Καλώδια και θύματα
και ερχετε τωρα η jbl και λεει .....
τι λεει ;
Speaker wire and interconnect cables are important com-
ponents in an audio system. With all other factors at an
appropriate level of quality the speaker cable and the
interconnect cable can make significant contributions to
the perceived sound quality. Careful selection of cable
and interconnect can add or subtract marked shadings in
the tonal character. Likewise, different cables can have
quite a dramatic impact on the dynamic contrasts experi-
enced by listeners.
Λέει και αυτά αν κατεβάσεις το manual https://www.jblsynthesis.com/produc...tml?dwvar_DD65000-_color=Cherry-Japan-Current
Speaker wire and interconnecting cables are an important
component in any audio system. With a system like Project
Everest, they assume an increased level of importance.
Project Everest loudspeakers are internally wired using high-
quality oxygen-free copper wiring. The same care that was
given to the selection of the loudspeakers’ internal system wiring
should be afforded to the selection and application of the wires
that will connect the Project Everest loudspeakers to your other
system components.
Many manufacturers produce audiophile speaker wire worth
considering for Project Everest loudspeakers. As with all electronics
and associated components, however, every manufacturer
offers products of varying quality to suit a range of budgets and
applications. We advise that you use high-quality wire and to
select the highest grade of wire available from the manufacturer.
Project Everest specialist dealers have the experience and
knowledge to recommend suitable speaker wire to best
complement your particular system. We recommend using an
audiophile-quality speaker wire of not less than 16-gauge for
connections of up to 15 feet (5 meters) as a minimum requirement.
For maximum signal purity, we advise that you place the
amplifier(s) as close as possible to the loudspeakers, even if
this means that a longer distance will be needed between the
amplifier(s) and preamplifier.
The connections between the left and right amplifiers and
speakers should be the same length. If the distance between one
speaker and its amplifier(s) is greater than the distance between
the other speaker and its amplifier(s), use the longer length of wire
for both connections.
For bi-wire connections, the same type of wires may be used for
both low-frequency and high-frequency sections to reduce wire
effects (resistance, inductance, etc.) and to avoid intermodulation
of low and high frequencies in the wires. Specialized wires for
low-frequency and high-frequency sections may yield excellent
results. Whatever wires you select, be sure that the low-frequency
wires are as short as possible, and that the left and right wires for
each section are the same length.
να ριξουμε στη πυρα το stereo Times!
Όχι βέβαια, είναι ιερό, σα την καιόμενη βάτο, και μάλιστα πρέπει να βγάζεις τις παντόφλες όταν διαβάζεις στέρεο τάιμς:
Ο ΜΩΥΣΗΣ είχε φτάσει στο βουνό Χωρήβ για να βρει χορτάρι για τα πρόβατά του. Εκεί είδε έναν θάμνο που είχε πιάσει φωτιά, αλλά δεν καιγόταν!
“Περίεργο”, σκέφτηκε ο Μωυσής. “Θα πάω πιο κοντά να δω καλύτερα”. Όταν πλησίασε, ακούστηκε μια φωνή από το θάμνο που έλεγε: “Μην πλησιάσεις περισσότερο. Βγάλε τα σανδάλια σου, γιατί στέκεσαι σε άγιο έδαφος”.
Τη βγάζεις την παντόφλα;
head-stef
Headphones
Αν υπήρχε η παραμικρή δόση αλήθειας στα παραπάνω, καμία εταιρία καλωδίων δεν θα ρίσκαρε να βγάλει στην αγορά άστρωτη παρτίδα καλωδίων και να χάσει τις εντυπώσεις στην απόδοση (αφού μπορεί να οργανώσει πάμφθηνα το μαζικό "στρώσιμο" με τις εκατοντάδες ή με τις κουλούρες πριν τον τεμαχισμό). Το "στρώσιμο" είναι η απάντηση στην ερώτηση "γιατί δεν ακούω βελτίωση". Και τραγανίζει το χρόνο για να μη μπορεί να γίνει πια επιστροφή προϊόντος (στις μεγάλες αγορές όπου η επιστροφή προϊόντος που δεν ικανοποιεί είναι θεσμός).
Το εμπόριο είναι ...εμπόριο. Χωρίς τεχνάσματα βγαίνεις εκτός αγοράς.
Σταύρος Λαγκαδιανός
Το αγοράκι με τα σπίρτα
stereo Times!
Από λαδάκι άλλο τίποτα το... "καλό περιοδικό" :taunt:
Γεμάτο τέτχια είναι...
