκέμβριο στην τιμή των 1.790 ευρώ. Επίσης η Ortofon θα κυκλοφορήσει ένα ημερολόγιο τοίχου για το 2018 στα 25 ευρώ.
http://www.hxoseikona.gr/nea/5994-ortofon-spu-wood-a.html
SPU Wood A technical data
Output voltage at 1000 Hz, 5cm/sec. - 0.18 mV
Channel balance at 1 kHz 1,5 dB
Channel separation at 1 kHz 20 dB
Channel separation at 15 kHz 10 dB
Frequency range at -3 dB 20-25.000 Hz
Frequency response - 20-20.500 Hz
Tracking ability at 315Hz at recommended tracking force *) 70 µm
Compliance, dynamic, lateral - 10 µm/mN
Stylus type - Spherical
Stylus tip radius - R 18 µm
Tracking force range - 3.0-5.0 g (30-50 mN)
Tracking force, recommended - 4.0 g (40 mN)
Tracking angle - 20°
*) Typical value
Internal impedance, DC resistance - 2.5 ohm
Recommended load impedance > 10 ohm
Cartridge body material - Wood
Cartridge color - Dark maroon
Cartridge weight - 31 g
https://www.ortofon.com/spu-wood-a-p-758
Mr Spock
Glanz Βραχίονες
Η Glanz δεν είναι καινούργια. Ξεκίνησε τη δεκαετία του 1950 από την ιαπωνική εταιρεία Mitachi Acoustics, της οποίας τα αναλογικά προϊόντα ήχου κυκλοφορούσαν με την ονομασία Glanz.
Αρκετά από τα προϊόντα της εταιρείας δημιουργήθηκαν από τον Masataka Hamada, ηχολήπτης στο επάγγελμα, ο οποίος ανέπτυξε δεξιοτεχνία στην κατασκευής βραχιόνων για πικάπ. Τελευταία ο Hamada απέκτησε ειδική άδεια από την οικογένεια Mitachi για την εμπορία των βραχιόνων με το όνομα Glanz.
Οι Glanz κατασκευάζονται από την Hamada Electric στην Shizuoka της Ιαπωνίας. Η σειρά προσφέρει τρία μοντέλα: την πρωτοποριακή σειρά S πολύ υψηλών προδιαγραφών, την προσιτή σειρά B και το μοντέλο SD. Όλοι οι βραχίονες κατασκευάζονται από τον ίδιο τον Hamada.
Η σειρά S είναι κατασκευασμένη από εξαιρετικά σκληρό ανοξείδωτο χάλυβα υψηλής ποιότητας, χρησιμοποιώντας συνδέσμους και όχι με κόλλες στερέωσης.
Η καμπυλότητα του βραχίονα σχήματος S μετράται με ακρίβεια. Ο άξονας του βραχίονα διαθέτει τέσσερα μεγάλα ρουλεμάν, το καθένα είναι κατασκευασμένο με το χέρι χρησιμοποιώντας σφυρί κοσμημάτων, για ακραίες ανοχές.
Υπάρχουν διάφορες στρατηγικά τοποθετημένες δομές απόσβεσης εντός του σωλήνα βραχίονα και ένα σύστημα αντίβαρου που ενσωματώνει ένα άλλο σύστημα τριπλής απόσβεσης που συγκρατούνται με στρώματα από ίνες άνθρακα.
http://www.hxoseikona.gr/nea/6022-glanz.html
Specifications
Model
MH-104S
MH-124S
Type
static balance
Effective/Active Length
245mm/230mm
305mm/290mm
Offset Angle
22゜
20゜
Overhang
15mm
Stylus Pressure Adjustable Range
0.25g (minimum scale) ~ 3g (1 circle)
Suitable Phono Cartridge( w/headshell)
9~40g
7~42g
Height Adjustable Range
41~ 70mm
Mounting Hole
30mm dia. (option: 24mm dia.)
Mounting Depth
~ 30mm
Mass
1.00kg
1.05kg
Accessories
head-shell, mounting screw x 4, hex wrench x 2
MH-4S Head-shell
Specifications
Material: Integral shell and plug of machined stainless steel
Leadwire: Stranded OFC
Mass: 12g (including leadwires and screws)
Mounting Screws: stainless steel 2.6mm dia. X 16mm x 2 pcs./stainless steel 2.6mm dia. X 12mm x 2 pcs.,/stainless steel nut 2.6mm dia. X 2 pcs.
http://sibatech.co.jp/glanz/index.html
http://www.sixmoons.com/audioreviews/glanz/2.html
Mr Spock
Semper sonus: Πικάπ από τη Πορτογαλία
Οι φίλοι μας οι Πορτογάλοι μπορεί να μην φημίζονται για την τοπική audio βιομηχανία τους, αλλά ποτέ δεν είναι αργά.
Εκεί στη Λισαβόνα δημιουργήθηκε μια μικρή εταιρία κατασκευής πικάπ. Ήδη η Semper sonus έχει το πρώτο μοντέλο που είναι το ΤΕ1.
Ένα πικάπ όπου η κίνηση μεταδίδεται όχι με ιμάντα αλλά με τροχαλία. Υπάρχει ένα δεκαπολικός κινητήρας BLDC που οδηγεί το αλουμινένιο και ακρυλικό πλατό, βάρους 3,3 κιλών, μέσω ενός χαμηλής ελαστικότητας τροχό *
Όλα τα στοιχεία του είναι αναρτημένα με σορμποθανη, αλλά υπάρχουν και αντισταθμιστικά μαγνητικά συστήματα για την ομαλή λειτουργία.
