Dirac Live
Μάλιστα. Είχα αφήσει τις default ρυθμίσεις στο eq του rew που ήταν 1,8db/octave. Καλού κακού μόλις παραλάβω το minidsp hd θα του βάλω 0,8 db/octave :spiteful:
Όλα λάθος τα παραπάνω. Έπρεπε να μετρήσω όπως είπες όλο το φάσμα γιατί είχα βάλει cross 80
Ναι ρε συ απλά μια δοκιμή έκανα να δω τι παίζει. Ευτυχώς έχουμε και λίγο headroom παραπάνω για λακούβες.... :p
TERMATOGAZI
Bass!
Dirac Live v2.2 Changelog [Latest]
2019-02-26
Added
  • High-contrast themes
    The user can switch between a bright and a dark high-contrast theme in addition to the existing low-contrast theme. The application defaults to one of the high-contrast themes.
  • Manual IP
    The option to manually enter the IP address of a device to connect to has been added.
  • Support for separate and independent recording devices
    Dirac Live now supports using recording devices on the same network in addition to microphones connected to the active device or local computer.
  • Project name in application title bar
    The name of the most recently loaded or saved project is provided in the top area (“title bar”) of the application.
  • Auto-save project
    The program is automatically saved to an autosave file (one file per device) after each measurement and every time a new filter has been calculated.
  • Warning about unsaved changes
    The user is warned if there are changes to measurements or filter design when exiting the program or loading a project, and will have to confirm the action.
  • Load project from command-line
    A project filename can be provided as a command-line argument to be loaded when the corresponding device is selected.
Changed
  • Better fit for localised texts
    The interface will adjust to accommodate the length of localised texts for improved readability and presentation.
  • Loud volume timeout indicator
    The safety lock for the loud playback master volume slider in the volume calibration step now has a visual indicator showing time remaining until the slider is re-locked.
  • Visibly interactive channel groups
    The interactivity of the channel groups in filter design has been made more discoverable and visible.
  • Removed the asterisk from recording devices
    The ✱ (asterisk) icon that indicated a default device has been removed from the recording device cards in the select recording device step.
  • Selected success toasts are persistent
    Notifications for successfully measured a position or exporting a filter will not time out and must be manually dismissed.
Fixed
  • Improved the descriptions of some confusing error messages (issue 142)
  • Fixed crash when disconnected from network (issue 166)
  • Fixed crash when attempting to load a target curve from a .txt file that did not contain target curve data (issue 228)
  • Fixed that the impulse and magnitude responses were not visible after a position is re-measured (issue 243)
  • Fixed that some texts did not fit inside their widget areas at larger text sizes (issue 254)
  • Fixed a ski-jump ramp behaviour in the target curve close to the high frequency curtain (issue 260)
  • Clarified the sample rate information (issue 274)
  • Fixed that microphones connected through a USB dongle on a Mac computer were not detected as recording endpoints (issue 279)
  • Fixed incorrect message that the microphone had been disconnected (issue 282)
  • Fixed problems when logging in to account when already in an anonymous session using an Arcam device (issue 287)
  • Fixed that the log-in page became locked when there was an error during an attempted log-in (issue 294)
  • Fixed a startup crash on Mac when CoreAudio reported zero input and output channels (issue 302)
  • Relaxed screening restrictions to allows devices with an empty friendly name field (issue 324)
  • Fixed crash bug when exporting filters to Arcam or NAD 758 devices (issue 370)
2019-02-26
Added
  • Manual IP
  • Auto-save project
Changed
Fixed
εσένα τώρα...τι σε κόφτει για το dirac δεν κατάλαβα...:lolsign:
Συσκευές με Dirac οι οποίες κυκλοφορούν στην αγορά, αναβαθμίζονται με την καινούρια έκδοση του Dirac;
TERMATOGAZI
Bass!
ARCAM, AudioControl, Lexicon, NAD και StormAudio και ξεκινησαν στην minidsp απο καποια μικρα μοντελα
[DOUBLEPOST=1551262870][/DOUBLEPOST]mini dsp DDRC-24/22 series ως beta νομιζω προς το παρον και θα το βαλουν και στα υπολοιπα μοντελα τους
Η σκέψη μου πήγε στο SHD και στο SHD Studio της miniDSP.
AudioControl
Αχ, σήμερα τα έχετε όλα έτοιμα στο πιάτο και γκρινιάζετε. :p
Στις αρχές και τα μέσα των '90s, για να πάρω μια ιδέα αξιοπρεπούς ισοστάθμισης δανειζόμουν (για ένα βράδυ κάθε φορά) ένα πανάκριβο AudioControl real time spectrum analyzer απο μια εταιρεία (δεν θυμάμαι ποιά*, αλλά μου έκαναν μεγάλη τιμή που μου το εμπιστεύονταν :hi: ), το τάιζα pink noise και πάλευα με το eq των AV και την τοποθέτηση του (ενός φυσικά) 10" sub. :rolleyes::(
*Ίσως η TEMET;
Στις αρχές και τα μέσα των '90s, για να πάρω μια ιδέα αξιοπρεπούς ισοστάθμισης δανειζόμουν (για ένα βράδυ κάθε φορά) ένα πανάκριβο AudioControl real time spectrum analyzer απο μια εταιρεία (δεν θυμάμαι ποιά, αλλά μου έκαναν μεγάλη τιμή που μου το εμπιστεύονταν :hi: ), το τάιζα pink noise και πάλευα με το eq των AV και την τοποθέτηση του (ενός φυσικά) 10" sub. :rolleyes::(
α ρε ψυχουλίτσα τι τραβούσες και συ...:roflmao:
Nαι αλλά για την εποχή ήσουν αρχηγόπουλο.....
Ποιά ξένα σπίτια ρε παπαρίδη; :p
δεν είχες πει ότι πολύ παλιά πήγαινες και σε φίλους και τους τα έστηνες τα σαπάκια?
  • Like
Reactions: PPG
Manosmathiou
