Aku Audio Ichor......active midfield monitor ....MADE IN GREECE
Τρέμετε Kii..s
Technical Specifications
Τρέμετε Kii..s
System
– Active 2-way, 2 chamber monitor with cast-aluminum proprietary body construction. Amplitude & time aligned. Ribbed, nonplanar internal surfaces.
– Minimal Vibration two material design. -
Driver Composition
– Mid-Bass section: Ichor boasts one 8″ carbon-paper, high-precision woofer.
Ichor EB adds two 10” aluminum passive radiators.
– Treble section: one 1,34″ aluminum-magnesium dome, neo motor high-excursion tweeter with high power handling, low distortion & cross capability.
Frequency
Response
– Ichor: -29Hz – 25000Hz @ +-2dB
– Ichor EB: -18Hz – 25000Hz @ +-2dB -
SPL
– Ichor: 110dB
– Ichor EB: 113dB -
Stand
– Wooden Stand with Amplifier Compartment Embedded.
– Felt lining to reduce friction and vibration. Min.+- 20deg. Vertical tilt adjustment.
Amplification /DSP
– One custom AKu-Hypex Ncore 2channel amplifier with DSP plus Digital and Analog I/O
– Three DSP presets (Maximally Flat, Bass Contour, Party Mode)
– Mid-Bass: 250Watt
– Treble: 100Watt
– Frequency Response: 10Hz-50KHz
– SNR: 118dB
– Distortion (THD+N): 0.006% @ half power
– Global Mains Voltage compatibility (100-240VAC)
– Efficiency: 92%
– Max Power Consumption: 350W
– Power Connector: 3-pin IEC 250Vac, 10A male
– Neutrik XLR balanced inputs for Analog & AES
– Hypex Gold RCA unbalanced input for Analog & S/PDIF
– Optical – Toslink input (up to 96KHz)
*use of a digital or analog preamp before the amp is advisable. -
Dimensions
– Loudspeaker
H:560mm W:335mm D:510mm
H:22.04in W:13.18in D:20.07in -
Weight
– Ichor: 25kg / 55,10lb each
– Ichor EB: 27kg / 59,40lb each
