Analog News
Mr Spock
demokratischer - sektor
Merrill-Williams Audio Announces The R.E.A.L. 101.3 Turntable
Michael Fremer | Feb 20, 2018
Merrill-Williams Audio LLC of Memphis, Tennesseejust introduced the latest version of its celebrated R.E.A.L. turntable, the model 101.3. The R.E.A.L. 101.3 retains the essential elements of the 101 and 101.2 models while adding fundamental improvements.
. . . The plinth consists of rubber elastomer sandwiched with phenolic (hence Rubber Elastomer Acoustic Laminate). All sources of vibration (motor, platter, bearing, and tonearm) are attached only to the elastomer, and each is isolated from the others in such a way that none is allowed to transmit vibration through the laminate. . . .
Also retained are the 101.2's microprocessor-controlled motor drive with built-in speed strobe, its energy-rejecting elastomer feet, and its sophisticated record-clamping system, which consists of a center weight (also energy-rejecting) and periphery ring. The design of the R.E.A.L. turntable is the recipient of one of only two U.S. patents granted to a turntable (#8,406,122 B2), and the first since 1958. . .
https://www.analogplanet.com/content/merrill-williams-audio-announces-real-1013-turntable
ENERGYMANAGEMENT DESIGN
  1. Rubber cork compound mat
  2. Damped center weight
  3. 3/4” polished stainless steel high stability spindle
  4. Quick change tone arm mounting platform
  5. Damped periphery clamping ring
  6. Polyoxymethylene platter
  7. Inverted adjustable hemispheric feet
  8. Elastomer suspended MDS impregnated high viscosity oil well bearing
  9. R.ubber E.lastomer A.coustic L.aminate
  10. Adjustable dual oscillator (sign/cosign) crystal time base motor drive system. Accuracy within 2 parts per million.
  11. Elastomer suspended, fluid damped, custom manufactured, synchronous motor
  12. Acoustic Isolation Valleys
  13. Level
  14. Built in speed strobe utilizing a short pulse, crystal controlled, square wave generator+
http://realturntable.com/product-overview.html
Mr Spock
- δεν αφορά κάτι νέο , αλλά τα 100 χρόνια ενός βαρυσήμαντου brand name . . .
1918 9th of October: the Electrical Phono Film Company is founded by Axel Petersen (1887-1971) and Arnold Poulsen (1889-1952) with the objective of developing one of the world’s first synchronized sound film system.
- και μόνον με αυτή την κεφαλή , θα μπορούσε να βιοπορήσει
- κούνησε και εξακολουθεί να δονεί αρκετά μαγαζιά και μερακλίδικα σπίτια
Timeline - Ortofon
Anniversary products - Ortofon
Mr Spock
Phono Loco Coming From Sutherland Engineering
Michael Fremer | Mar 2, 2018
. . . As with a few others on the market the Phono Loco requires a balanced signal from the cartridge and an XLR terminated phono cable. Now, cartridges are inherently "balanced", with no reference to ground but some tone arm manufacturers, Rega for one, ties ground to the RCA plug's outer ring so an RCA to XLR adapter will not work but others that separate ground (SME's DIN connector among others) can be used with an adapter and Sutherland supplies one but only for use until you can get a replacement cable or have your arm re-wired if necessary . . .
https://www.analogplanet.com/content/phono-loco-coming-sutherland-engineering
Mr Spock
McIntosh Announces MT2 Precision Turntable
The following is a press release issued by McIntosh.
Binghamton, NY | March 8, 2018 McIntosh, the global leader in prestigious home entertainment and ultimate-quality audio for over 65 years, is proud to announce the MT2 Precision Turntable.
. . . The MT2 plays both 33-1/3 and 45 rpm records and is virtually ready to use out of the box as tracking force, anti-skate force, cartridge overhang and arm height are all preset from the factory for maximum performance. The remaining setup steps are simple, allowing the user to be enjoying their vinyl in no time . . .
http://www.theabsolutesound.com/articles/mcintosh-announces-mt2-precision-turntable/
https://www.mcintoshlabs.com/products/turntables/MT2
NEW!!! McIntosh MT2 Precision Turntable... Spectacular!
