wnet
Nearfieldένιος
Adam T5V Review (Studio Monitor)
This is a review and detailed measurements of the Adam T5V Powered Speaker. It was kindly purchased new by a member and drop shipped to me. The T5V costs US $200 each. Much like the rest of Adam speakers, the T5V has a serious look to it: Back panel shows good connectivity and usual...www.audiosciencereview.com
Για 159€; Απίστευτο..
Adam T5V – Thomann Elláda
Adam T5V, Active Nearfield Monitor, Equipped with: 5" woofer and 1.9" U-ART ribbon tweeter, 2x Class-D amplifiers: 50W RMS woofer, 20W RMS tweeter, Frequency range: 45 - 25000 Hz, Crossover frequency: 3 kHz, Maximum...m.thomann.de
" Discovering a budget speaker that exceeds your expectations and produces great sound with almost no faults. No need for, "well you always need a sub." No, a good speaker should not need a sub to sound good. The subwoofer should be augmentation, not filling design deficiency. A bookshelf speaker needs to deliver enough bass to balance the rest of the response and the Adam T5V does that. Ditto for ability to get loud "
Α δε θέλει και sub ή γενικά τα ηχεία δε θέλουν (ούτε καν τα bookshelf) !
Στα πιο σοβαρά και όσον αφορά το συγκεκριμένο... ε, με 400 ευρά (βάζω και ένα ντακάκι) ακούς μουσικούλα που ούτε την ονειρευόσουν πριν κάποια χρόνια σ' αυτό το ποσό...
