DACs - τελειωμό δεν έχουν
Όταν μετατρέπουμε ένα CD σε flac με το exact audio copy τα αρχεία δημιουργούνται σε 24 /192 ? Και τα flac που κατεβάζουμε γράφουν κάπου σε τι είναι?
δεν εχει νοημα να το κανεις αυτο,αν και τεχνικα γινεται,γιατι πολυ απλα δεν εχει κανενα πρακτικο οφελος μιας και τo cd εχει χαμηλοτερη (πολυ) ψηφιακη αναλυση και συγκεκριμενα 16/44.1.
Mr Spock
demokratischer - sektor
Brinkmann Audio Nyquist DAC
New Meets Old
Equipment report
Mention the name Helmut Brinkmann to an audiophile and the first thing that comes to mind is probably the German designer’s superb turntables. But Brinkmann began his audio career more than 35 years ago making amplifiers, and even designed his first DAC way back in 1986 (called the “Zenith”). Now Brinkmann has come full circle with the new Nyquist DAC, a product that is designed and built with the same fanatical attention to detail as the company’s turntables. Moreover, the Nyquist is brimming with advanced features, including MQA decoding, high-speed DSD support, Roon-ready operation, UPnP connectivity, and upgradeable digital circuitry. Yet for all its cutting-edge digital prowess, the Nyquist’s output stage is built around that most ancient and venerable of audio technologies, the vacuum tube . . .
Conclusion
The Brinkmann Nyquist is the perfect marriage of the new and the old, combining the latest cutting-edge digital technology and connectivity with a tube-based analog platform. Moreover, the Nyquist embodies the ethos of one of high-end audio’s most passionate and dedicated designers, bringing 35 years of analog design experience to the digital arena. I also like that the Nyquist’s digital section can be upgraded, assuring that you can keep up with technological advancements. The world-class headphone amplifier further adds to the appeal. But best of all, the Nyquist is extremely compelling musically with its delicious analog-like warmth, bloom, and ease. When you add it all up, the Nyquist could very well be the off-ramp from the digital-upgrade highway
Specs & Pricing
Inputs: USB, SPDIF, AES/EBU, TosLink optical, RJ45 Ethernet
Outputs: Balanced on XLR jacks, unbalanced on RCA jacks, balanced headphone
Formats supported: PCM up to 384kHz, DSD64 and DSD128 via DoP, DSD256
Gain adjustment: 0 to +10dB (line out); 0 to 90 (headphone output)
Output voltage: 3.5V (balanced)
Output impedance: 10 ohms (balanced)
Dimensions: 16.5" x 3.75" x 12.2"
Weight: 26.4 lbs. (DAC), 26.4 lbs. (granite base), 7 lbs. (power supply)
Price: $18,000
http://www.theabsolutesound.com/articles/brinkmann-audio-nyquist-dac/?page=3
Mr Spock
Krell Vanguard Universal DAC:
To νέο δικτυακό DAC της Krell δέχεται σήματα PCM μέσω ομοαξονικής και HDMI μέχρι 24/192 και μέσω οπτική έως και 24/96.
Το Vanguard Universal DAC παίζει μουσική από στικάκια USB ή σκληρούς δίσκους, καθώς και μέσω δικτύου. Μπορεί να αναπαράγει όλες τις δημοφιλείς μορφές αρχείων ήχου, συμπεριλαμβανομένων αυτών υψηλής ανάλυσης.
Εννοείται ότι παίζει DSD, αλλά μόνο μέσω της HDMI. Έχει επίσης Bluetooth με aptX. Για τον έλεγχο του DAC η Krell παρέχει μια εφαρμογή για iOS και Android. Ακόμη έχει πρόσβαση στις υπηρεσίες Tidal και Deezer, ενώ είναι Roon-ready. Κάτω από το καπό υπάρχει το τσιπ DAC ESS9018, ενώ το στάδιο εξόδου είναι balanced με διακριτά υλικά Τάξης Α.
Υπάρχουν μενού για την ρύθμιση της συσκευής, η οποία μπορεί να λειτουργήσει και ως προενισχυτής. Υποστηρίζεται και από τηλεχειριστήριο.
