Timaras
Πρέπει να είναι ίδια.
Tι εννοεις ποσα??? Θα χρειαστει πανω απο 1? Μιλησα χθες στη γυναικα για τα 4 ηχεια οροφης (πιο πολυ σε φαση αστειου το ειπα) και ειχα γκρινιες..τα phantom 80 ειναι οτι πρεπει. Τεσσερα ιδια εννοειται. Για σαμπ θα το συζητήσουμε εκτενέστερα ποσα θες και γιατι σε αλλη φαση.
Αντε να τα εξηγησεις αυτα στον γυψοσανιδά!!!Mounting considerations If the chosen overhead speakers have a wide dispersion pattern (approximately 45 degrees from the acoustical reference axis over the audio band from 100 Hz to 10 kHz or wider), then speakers may be mounted facing directly downward. For speakers with narrower dispersion patterns, those with aimable or angled elements should be angled toward the primary listening position. The overhead speakers should be at a height (shown as H3 in Figure 2) between two and three times the vertical position of the listener-level speakers. The angle of elevation from the listening position to the left top front/right top front and left top rear/right top rear overhead speakers in a 7.1.4 reference layout should be 45 degrees. This may be adjusted between 30 and 55 degrees if needed, as shown in Figure 2. Figures 3 and 4 show the preferred locations of the four overhead speakers as seen from above. The horizontal width should be about the same as the horizontal separation of left and right speakers placed at ±30 degrees. If this guidance is followed, the overhead side-to-side separation should be 0.5 to 0.7 of the width of the overall layout, depending on the distance to the screen and the front three speakers, relative to the surrounds. It is best to keep the overhead arrangement centered, front to back, over the listening area, even if the front speakers and screen are at a greater distance than the surround speakers.
Οχι, με ενδιαφερει για να ξερω το συνολικο μπατζετ που θα χρειαστει...Ξεκινα οπως ειπαμε και για σαμπ μιλαμε αργοτερα.
Ποσα τ.μ ειναι ο χωρος σου και αν μπορεις βγαλε μια φωτο. Επισης τι μπατζετ εχεις για σαμπ;Οχι, με ενδιαφερει για να ξερω το συνολικο μπατζετ που θα χρειαστει...
Εχουμε και λεμε.
Θα χρειαστω
1 dali zensor vocal (240 euros)
2 ζευγη dali phantom E-80 (416 euros)
1 ζευγος dali zensor 1 (220 euros)
και μας απομενει το κοστος του sub
Ο χωρος ειναι αυτος στη φωτογραφια (κρυβονται λογω 2 μετρα αριστερα απο το αριστερο ηχειο ενω δεξια απο το δεξι ηχειο της φωτογραφιας, ακολουθει -χωρις τοιχο αναμεσα- η κουζινα). Για να οπτικοποιησω καλυτερα το δωματιο, να αναφερω πως η οθονη ειναι 55'.Ποσα τ.μ ειναι ο χωρος σου και αν μπορεις βγαλε μια φωτο. Επισης τι μπατζετ εχεις για σαμπ;
Το δωματιο ακροασης ειναι 20τμ αλλα ενωνεται απο δεξια με την κουζινα η οποια ειναι 25 τμ μονη της. Βεβαια δε νομιζω να υπαρξει μεγαλο θεμα αν τα ηχεια μπουν σε καλη θεση.Τι μπατζετ περιπου εχεις και ποσα τμ ειναι συνολικα ο χωρος που ακους.
[DOUBLEPOST=1526238504][/DOUBLEPOST]Γενικα μπορω να σου πω ενα svs pb2000 πιθανοτατα θα ειναι αρκετο οπως βλεπω το χωρο. Αλλα πες μας ακριβως τα τμ και μπατζετ.
Αν σε περνει να δωσεις το χιλιαρικο το pb2000 ειναι κομπλε....Το δωματιο ακροασης ειναι 20τμ αλλα ενωνεται απο δεξια με την κουζινα η οποια ειναι 25 τμ μονη της. Βεβαια δε νομιζω να υπαρξει μεγαλο θεμα αν τα ηχεια μπουν σε καλη θεση.
Δεν ξερω σε τι τιμη παιζουν τα sub αρα δε μπορω να μιλησω για μπατζετ. Αν πω 400 ευρω ειναι λιγα?? Δε ξερω, ειλικρινα.
Αρχικα, οφειλω να σε ευχαριστησω για την διαθεση σου να με βοηθησεις φιλε μου.Αν σε περνει να δωσεις το χιλιαρικο το pb2000 ειναι κομπλε....
Το pb1000. Θα χρειαστεις δυο που ειναι και καλυτερα απο ενα αλλα μπορεις να παρεις το δευτερο αργοτερα.Αρχικα, οφειλω να σε ευχαριστησω για την διαθεση σου να με βοηθησεις φιλε μου.
Η αληθεια ειναι πως ΔΕΝ με παιρνει για ενα τοσο μεγαλο ποσο αν βιαστω να φτιαξω το συστημα συντομα. Αν ομως κανω υπομονη και το χτισω σιγα σιγα τοτε ειναι πιθανο να καταληξω στην λυση του συγκεκριμενου sub.
Επιλογες με λιγοτερα χρηματα υπαρχουν? Γυρω στα 500 δεν βρισκω κατι αξιοπρεπες?
Τοτε θα κανω υπομονη κ θα παω στο ακριβο..Το pb1000. Θα χρειαστεις δυο που ειναι και καλυτερα απο ενα αλλα μπορεις να παρεις το δευτερο αργοτερα.
[DOUBLEPOST=1526240339][/DOUBLEPOST]Το pb1000. Θα χρειαστεις δυο που ειναι και καλυτερα απο ενα αλλα μπορεις να παρεις το δευτερο αργοτερα.
Επισης το presonus temblor t10 στα 350 ευρω αλλα θες δυο σιγουρα....
Η τιμή που βλέπεις στο skroutz είναι τιμή τεμαχίου και όχι ζεύγους!2 ζευγη dali phantom E-80 (416 euros)
Το αφαίρεσα γιατί δεν πρόσεχα. Με είχε η κυρά να βλέπω 5 επεισόδια Alienist στη σειρά.