φουτούρα.
Ο Gregory Porter δεν κολλάει βέβαια με τα πράσινα φωτάκια αλλά έστω.
Mr Spock
- ο αιρετικός κατασκευαστής με τις ''περίεργες'' καμπύλες απόκρισης ( στα ηχεία του τουλάχιστον ) , εδώ σε μία διασκευή . . .
Zu DL-103 Mk.II phono cartridge
. . . Zu Audio's Zu/DL-103 Mk.II ($459), which aims to enhance further still the performance of the original Denon and the first Zu mod. It does this in a couple of ways: For the new Zu, the company's precision-machined aircraft-aluminum body has been reshaped in a manner claimed to further prevent unwanted resonances, and at the same time to ensure even better contact with the motor within. (A side benefit of the new shape: the stylus guard supplied with the stock Denon cartridge fits it to a T, whereas Zu's previous cartridge body did not.) The Mk.II's body is also hard-anodized in a manner similar to many tonearm headshells in common use: Zu suggests that this can help avoid mechanical impedance reflections and mismatches between tonearm and cartridge. Finally, the high-metal-content epoxy used to bond Denon's motor to Zu's body is more advanced than that used for the first Zu/DL-103
. . . The distinctions I did hear between MusiKraft's and Zu's takes on the DL-103 formula were slight, and became apparent only after I made an effort to listen for such things—all the while, the very musical Denon, in both of its borrowed bodies, just wanted to hold my attention with momentum and clarity of line and touch and tone. And I pretty much went along with it. Yes, I do think the MusiKraft was more capable of sounding taut, the Zu of sounding colorful. From there, it was a bit of a toss-up: both were brilliantly well crafted and solidly recommendable . . .
https://www.stereophile.com/content/listening-184-zu-dl-103-mkii-phono-cartridge
https://www.zuaudio.com/turntable/zudl-103
. . . εδώ θα τονίσω πως γενικά όλες οι grado διαβάζουν και αναπαράγουν καλύτερα στο κατώτατο όριο προτεινόμενου βάρους ανάγνωσης δηλ 1,5g και με αρνητικό vta . . . πολλοί αντ΄ αυτού βάζουν 1,8g και 0 vta φέρνοντας ( μπακαλίστικα ) το vta στην σωστή του θέση ( μιάς και είναι αρκετά ενδοτικές ) , αλλά με λάθος βάρος ανάγνωσης
Θα διαφωνησω, Προσωπκα (στο δικο μου συστημα) ΟΛΕΣ οι Grado (από την Black μεχρι και τη Statement) "παιζουν" καλυτερα στα 1,7 ~ 1,8 γραμμαρια και με VTA αν όχι καθετα τοτε 1~2 μοιρες πισω.
Mr Spock
Ναι πιθανόν, ο κατασκευαστής όμως προτείνει στο manual 1,5 & 1 με 2 μοίρες αρνητικό vta
Ίσως στο σύστημα σου έρχεται η τονικότητα καλύτερα όπως την έχεις ρυθμίσει
Mr Spock
Jico Ιαπωνική κεφαλή
Εκεί στην Ιαπωνία, στην χώρα των μηχανών ακριβείας, υπάρχει ένας κατασκευαστής κεφαλών με την ονομασία Jico. Ανάμεσα στην γκάμα που έχει, ξεχωρίζει η νέα κεφαλή Seto Hori που είναι κινητού πηνίου MC υψηλής εξόδου 2mV.
To κέλυφος από φυσικό ξύλο και υπάρχει διακόσμηση, κάτι σαν καρέ -πολυεδρικό- υλικό που προέρχεται από πολυετή ερευνά και ονομάζεται δε Setο. Αυτό είναι χυτό υψηλού συντελεστή συρρίκνωσης και η διάρκεια ζωής είναι τρεις φορές περισσότερο από μια συνηθισμένη κεφαλή. Στην στην άκρη έχει διαμάντι micro ridge και το στέλεχος είναι από ορυκτό βόριο.
