Σε λιγες μερες ανακοινωνετε το νεο player το Ζ9Χ με το SoC Realtek RTD1619DR.
Κοιτοντας τα specs βλεπω οτι τοποθετειτε λιγο πιο κατω σε χαρακτηριστικα απο το αντιστοιχο Dune HD Pro 4K II αλλα ειναι πιο ενδιαφερον για τους περισσοτερους απο εμας (..και σημαντικα φθηνοτερο!)
Δειτε εδω μεταφραση απο κινεζικα:
Zidoo Z9X media player will receive SoC Realtek RTD1619DR.
SoC Realtek RTD1619DR will be the basis of the upcoming Zidoo Z9X media player.
The device will run on Android 9.0 and OpenWRT.
The amount of DDR4 RAM is 2 GB, and the internal storage will be 16 GB eMMC memory, there will be one SATA 6 Gb / s port on board.
Video output and input correspond to HDMI 2.0a, audio streams are output via HDMI, or S / PDIF, pass-through audio output is supported.
There is also a Gigabit Ethernet port and an 802.11ac / Bluetooth 4.2 Wi-Fi adapter, there are two USB 3.0 ports and two USB 2.0.
Information about the cost and start of sales will be available in the near future.
Technical specifications Zidoo Z9X
Color: Aluminum Gray
Screen: LED
Operating System: Android 9.0
Processor: Realtek RTD1619DR ARM Cortex-A55 (Hexa-core)
RAM: 2GB (DDR4)
Flash memory: 16GB eMMC
Wi-Fi: 802.11 AC, MIMO Dual-Band WIFI
Ethernet: 1 * RJ-45 Ethernet Jack (10/100 / 1000Mbps)
Bluetooth: Bluetooth 4.2
HDMI Out: HDMI 2.0a, support 4K @ 60fps, HDR10, HDR10 +, Dolby Vision
Video decoding: HDR, HDR10 +, Dolby Vision, 10-bit HEVC / H.265 up to 4K @ 60fps, VP9 up to 4K @ 60fps, H.264 up to 4K @ 24fps
Audio Decoding: MP3 / WMA / AAC / WAV / AC3 / DTS / OGG / FLAC / APE / SACD / DFF / DSF / APE etc.
Network Protocol Support: NFS, SMB2
USB: 2 * USB 3.0, 2 * USB 2.0
SATA: 1 * SATA3.0
HDMI: 1xHDMI Out + 1xHDMI In
Other interfaces: 1 * IR Receiver, 1 * Composite video and audio port (Cvbs Out), 1 * SPDIF (2CH, 5.1 CH), 1 * 3.5mm RS232.2 * External High-Gain Antenna
Screen: LED
RAM: 2GB (DDR4)
SATA: 1 * SATA3.0