Η νέα σειρά Vanguard της Krell περιλαμβάνει ακόμη έναν τελικό και έναν προενισχυτή, όλα με οθόνες. To Vanguard Universal DAC κοστίζει περί τα 5.000 ευρώ.
http://hifipig.com/krell-digital-vanguard-integrated-amplifier/
http://www.krellonline.com/downloads/Vanguard_Series_Owners_Ref.pdf
. . . CONCLUSION
Those not convinced of just how good Krell can be, should give this one a go, and particularly the digital version. This one just does everything except make coffee, and allows user adjustment of settings from the comfort of your armchair, and does it all with both authority and tenderness. If you want a large-scale performance in your living room, especially in the speed of sound and stereo spread, you will like this one, but if you want easy listening, then go elsewhere; this Vanguard will keep your attention for as long as it’s switched on.
Sound Quality – 8.90/10
Value for Money – 8.6/10
Build Quality – 8.8/10
Overall – 8.77/10
Price at time of review £5,998
Pros:
Digital features pleases everyone
Muscle where you need it
Well behaved bass
fast and accurate imagery
Petite size of amplifier will please more folk
Quiet fans keep the heat down
Love the red and blue lights
Cons:
Pretty expensive but a lot of features for the money
You might not like the bonnet
Janine Elliot
SPECIFICATIONS
Inputs
1 pr. balanced via XLR connectors
3 pr. single-ended via RCA connectors
1 HDMI
1 USB
Outputs
1 pr. speaker outputs via WBT gold-plated binding posts
Control inputs
1 remote IR detector input via 3-conductor 3.5 mm connector
1 12 VDC trigger input via 2-conductor 3.5 mm connector
Control output
1 programmable 12 VDC trigger output (300 mA maximum current) via 2-conductor 3.5 mm connector
Input impedance
Balanced: 95 kΩ
Single-ended: 47.5 kΩ
Frequency response
20 Hz to 20 kHz +0, –0.01 dB
<2 Hz to 150 kHz +0, –3 dB
Signal-to-noise ratio
>90 dB, wideband, unweighted, at maximum gain, referred to full power output
>97 dB, “A”-weighted
Gain
48 dB
Input sensitivity
Single-ended or balanced: 160 mV RMS
Total harmonic distortion
<0.015% at 1 kHz, at 200 W, 8 Ω load
<0.13% at 20 kHz, at 200 W, 8 Ω load
Output power
200 W RMS per channel at 8 Ω
400 W RMS per channel at 4 Ω
Output voltage
113 V peak to peak
40 V RMS
Output current
16 A peak
Slew rate
50 V/μs
Output impedance
<0.066 Ω at 20 Hz
<0.075 Ω, 20 Hz to 20 kHz
Damping factor
>121 at 20 Hz, referred to 8 Ω
>106, 20 Hz to 20 kHz, referred to 8 Ω
Power consumption
Standby: 12 W
Idle: 70 W
Maximum: 1300 W
Heat output
Standby: 41 BTU/hr
Idle: 239 BTU/hr
Maximum: 4436 BTU/hr
Dimensions
17.1 in W x 4.15 in H x 17.5 in D
434 mm W x 105 mm H x 445 mm D
Weight
Unit only: 39 lb [17.7 kg]
As shipped: 47 lb [21.3 kg]
Digital Module Specs
Coaxial and HDMI inputs support PCM up to 24-bit/192kHz. Optical input up to 24-bit/96kHz
HDMI inputs support DSD and 4K video content. HDMI output supports Audio Return Channel (ARC)
USB and Network streaming support MP3, AAC, WMA, WAV(PCM), FLAC, ALAC up to 192kHz
Bluetooth streaming supports A2DP, AVRCP, HFP, HSP
Mr Spock
Mytek Shipping the Affordable, High Performance, Full-Featured Liberty DAC with MQA
Brooklyn, NY | February 6, 2018 — Mytek is now shipping the new Liberty DAC, a PCM/MQA/DSD USB2 Digital-to-Analog convertor, designed for high quality music playback and monitoring of all high resolution formats.
This USB2 DAC features several digital inputs, digital volume control, unbalanced as well as balanced audio outputs, and a high-performance headphone amplifier.
Designed as a little brother of the original Brooklyn DAC around the ES9018 Sabre chipset, the Liberty DAC provides robust performance, ability to stream MQA masters and state-of-the-art headphone output in a small 1/3 rack package. It’s also intended for general music studio use and desktop systems, as well as audio installations.
