Τι θυμήθηκα τώρα
Mr Spock
demokratischer - sektor
Το ιστορικό κατάστημα ρούχων στην Πλάκα υπήρξε συνώνυμο του πανκ στην Ελλάδα και η δεύτερη αθηναϊκή στάση μετά την Ακρόπολη, ροκ σταρ όπως η Debbie Harry, ο Bruce Dickinson και η Kim Gordon.
- το πρόλαβα στην Πλάκα & μετά στο Κολωνάκι . . . αγόραζα κρυφά από τους γονείς μου ρούχα και τα καβάτζωνα στην ντουλάπα της αδελφής μου ( ταίριαζαν οπτικά καλύτερα :gotcha: ) . . . έχω ακόμη 2 δερμάτινα μπουφάν 1 παντελόνι & ένα ζευγάρι γυαλιά . . .
. . . που τους άλλαξα φακούς φυσικά
Mr Spock
- μου άρεσε να ξεκινήσω το εν λόγω νήμα με το ομότιτλο κατάστημα , αλλά εδώ ποστάρουμε ότι θυμηθήκαμε ξαφνικά από το πουθενά
Mr Spock
Theta Digital Cobalt 307 digital processor
This is his statement to the world of what he can accomplish—a kind of "personal best" that defines the upper limits of his talent. Because he knows of no way to make the product better, the component stands as the ultimate testimonial to his skill.
The Burr-Brown PCM67 DAC is an 18-bit, dual-channel hybrid unit that combines a multi-bit ladder DAC on the upper ten bits and a 1-bit type converter on the lower eight bits. This is the same DAC used successfully in the Sumo Theorem converter .The 307 DAC uses the highest-grade "K" version of the PCM67
From the start, it was apparent that the Cobalt had a good overall tonal balance and a big, gutsy, powerful quality not previously heard at this price level. The Cobalt's bass was particularly impressive. There was a generous feeling of weight and heft, giving the music warmth, power, and drive. Bass guitar lines were well resolved, and the instrument was portrayed with a full "purring" quality. Similarly, acoustic bass had a round, meaty quality that provided a good tonal foundation for music. By contrast, the Sumo Theorem had a lighter, less robust presentation. Bass lines hinted at by the Theorem were fully fleshed out through the Cobalt. The Theorem tended to make the presentation somewhat thin and lean; the Cobalt imbued music with a sense of power and weight.
Theta Cobalt 307, CD frequency response at –12dBFS into 100k ohms, with de-emphasis (bottom) and without (top). (Right channel dashed, 0.5dB/vertical div.)
Theta Cobalt 307, 1/3-octave spectrum of dithered 1kHz tone at –90dBFS, with noise and spuriae, 16-bit data (right channel dashed.)
Description: Digital/analog converter with 8x-oversampling digital filter and 18-bit hybrid DAC. Frequency range: 0.05Hz–20kHz (no tolerance given). Filter math resolution: 45 bits. S/N ratio: 108dB. Resolution: 18 bits. Linearity: 18 bits. THD at full output: 0.002%. Inputs: one coaxial on RCA jack, one optical on Toslink jack. Digital output: One coaxial on RCA jack. Analog output: unbalanced on RCA jacks. Output level: 2V RMS.
Dimensions: 9.5" (W) by 2" (H) by 6.625" (D). Weight: 5 lb.
https://www.stereophile.com/content/theta-digital-cobalt-307-digital-processor#5xkHsTZdhPIQwu07.99
Mr Spock
ΚΑΤΑΠΛΗΚΤΙΚΟ ΤΟ ΣΚΙΤΣΟ ΤΟΥ ΜΗΤΡΟΠΟΥΛΟΥ.
ΤΟ ΚΛΑΣΙΚΟ ΨΥΓΕΙΟ ΤΗΣ ΙΖΟΛΑ ΜΕ ΤΗΝ ΤΕΤΡΑΓΩΝΗ ΠΕΤΟΥΓΙΑ ΤΟ
ΕΧΟΥΜΕ ΑΚΟΜΑ ΣΕ ΑΠΟΘΗΚΗ ΣΤΟ ΕΞΟΧΙΚΟ!
Post automatically merged:
ΕΧΕΙ ΠΑΙΞΕΙ ΚΑΙ ΣΕ ΑΡΚΕΤΕΣ ΕΛΛΗΝΙΚΕΣ ΤΑΙΝΙΕΣ....
roberto_portale