Το σασί είναι από οπλισμένο σκυρόδεμα με ατσάλινα δεσίματα, υπάρχει σύστημα σταθεροποίησης για την τροφοδοσία του κινητήρα, ελεγκτής στροφών ώστε να υπάρχει ακρίβεια περιστροφής και έρχεται με βραχίονα Jelco SA-750EB και κεφαλή Denon DL-110, αλλά και χωρίς.
http://www.hxoseikona.gr/nea/6029-semper-sonus.html
* . . . χμμμμμ , νομίζω πως έχει ξαναγίνει τέτοια προσπάθεια στο παρελθόν αλλά δεν ''περπάτησε'' . . . είδομεν
https://sempersonus.com/te1/
Mr Spock
Καταστολή θορύβου στην είσοδο phono από την Akiko Audio.
Η γνωστή για τα παθητικά συστήματα καταστολής θορύβου Akiko, παρουσίασε μια λύση προσαρμοσμένη στις ανάγκες των σημάτων πολύ χαμηλής στάθμης που παράγονται από τις κεφαλές και οδηγούνται στις εισόδους phono ενός συστήματος. Η χρήση του Phono Booster, όπως και των υπόλοιπων προϊόντων της εταιρίας, είναι πολύ απλή και, με βάση τα όσα αναφέρονται στον δικτυακό τόπο της, η επίδρασή του αφορά κυρίως στον θόρυβο υψηλών συχνοτήτων.
Η καταστολή του συνολικού θορύβου σε ένα σύστημα είναι ειδικότητα της Akiko και η εταιρία αναφέρει ότι πηγές θορύβου όπως το δίκτυο τροφοδοσίας και οι διάφορες συσκευές που παράγουν και διαχειρίζονται υψηλές συχνότητες επιδρούν ιδιαίτερα στα χαμηλής στάθμης σήματα που παράγονται από τις κεφαλές. Το Phono Booster ακολουθεί την κλασική προσέγγιση της εταιρίας, όντας παθητικό και έξω από τον δρόμο του σήματος. Η κατασκευή βασίζεται σε ένα εξωτερικό περίβλημα εντός του οποίου έχουν διαμορφωθεί δύο διαμερίσματα που έχουν γεμιστεί με ένα μείγμα από υλικά (για τα οποία, παγίως, η Akiko δεν δίνει πολλές λεπτομέρειες) και συνδέονται γαλβανικά με έναν αγωγό. Η συνολική δομή είναι σταθεροποιημένη με μια ειδική “μαύρη” ρητίνη η οποία εξασφαλίζει την ελαχιστοποίηση των μικροφωνικών εφέ (της επίδρασης δηλαδή των ηχητικών κυμάτων στην όλη κατασκευή). Το ίδιο το περίβλημα είναι κατασκευασμένο από αλουμίνιο μεγάλου πάχους και η μόνη επικοινωνία με τον έξω κόσμο είναι ένα απλό καλώδιο που τερματίζεται σε έναν ακροδέκτη τύπου “U”.
Το Phono Booster μπορεί να τοποθετηθεί δίπλα ή και πίσω από το πλατό, δίπλα ή πάνω στον προενισχυτή phono και το μόνο που χρειάζεται είναι να συνδεθεί το καλώδια με κάποιον διαθέσιμο ακροδέκτη γείωσης από αυτούς που έχουν, συνήθως, όλοι οι προενισχυτές phono. Η συσκευή δεν συνδέεται με το δίκτυο τροφοδοσίας.
Σύμφωνα με τα όσα αναφέρει η ίδια η Akiko, “η χρήση του Phono Booster προσφέρει καλύτερη ποιότητα σήματος”, με χαρακτηριστικά όπως “σημαντική αναβάθμιση στην απόδοση των φωνών και των ακουστικών οργάνων” καθώς επίσης και “αύξηση στην αίσθηση του χώρου και στην απόδοση των μικροδυναμικών”. Το αποτέλεσμα, αναφέρεται, είναι “μια πιο ευχάριστη μουσική εμπειρία, επειδή η στάθμη του θορύβου έχει μειωθεί και το άκουσμα είναι περισσότερο ξεκούραστο”. Οι διαστάσεις του Phono Booster είναι περιορισμένες (98x65x39, mm) και το βάρος του 430 γραμμάρια. Όλες οι συνδέσεις έχουν γίνει με ασημοκόλληση και ο ακροδέκτης είναι επίχρυσος, της Hirshmann. Η κατασκευή είναι χειροποίητη και περιλαμβάνει αγωγό σύνδεσης με μήκος 60 εκατοστών. Η Akiko προσφέρει εγγύηση επιστροφής χρημάτων για χρονικό διάστημα 14 ημερών και εγγύηση 10 ετών για την κατασκευή.
http://avmentor.gr/news/2017/akiko_audio_phono_booster.htm
- εδώ θά ήθελα από του έχοντας τεχνικές γνώσεις να μας πουν εάν και πως δουλεύει κάτι τέτοιο
Specifications:
  • Dimensions: 98 mm x 65 mm x 39 mm (Length x Width x Height).
  • Weight: 430 gram.
  • All soldering is done with Silver Solder.
  • Gold plated Hirschmann 4mm banana socket.
  • 60 cm Connection cable included.
  • The Akiko Audio Phono Booster is Hand Made.
  • 10 years factory warranty.
https://www.akikoaudio.com/en/akiko...dio-accessories/549-akiko-audio-phono-booster
Katerinanota