SPECIFICATIONS:
CONVERSION:
Up to 384k, 32bit PCM, native DSD.
Up to DSD256, DXD, 127dB Dynamic Range.
MQA HI-RES DECODER:
Built-in certified hardware MQA™ decoder.
DIGITAL INPUTS:
USB2 Class2 (OSX, Linux driverless, all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP).
ANALOG OUTPUTS:
One pair of unbalanced RCA, one pair of balanced TRS, TRS to XLR. Metropolis cable can be added as option.
HEADPHONE AMPLIFIER:
Reference high current, high transient Headphone Amp, 300mA, 3 Watts, single unbalanced headphone jack, designed to drive hard-to-drive headphones, 0.1 Ohm impedance.
CLOCK GENERATOR:
Low noise with 10ps of jitter.
FIRMWARE:
Upgradable via USB via Mytek Control Panel app for Mac and PC.
OPTIONAL DC/BATTERY POWER INPUT:
12VDC
DIMENSIONS:
W x D x H = 5.5x8.5x1.74 inches / 140 x 216 x 44 mm
WEIGHT:
3 lbs., 1.5kg
WARRANTY:
2 years
http://www.theabsolutesound.com/art...rformance-full-featured-liberty-dac-with-mqa/
Mr Spock
- είναι κάτι περισσότερο από dac , αλλά ας μην γεμίζουμε με νέα θέματα . . .
Η ATC ανακοίνωσε την έκδοση mk2 του CDA2.
Το κορυφαίο front end (CD player/DAC/Προενισχυτής) της εταιρίας είναι, πλέον, διαθέσιμο στην έκδοση mk2, με ανασχεδιασμό πολλών από τα μέρη που το απαρτίζουν, νέο κορυφαίο ολοκληρωμένο μετατροπής d/a, δυνατότητα χειρισμού streams υψηλής ανάλυσης μέσω USB, νέο transport και νέα αναλογικά στάδια. Στην πραγματικότητα, η ATC δεν άφησε και πολλά πράγματα χωρίς να τα αλλάξει ή να τα βελτιώσει και η σχετική λίστα είναι μεγάλη σε μήκος.
Ίσως η σημαντικότερη αλλαγή να αφορά το ψηφιακό μέρος του CDA 2, το οποίο περιλαμβάνει θύρα USB μέσω της οποίας μπορεί να πραγματοποιηθεί streaming μέχρι τα 384kHz (PCM) και επιπέδου DSD256 (DSD). Η θύρα USB συνοδεύεται από συμβατική ομοαξονική και οπτική είσοδο (24/192) και υποστηρίζεται από έναν κορυφαίο μετατροπέα 32-bit της AKΜ. Η εταιρία αναφέρει ότι η καταστολή του jitter είναι “εξαιρετική” και ότι το CDA 2 είναι ιδιαίτερα ανεκτικό σε πηγές μέτριας ποιότητας ή καλώδια μεταφοράς ψηφιακού σήματος με μεγάλο μήκος. Το ψηφιακό πακέτο συμπληρώνει ένα νέος μηχανισμός ανάγνωσης οπτικών δίσκων ο οποίος προέρχεται από την Teac.
Η ATC δεν έχει αφήσει ήσυχο ούτε το αναλογικό μέρος της συσκευής. Εδώ, υπάρχει αναβάθμιση τόσο στην τροφοδοσία (με εννέα σταθεροποιημένα τροφοδοτικά) όσο και στο ίδιο το κύκλωμα. Οι Βρετανοί παρέμειναν πιστοί στις αρχές τους και χρησιμοποιούν οκτώ συνολικά βαθμίδες τελεστικών ενισχυτών (υλοποιημένους με διακριτούς ημιαγωγούς), δύο από τις οποίες παίζουν τον ρόλο του απομονωτή και τέσσερις (δύο ανά κανάλι) τον ρόλο του σταδίου εξόδου, σε balanced αρχιτεκτονική, με τελικό στάδιο σε τάξη Α και τοπολογία Sziklai. Οι balanced έξοδοι, στην περίπτωση του CDA 2 Μκ2 έχουν ιδιαίτερο νόημα καθώς η συσκευή είναι σχεδιασμένη με το μυαλό στα ενεργά ηχεία της εταιρίας ή, για όσους θα ήθελαν μια περισσότερο συμβατική λύση, τον τελικό ενισχυτή P2 (εννοείται, βεβαίως, ότι το CDA 2 μπορεί να χρησιμοποιηθεί και σε άλλα συστήματα, χωρίς πρόβλημα).