Το συνολικό βάρος της κεφαλής είναι 19 γραμμάρια.
http://www.hxoseikona.gr/nea/6250-jico.html
Το ρυθμησα με ακουστικα οποτε με καθε αλλαγη η διαφορα ηταν αμεσα αισθητη!
Mr Spock
Is HD Vinyl In Your Record Playing Future?
REBEAT CEO Günter Loibl has a plan to change the way vinyl records are mastered.
If what he is planning actually comes to pass, records could be "one step" mastered on a ceramic disc that could possibly press 10,000 records before it begins to wear. Watch the interview AnalogPlanet editor Michael Fremer conducted this week with Loibl in the Vienna offices of Pro-Ject CEO Heinz Lichtenegger.
Is "HD Vinyl" In Your Record Playing Future?
https://www.analogplanet.com/content/hd-vinyl-your-record-playing-future
Mr Spock
Perfect Vinyl Forever Record Cleaning Service
For those vinyl music listeners who don’t enjoy cleaning records or just want someone else to do a better job, there is Perfect Vinyl Forever. The service costs $5 (Ultra Deep Process) or $8 (Archival Process) per record for cleaning. Briefly, the difference involves additional steps with enzymatic soaking and vacuum extraction for dirty and/or used records with the archival process. Both processes involve ultrasonic deep cleaning, ultrasonic rinse, HEPA-filtered warm-air drying, and a static-free inner sleeve. There are drop-off points in certain locations around the country. The company also has prepaid and prepackaged shipping boxes (available for a fee) that are sent to your home; records can be carefully and safely placed in the application-specific packaging and mailed out for cleaning. The items are returned cleaned and ready to store or play
http://www.theabsolutesound.com/articles/2018-axpona-show-report-analog-sources/
https://www.perfectvinylforever.com/
Mr Spock
Audio-Technica & Arché . . .
. . . The AT-ART1000's base is machined from titanium and the rest of its body from aluminum, topped with a plastic piece claimed to confer a degree of damping. Despite having coils that lack iron cores, the A-T's output is a low but not crazy-low 0.2mV. Its coil resistance is 3 ohms, its compliance a lowish 12x10–6 cm/dyne, and its stylus is ground with a line-contact profile. Its well-designed clear-plastic stylus guard protects all of the cartridge's fragile moving parts, yet can remain snugly in place as you install or undo the cartridge-mounting bolts. The distance between the stylus tip and the line intersecting the cartridge's mounting bolts is 9.5mm, which was once nearly a standard spec . . .
. . . If, under the Audio-Technica's stylus, the Brahms sounded like a different recording, it was surely not a different performance: with its clearer portrayal of playing techniques, of sheer humanness, the A-T assured me that playing encrypted in the groove had evinced no less insight, taste, judgment, and pure physical talent than before. Based on my earlier experience with the Tzar DST, I expected a better sense of touch from the strings, and that I certainly heard. What I hadn't expected was how much better a sense of clarinetist Alfred Boskovsky's breathing and tonguing techniques the A-T now provided. Legato phrases were more so—something as easy to enjoy as to hear . . .
. . . To my way of thinking, and notwithstanding the Arché's high price, that's high praise. To achieve such adjustability and versatility with no sonic penalty is a noteworthy accomplishment, and I enthusiastically recommend the Arché to phonophiles on my side of the great divide.
https://www.stereophile.com/content/listening-185-audio-technica-arché
Mr Spock
SAEC Again Producing Classic Double Knife-Edge Bearing Tone Arm
Michael Fremer | Apr 26, 2018
After a more than 30 year absence SAEC's double knife-edged bearing tone arm is once again in production and will be available through DS Exports, DS Audio's new export division. DS Audio, of course manufactures a line of "optical" cartridges and dedicated phono preamplifiers.
The new SAEC WE-4700 arm is constructed one at a time by skilled technicians. The double knife-edges are manufactured using state-of-the art machining technology with each edge then hand-finished. The press release did not specify effective length or any of the other key specs but those should be available soon. The price in America will be between $8500 and $9500.
https://www.analogplanet.com/content/saec-again-producing-classic-double-knife-edge-bearing-tone-arm
http://www.fonolab.com/service-saec.html
xkaragi