Και εδω ενα review για το kinber select ks 1030 http://stereotimes.com/cables022300.shtml το οποιο αναφερει πολλα χρονια πριν για το θεμα του στρωσιματος των καλωδιων,φυσικα ειναι και αυτοι ασχετοι!Απλα μεταφερω το σημειο που εχει σχεση με το θεμα αυτο!
Break-in
Don’t ever expect this cable (or any other cable) to sound decent right out of its packaging. This is easy to say but very hard to accept. The typical human reaction is the desire for immediate satisfaction, especially when you pay $1,200. for each meter pair. They sound far from decent during the first hours of use. I wished very much to go back to my trusty KCAGs and listen to some music. They sounded lean, edgy, without any bass extension, and bright in the treble. But from the first hours they gave me a distinct hint as to their potential, exhibiting a lot of detail, openness and depth. Their sonic character changed from day to day. Sometimes the bass was good, the sound became more bearable, and the next day it would disappear again. Kimber recommends that you simply run dynamic, complex music (big band, full orchestra, etc.) during break-in. They also claim that the majority of the break-in will take place within the first 72 hours, and that near full break-in should be realized after about 200 hours of play. In my case, the majority of the break-in did not take place within the first 72 hours. Unfortunately, it took place when I approached the 200-hour mark.
I find the break-in process (not only for cables but also for all high-end equipment) to be a form of modern day torture for audiophiles. We are the consumers and yet we have to suffer this aurally painful and time-consuming process. The worst part is that you are never sure of what the final sonic results will be. The product could be the best of its kind but it may not work synergistically with your system. If you were to play your system an average of 2 hours per day, every day, it would take 100 days (well over 3 months) to total 200 hours! Of course, you could turn off your power amplifiers and put a CD on infinite repeat while you are elsewhere. However I could only apply this practice during weekends for safety reasons--plus I still wanted to listen to music during the break-in period and this was not fun! I think that manufacturers and dealers should be obligated to provide broken-in samples for home trials or reviewing purposes. It would make our lives as audiophiles much easier.
Listening
After 200 hours of playing, I gradually felt that things were going in the right direction. The body was back on the mids—the tonality became very pleasant and natural, and the bass was present, extended and controlled. I started to like the sound very much and enjoyed listening to music again. Before tackling the serious evaluation process, I let the sound settle for 30 more hours. How do I know these accumulated hours so precisely? Well, my Nuance power amplifiers have LCD hour meters that start to count only when the amps are turned on. I had installed them to provide statistical information about tube life expectancies. OK, enough about break-in hours.
Απαραδεκτος αυτος που τα γραφει ελα Astronaut Jr πες του για μια εκατοστη φορα ακομη για τον φροντισμο του χωρου,το τερματισες λεμε!!!Ελατε και οι υπολοιποι να ριξουμε στη πυρα το stereo Times!
system components.
Ας μιλήσουμε και λίγο ωμά...Σε επίπεδο διαλόγου εντός fora θεωρώ πως δεν απαντούν ουσιαστικές δυσκολίες,αφού τα πάντα μπορούν να εκτυλίσσονται σε εικονικό πεδίο.Επειδή οι πραγματικές δυσκολίες εδρεύουν στην καθημερινότητα ,ας αναλογιστούμε δύο ενδεικτικές περιπτώσεις στην επιχειρηματική πρακτική :
Στην περίπτωση των JBL Everest,πόσο κύρος θα μπορούσε να εδραιώσει μια εταιρεία στη διαμορφωμένη από άλλους φορείς συνείδηση υποψήφιων πελατών της άμα υποστήριζε φόρα παρτίδα ότι τα κορυφαία της προϊόντα δεν θα απαιτούσαν και τόσο αβανταδόρικες καλωδιώσεις για τη μέγιστη ανάδειξη στην απόδοση...Διότι θα είναι ηχειακές υλοποιήσεις με το κύρος των Everest κανονικά εκείνες που θα όριζαν το βεληνεκές των συνδεδεμένων καλωδίων και όχι αντιστρόφως... :sneaky:
Περνάμε τώρα σε μια αντιπαραβολή υπό όρους ST...Αναρωτιέμαι λοιπόν πόσο χλευασμό σε υποψήφιους πελάτες ανά την υφήλιο θα είχε συγκεντρώσει πάνω της όποια εταιρεία λογισμικού θα συνόδευε τα προϊόντα της με επισημάνσεις του στυλ ΄΄μην περιμένετε ν'ακουστεί αξιοπρεπώς μόλις θα έχετε ολοκληρώσει τις ρυθμίσεις χωρίς όμως να έχει στρωθεί για καμιά διακοσαριά και βάλε ώρες΄΄ ,όπως και το άλλο αμίμητο ΄΄το προϊόν μας είναι το καλύτερο στο είδος του,αλλά μην περιμένετε να συνεργήσει ευνοϊκά με οποιοδήποτε setup΄΄...🤡
Της νύχτας τα καμώματα τα βλέπει η μέρα και γελά...Γιατί γνωρίζει πού βρίσκονται οι πραγματικές δυσκολίες.