Όσοι χρησιμοποιούν αναλογικές πηγές, έχουν στην διάθεσή τους δύο εισόδους στάθμης line στην πίσω πλευρά και μια βοηθητική είσοδο με βύσμα TRS 3.5mm στην πρόσοψη. H βοηθητική είσοδος έχει αυξημένη ευαισθησία, ώστε να αξιοποιεί καλύτερα σήματα από συσκευές όπως είναι τα smartphones και τα tablets. Αναβαθμισμένος είναι, τέλος, και ο ενισχυτής ακουστικών του CDA 2, ο οποίος μπορεί να οδηγήσει ακουστικά με ονομαστική αντίσταση από 30Ω μέχρι 600Ω, μέσω ενός συμβατικού βύσματος TRS 6.4mm.
Τις λιγότερες αλλαγές, τελικώς, τις έχει υποστεί το σασί του CDA 2 mk2. Εδώ, η ATC έχει χρησιμοποιήσει τμήματα από χάλυβα και αλουμίνιο με εσωτερική απόσβεση ώστε να ελαχιστοποιηθούν οι συντονισμοί, ενώ η πρόσοψη είναι κατασκευασμένη από προφίλ αλουμινίου 13 χιλιοστών. Η συσκευή είναι διαθέσιμη στο κλασικό ασημί χρώμα, διαθέτει τηλεχειριστήριο και συνοδεύεται από εγγύηση 6 ετών για τα ηλεκτρονικά μέρη και 2 ετών για τον μηχανισμό ανάγνωσης των δίσκων.
http://avmentor.gr/news/2018/atc_cda2_mk2.htm
Ανοχή στο jitter του σήματος εισόδου. Σήμα: -3dBFS, sample rate 96kHz, είσοδος S/PDIF, ημιτονοειδές jitter 40nS, Fs/192 (πράσινη καμπύλη), 997Hz (κόκκινη), Fs/4 (πορτοκαλί)
http://avmentor.gr/reviews/atc_cda2_0.htm
Akis_G
Αυτό το εχουμε βαλει?
Κουκλί!!
https://www.lessloss.com/echos-end-p-218.html
Echo's End Digital to Analogue Converter
Price (Echo's End Original): $5,342
Price (Echo's End Reference): $19,628
Επ' ευκαιρια, αν υπαρχουν αλλοι 3 ενδιαφερόμενοι, να παρουμε ολοι μαζι αυτό και να κερδίσουμε εκπτωση 10%.
Μπορει να φαινεται μικρο ως ποσοστο, αλλα αντιστοιχει σε μια 318i.
Επισης μπορούμε να τους κανουμε πλακα, αν δεν παραλαβουμε 4 κομματια εντος τριων ημερων, ακυρώνουμε την παραγγελια. Σιγα μην εχουν στοκ!
:lolsign:
Κουκλί!!
View attachment 92468 View attachment 92469 View attachment 92470
:lolsign:
Πουλάνε κι αυτά, να βάλουμε απο μια ντουζίνα;
https://www.lessloss.com/bindbreaker-vibration-control-equipment-foot-p-219.html
Vakis2000
Κλιψ κλαψ
Αρκετές γνώσεις βλέπω στο θέμα.
Ο pro μου έχει ενσωματωμένο dac : https://advance-acoustic.com/en/hifi-elements/preamplifier/18-x-preamp
Σχετικά με ένα dac magic 100 που έχω, δεν βλέπω διαφορές σε ποιότητα. Αν κοιτάξω πχ κάτι σε teac : https://teac.jp/int/product/nt-505/top αξίζει ή πετάω χρήματα?
Σαφως και θα δεις διαφορα μεγαλη.
PPG
Πίπιτζι
Το teac δουλεύει και σαν προ?
Vakis2000
Κλιψ κλαψ
Δεν θα καταργήσω τον pro μου, απλώς θα το συνδέσω μέσω xlr και θα συνδέσω τα διάφορα (htpc και λοιπά) στο teac.
