Aku Audio Ichor - Active midfield monitor: Made in Greece
Aku Audio Ichor......active midfield monitor ....MADE IN GREECE
Τρέμετε Kii..s
Technical Specifications
  • null
    System
    – Active 2-way, 2 chamber monitor with cast-aluminum proprietary body construction. Amplitude & time aligned. Ribbed, nonplanar internal surfaces.
    – Minimal Vibration two material design.
  • null
    Driver Composition
    – Mid-Bass section: Ichor boasts one 8″ carbon-paper, high-precision woofer.
    Ichor EB adds two 10” aluminum passive radiators.
    – Treble section: one 1,34″ aluminum-magnesium dome, neo motor high-excursion tweeter with high power handling, low distortion & cross capability.
  • null
    Frequency
    Response
    – Ichor: -29Hz – 25000Hz @ +-2dB
    – Ichor EB: -18Hz – 25000Hz @ +-2dB
  • null
    SPL
    – Ichor: 110dB
    – Ichor EB: 113dB
  • null
    Stand
    – Wooden Stand with Amplifier Compartment Embedded.
    – Felt lining to reduce friction and vibration. Min.+- 20deg. Vertical tilt adjustment.
  • null
    Amplification /DSP
    – One custom AKu-Hypex Ncore 2channel amplifier with DSP plus Digital and Analog I/O
    – Three DSP presets (Maximally Flat, Bass Contour, Party Mode)
    – Mid-Bass: 250Watt
    – Treble: 100Watt
    – Frequency Response: 10Hz-50KHz
    – SNR: 118dB
    – Distortion (THD+N): 0.006% @ half power
    – Global Mains Voltage compatibility (100-240VAC)
    – Efficiency: 92%
    – Max Power Consumption: 350W
    – Power Connector: 3-pin IEC 250Vac, 10A male
    – Neutrik XLR balanced inputs for Analog & AES
    – Hypex Gold RCA unbalanced input for Analog & S/PDIF
    – Optical – Toslink input (up to 96KHz)
    *use of a digital or analog preamp before the amp is advisable.
  • null
    Dimensions
    – Loudspeaker
    H:560mm W:335mm D:510mm
    H:22.04in W:13.18in D:20.07in
  • null
    Weight
    – Ichor: 25kg / 55,10lb each
    – Ichor EB: 27kg / 59,40lb each
Μπες στο θέμα της έκθεσης που έγινε και το είχαμε γράψει, δε θυμάμαι απέξω.
Rosinante
Dark Nιάου
Ντροπη βρε να ρωτατε τιμη σε ελληνικο προιον και μαλιστα με ονομασια ΙΧΩΡ, δηλαδη με αρχαιοελληνικας καταβολας. Τσαμπα θα παρετε το αρχαιο πμευμα αθανατο;:):)
Επειδή υποψιάζομαι το κόστος αυτών θα κάνω μια ερώτηση.
Καλό το design ,καλό το made in greece, αλλά να αγοράσω από μια εταιρεία που δεν αναγράφει ούτε την διεύθυνση τις έδρας της?
Με το after sales τι συμβαίνει.
Αν αύριο μεθαύριο ψάχνω τον κατασκευαστή γιατί βαρέθηκε,κουράστηκε,έκλεισε κλπ.
Σε αυτό το κόστος δεν πάω σε ένα τεράστιο genelec ,adam κλπ που θα έχω το κεφάλι μου ήσυχο από τέτοιες δυσάρεστες αλλά και συχνές εκπλήξεις?
Και μάλλον θα μου μείνουν και ρέστα για καλώδια ρεύματος!!
Έτσι στα γρήγορα στο 1/3 τις τιμής το ζευγάρι.
15" με 500w στα μούτρα και 60 κιλά αντριλα.
Μα επιτέλους ποια είναι η Ρόζι; Μπάσκετ παίζει;
  • Haha
Reactions: PMC
I
iason
Ωραία τα λές ,αλλα εμενα μου θυμιζουν λιγο τα Harbeth :sneaky:
AC/DC Ακούς :rolleyes:
Εχουμε εγγύηση οτι η Genelec δεν θα κλείσει ???:spiteful:
Όχι δεν ακουω. Μην μου πεις ότι είναι groupie ac dc!!! Η μήπως είναι ηλεκτρολόγος ;
Ο νόμος των πιθανοτήτων λέει να κοιμάμαι σίγουρος ότι δεν θα κλείσει.
Και αν κλείσει θα φροντίσει τους πελάτες της με after sales.
bmavroeidis
