Προτάσεις για καλώδιο ηχειων;
Μετρήσεις καλωδίων ηχείων:
LUXMAN
Δες αυτο που χρησιμοποιει τον καλυτερο χαλκο (απο θεμα καθαροτητας και επεξεργασιας/στιλβωματος) και ειναι σε απολυτα λογικη τιμη.
Can a speaker cable sound great, be practical and easy to use, be sexy and be easily affordable? Yes! Q2's inner Long-Grain Copper (LGC) conductor is surrounded by an outer spiral of 11 strands of LGC. The result is AQ's new flexible Solid+ Concentric Conductor, with sound quality even closer to that of an ideal solid conductor and yet big enough to make a great cable with only 2 simple-to-prepare conductors. Then, the 2 conductors (+ and -) are spiraled for minimum inductance (inductance makes sound seem out of focus), and maximum clarity and dynamics...and then this ideal cable is given a sexy, square deep black outer jacket.
Solid+ Concentric Long-Grain Copper Conductors
Solid conductors prevent two very common sources of distortion: imperfect strand-to-strand contacts and magnetic interaction between strands. However, if a conductor as large as in Q2 was a single solid, not only would it be very stiff, but, due to skin effect, it would also have a very unnatural sound—like an aural roller coaster. Q2’s Solid+ Concentric Conductors comprise a perfect circle of 11 smaller strands of LGC copper spiraled around a single larger strand of LGC. The result is a flexible conductor with sound quality approaching that of an ideal solid conductor.
Low-Inductance Twisted-Pair Geometry
A normal speaker cable with parallel conductors has fairly high inductance, smearing energy across time and making the sound dull and unfocused. Two conductors spiraled around one another, provide lower inductance, greater clarity, and superior bass-to-treble frequency extension.
Specifications:
  • Metal: 100% Solid PSC+
  • Gauge: 15 AWG (2,08mm2)
  • Jacket: Black PVC
Πολύ ενδιαφέροντα και τα λινκς στο τέλος του πρώτου λινκ.
Όποιος πραγματικά ενδιαφέρεται, μπορεί να τα διαβάσει.
“If there is no push back during discussions veering into fiction/delusion/snake oil, then I think this would be a sign of failure for a public forum...”
Και
“Nobody wants to be told one is wrong using factual evidence these days, right? Not just audiophilia, but it seems to me that in many areas of public discourse, having "fun", accepting claims of "lived experience" no matter how ridiculous, is more important than education, understanding, and appreciating what is truth.”
Ε, κάποιοι πρέπει να σπαν @ρχιδια με τις ανυπόστατες θεωρίες συνωμοσίας.
Ας μην αρέσει, αυτή είναι η δουλειά στα φορουμς.
Auditorium-23
http://www.auditorium-23.de/Accessories/Cable.html
Γερμανικά, χειροποίητα, σε λογική τιμή.
Τα είχα πάρει από συμφορουμιτη.
Φυσικός, ζεστός ήχος, χωρίς υπερβολές. Έχω ένα ζευγάρι αναπληρωματικό και κάθεται. Αν σ'ενδιαφερει let me know.
N
nickmitro
Κοιταξε για Audioquest Τype 4.Κοστιζει 20 ευρω το ατερματιστο μετρο, φυσικα υστερα απο δοκιμη.
ειμαι οκ η να παω σε κατι
Δε ξέρω αν είσαι οκ, ιερογλυφικά δε διαβαζω κι ούτε θέλω να μάθω τι είναι (πχ. qed xt25).
Για να είσαι οκ, χρειάζεται να τηρούνται απλοί κανόνες, απλές βασικές αρχές:
1. Έως 100 w ενισχυτή, 2*1mm καλώδιο
2. 100-250 w, 2*1,5mm
3. 250-500w, 2*2mm
4. 500-1kw, 2*2,5mm
5. 1-2kw, 2*4mm
6. 2-4kw, 2*6mm
Το τελευταίο, είναι για τον τερματογκαζι.
Μη γελάτε, αυτό χρειάζεται.
Αν θέλετε να είστε υπερβολικά οκ, πάρτε μια διάσταση πιο χοντρό καλώδιο από όση προτείνω.
Αν είστε απλοί άνθρωποι, χωρίς μανιες Χάι Ενδ, πάρτε καλώδια ηχείων φτηνά από Κάφκα, με τη διάμετρο που χρειάζεται.
Αν θέλετε υψηλή ποιότητα καλωδίου, Χάι Ενδ και τέτοια, πάρτε καλώδιο που να γράφει στην ουγια μογκαμι ή μπελντεν. Είναι περίπου στα διπλάσια λευτα από τα καλώδια στου Κάφκα.
Άμα θέλετε να σας πιάσουν τον κωλο γιατί έχετε ωραίο κωλο και σας αρέσει να σας τον πιάνουν, πάρτε καλώδια ηχείων που να έχουν ολοσέλιδες διαφημίσεις στο τας και στο στερεοφιλ.
Θα δώσετε για λίγα μέτρα καλώδιο όσο κοστίζουν όλα τα καλώδια του Κάφκα, όσα έχει μέσα στο μαγαζί, όλων των τύπων, από ηλεκτρικά και τηλεφωνικά μέχρι δεξερωγωτι, κι έχει πολλά χιλιόμετρα καλωδίων.
Έχετε τη δυνατότητα να σας πιάσουν τόσο πολύ τον κωλο, που να φτάσουν μέχρι αμυγδαλές.
Φχαριστηθείτε το.
Φιλ φρι.
christos77
Master of Diffusion
εγκρινω και επαυξανω χερ ντοκτορ αυτα εχω εγω μονοκλωνα ομως ,,πανακριβα,, :drinks:
Άμα θέλετε να σας πιάσουν τον κωλο γιατί έχετε ωραίο κωλο και σας αρέσει να σας τον πιάνουν, πάρτε καλώδια ηχείων που έχουν ολοσέλιδες διαφημίσεις στο τας και στο στερεοφιλ.
:wink::):):oops::gamer:
Vaslamp