PPG
Πίπιτζι
Όχι ρωτάω αν εχει αυτη την δυνατότητα
[DOUBLEPOST=1521657202][/DOUBLEPOST]
Ναι εγω εχω το ud-503 και το εχω σαν προ.
:thumbsup: το αποτέλεσμα καλό?
Aπροσμενα καλο μπορω να πω.
Εχω συνδεσει επανω στο τεακ το htpc-usb,tv-optical,cd-coaxial,
line in-πικαπ η tuner.;)
Mr Spock
New Launches for Linn's Acclaimed Katalyst DAC Architecture
The following is a press release issued by Linn.
22nd March 2018 - This week sees the launch of Linn’s all-new Akurate range with the addition of Katalyst DAC Architecture to Akurate DS, Akurate DSM and Akurate Exaktbox, bringing a new level of performance to the range.
Katalyst, Linn’s 4th generation digital-to-analogue conversion technology, delivers enhanced processing power and an unprecedented level of precision at the critical point where the digital signal is converted into sound, delivering a deeper insight into music.
. . . How does Katalyst improve on previous Linn DAC designs?
Five key aspects have been improved utilising Linn’s deep understanding of the entire digital-to-analogue process, including:
Reference Level
Now completely isolated from noise to produce a high-stability input Reference Level that generates the signal’s amplitude without variation.
Independent Power Supplies
Independent, isolated power supplies are tailored for each process, so feedback from one process cannot influence the performance of another, resulting in far lower distortion.
Data Optimisation
Linn-designed data optimisation stage that prepares the digital signal for conversion with greater accuracy, minimising errors right at the start of the process.
Master Clock
A single high precision clock with its own independent power supply ensures greater timing accuracy throughout.
Output Driver
The new ultra-low distortion analogue output driver prepares the delicate analogue signal for transmission out of the device, making it less susceptible to noise and degradation . . .
http://www.theabsolutesound.com/articles/new-launches-for-linns-acclaimed-katalyst-dac-architecture/
Mr Spock
HoloAudio Spring "Kitsuné Tuned Edition" Level 3 D/A processor
The HoloAudio Spring is a member of an interesting but nearly extinct subfamily of D/A converters called R-2R or ladder DACs. Ladder DACs date back to the dawn of digital, and use cascaded voltage dividers consisting of resistors (valued R and 2R) to passively convert pulsing bitstreams to continuous analog voltages . . .
. . . The HoloAudio Spring measures 16.9" wide by 2.2" high by 11.8" deep and weighs 18.75 lbs. Inside its solid case of copper and black-anodized aluminum are two entirely separate, fully balanced converters: a 24-bit, discrete R-2R for PCM, and a discrete resistor network to handle DSD up to DSD512. Both employ designer Jeff Zhu's patented "linear compensation," which is not clearly described on KitsunéHiFi's website but which I imagine is a second (parallel) resistor ladder. According to Zhu (footnote 1), this "will accurately compensate the resistor tolerance." Regarding the Spring's unique ability to handle native DSD with a discrete resistor-ladder DAC, "The DSD module of Spring does not use R2R architecture for the DSD, more specifically it uses a very specific architecture which is optimized to perform DSD to analog." Both modules employ a "paired transistor" op-amp input stage and an output stage employing direct-coupled bipolar junction transistors . . .
. . . The maximum output level at 1kHz in the Spring's NOS, OS, and OS PCM modes was 4.95V from the balanced outputs and 2.475V from the unbalanced outputs, the latter 1.85dB higher than the CD standard's 2V. However, the output levels dropped by 6dB when I switched the Spring to DSD mode. All outputs preserved absolute polarity. (The XLR jacks are wired with pin 2 hot.) The unbalanced output impedance was close to the specified 200 ohms, at 218 ohms across the audioband. The balanced output impedance was twice that value, as expected . . .
. . . HoloAudio's Spring DAC offers mainly excellent measured performance. While some more questionable aspects of that performance are related to the NOS mode's lack of a conventional digital filter, the oversampling modes behave much better on those specific tests. But there's something funky in the Spring's rejection of word-clock jitter, particularly in the left channel . . .
https://www.stereophile.com/content/holoaudio-spring-kitsuné-tuned-edition-level-3-da-processor
Manosahead