Αυτό θα ίσχυε αν δεν είχα το καλώδιο. Πες με και βλάκα, πες με και άσχετο. Πουλάω στρωμένο KS1016 του ενός μέτρου, άριστο! Το θες;
@μουςικοφιλος Φυσικά, τα 1016 τα πήρα ολοκαίνουργια, τους έβγαλα εκείνα τα πορτοκαλί διχτάκια απο τα βύσματα και τα απόλαυσα αρκετά ( πρέπει να έχω και σχετική φωτό, θα ψάξω. Ήμουν τόσο χαρούμενος τότε που κατάφερα και τα πήρα που τα φωτογράφιζα σαν να ήταν νέο αυτοκίνητο, ένα πράγμα! )! Καιρός να τα χαρεί και κανένας άλλος! Δεν είμαι παρτάκιας! Ψήσου! Και θα κάνω και καλύτερη τιμή, στα 600€ ( μόνο για τα μέλη του avsite! ). Ψήσου σου λέω, φανταστικό καλώδιο! Μπούρδες δεν έχω μάθει να λέω, το καλώδιο έχει παίξει ελάχιστα σε σχέση με την ηλικία του, καθώς το σύστημα ήταν πακεταρισμένο για πολύ καιρό.
JOHN MARKOU
Münchhausen
Εγω θα τα έπαιρνα άστρωτα για να είχα την μοναδική εμπειρία στρωσίματος καλωδίων και να ζούσα την μεταμόρφωσή τους , όχι του Σωτήρος, με την πάροδο του χρόνου. Να την ζήσω την εμπειρία ρε παιδάκι μου.
Ήταν σε πολυτελές κουτάκι από ξύλο καρυδιάς που περιείχε και βελούδινα γάντια για τη τοποθέτησή τους;;
Αν όχι, τα καλώδια σου είναι για τον ΠΕΟΝΤΑ! :geek:
Είσαι λίγο άσχιετος αγαπητέ τυμβωρύχε. Τα select της Kimber έρχονται στο pelican case τους, το οποίο παρέχω και φυσικά, σε άριστη κατάσταση κι αυτό. Με τον σειριακό αριθμό του καλωδίου, με τα όλα του! Ρίξε μια ματιά στην αγγελία μου και θα καταλάβεις!
JOHN MARKOU
Münchhausen
Δε με λες? το κουτί με τι είδος βερνικιού είναι περασμένο? Είναι υδατοδιαλυτό εμποτισμού ή από τα άλλα τα φτηνά με το νέφτι?
Εγώ δεν ξέρω και λέω ό,τι θέλω. Το καλώδιο όμως είναι το ξακουστό ΚS1016, με το γνήσιο κουτί το δικό του, σε άριστη κατάσταση, το ίδιο καλώδιο που θα πλήρωνε κάποιος αν το έπαιρνε απο αλλού. Καμία παγίδα απολύτως! Απλά, δεν το χρειάζομαι. Ας το πάρει κάποιος και μετά μουτζώστε με όλοι μαζί γι'αυτή μου τη κίνηση! Δεν θα σας κρατήσω κακία! :D
N
nickmitro
Το placebo placebo αλλα τα Mogami και τα Belden εξαιρουνται του placebo,σωστα:;):tongue:
Ισως γιατι τα χρησιμοποιουν αυτοι που επικαλουνται το placebo.;):laugh:
Δεν έχει βερνίκι! Μα, κοίτα κι εσύ την αγγελία μου βρε! Έχω σχετική φωτό!
Πάντα θα χρειαζόμαστε καλώδια για να συνδέσουμε τα μηχανάκια μας. Οπότε, δεν είναι θέμα πλασίμπο. Είναι αναγκαιότητα. Εγώ πάντως, όταν με το καλό πουλήσω τα 1016, θα τσεκάρω λίγο τα σπεκς των μηχανημάτων μου και των καλωδίων που παρέχουν αυτές οι εταιρείες και θα αγοράσω για να φτιάξω xlr interconnects. Τα ρέστα, θα τα φάω σε subs.
nikpapageo
