Preferred placementFlush against the wall...
The preferred placement of the speakers in a rectangular room is on the longer wall away from the room corners, minimizing side wall reflections. If your room is wide enough (typically minimum 4 meters) an alternative is to place the speakers on the short wall if you can place your listening position close enough and then have the advantage/trade off of having more corner loading and side reflections vs. having your listening position further away from the back wall and the acoustical problems that will arise from that. A desired minimum distance to the side wall is 50 cm. The speakers are designed handle typically max 100 w undistorted music material. To match your Larsen speakers with amplification, cables etc. for a certain room size we recommend that you take the advice from your local Larsen dealer. P
Μπορει να ειναι τα καλύτερα ηχεία στον κόσμο, δεν έχω αποψη αλλα προσωπικά σταμάτησα να διαβάζω μετά το παρακάτω:Πολύ σωστά ! αλλά η υπάρχουν εξαιρέσεις όπως η Larsen .....το εξηγούν στις οδηγίες τους ξεκάθαρα!
Preferred placement
Larsen loudspeakers should, different from most all other speakers, be placed flush against the wall of your listening room. This because the wall in combination with integrated damping panels is an integrated part of the design of the speaker. The design makes the speaker throughout its complete frequency range radiate the sound energy distributed as a half sphere. Other speakers placed with a distance to the back wall will exhibit what is called a “baffle step” at a certain frequency determined by the width of the speakers baffle. At this “baffle step” the radiation from the loudspeaker changes from half sphere to omnidirectional with the consequence of a 3-6 dB drop in sound pressure level for frequencies below “the step”. This step, however, partially compensated for in the crossover, is nothing that exists in real life acoustics. Here within is one of the secrets to the life like authentic sound of the Larsen speakers. In an equilateral triangle Larsen 4 and Larsen 6 are fairy similar in respect of acoustical design and the recommendations regarding speaker placement is valid for both of them. A fairly symmetrical placement of the speakers in respect to room boundaries is important. This because an unsymmetrical placement with for example one speaker much closer to a side wall could result in corner loading and additional reflections from that wall and this can give an unbalanced sound stage. A good start is an equilateral triangle with the speakers in two points and the listening spot in the third. The drivers of a Larsen speaker is tilted inwards and upwards to create the wider area of listening possibilities with the correct distributed acoustical energy throughout the frequency range. For this reason the ceiling should be acoustically reflective and not have sound absorbing panels. The preferred placement of the speakers in a rectangular room is on the longer wall away from the room corners, minimizing side wall reflections. If your room is wide enough (typically minimum 4 meters) an alternative is to place the speakers on the short wall if you can place your listening position close enough and then have the advantage/trade off of having more corner loading and side reflections vs. having your listening position further away from the back wall and the acoustical problems that will arise from that. A desired minimum distance to the side wall is 50 cm. The speakers are designed handle typically max 100 w undistorted music material. To match your Larsen speakers with amplification, cables etc. for a certain room size we recommend that you take the advice from your local Larsen dealer. P
Σα να λέμε...ακουστική του ορθού...Μπορει να ειναι τα καλύτερα ηχεία στον κόσμο, δεν έχω αποψη αλλα προσωπικά σταμάτησα να διαβάζω μετά το παρακάτω:
Να φωνάξουμε κανα γιατρό δλδ να μας το εξηγήσει !
@Bhutia
Το έπιπλο σε σχήμα γάμμα είναι εκεί προσωρινά λόγω μικρού παιδιού.Απ όλα τα αλλά που έγραψες δεν κατάλαβα λέξη…χεχε
3 μήνες διορία σου δίνει η Sonos. Τα δοκιμάζεις σπίτι σου και αν αλλάξεις γνώμη, τα επιστρέφεις και σου δίνει τα λεφτά σου πίσω στο ακέραιο.
Δεν υπάρχει αντίστοιχη διευκόλυνση στην αγορά.
3 μήνες! Τι να λέμε τώρα;
To Sonos Sub θα το ερωτευτεί η σύζυγος για το design του, όπως και θα χαρεί που θα εξαφανιστεί το καλωδιομάνι και τα κάθε λογής κουτάκια, dac κτλ.
Τα Five επίσης συμμαζεμένα και δεν είναι επιρρεπή σε ατυχήματα με τα μικρά παιδιά.
Το multiroom θα το λατρέψεις αν το δοκιμάσεις. Δεν υπάρχει λόγος να ακούς μουσική από το pc στο δωμάτιο του γραφείου. Την ίδια playlist σου θα παίζεις σε όποιον χώρο και αν βρίσκεσαι, ακόμα και ταυτόχρονα αν θέλεις.
Και δεν χρειάζεται να γεμίσεις ηχεία σε όλους τους χώρους. Μετακινείς ένα Sonos Move, στο ντους, στην αυλή/μπαλκόνι, παντού.
Με τα ενεργά και ειδικά σε σύστημα με subs, απλά ξέχνα το dac. Minidsp και καθάρισες. Ψάξε στο youtube να δεις videos που σετάρουν συστήματα με subs χρησιμοποιώντας το minidsp και θα κααταλάβεις κι εσύ πόσο αναγκαίο είναι για τη σωστή ενσωμάτωση των subs στο σύστημα. Για να σου κεντρίσω το ενδιαφέρον, τεράστιες κοιλιές στη καμπύλη απόκρισης τακτοποιούνται με προσθήκη χρονικής καθυστέρησης ( συνήθως στα πιο γρήγορα μεγάφωνα που είναι αυτά των δορυφόρων ) ούτως ώστε να υπάρχει χρονική ευθυγράμμιση μεταξύ όλων των ηχείων ( δορυφόρων και subs ). Και αφήνεις τους άλλους να κάνουν βόλτες το ή τα subs τους μέσα στο χώρο.ενεργά συν dac
Εδώ σε έχω!!
Πρέπει όμως να επισημανθεί ότι ακόμα και παρουσία miniDSP χρειάζεται ψάξιμο για τις θέσεις ηχείων-sub με τη βέλτιστη απόκριση - και κυρίως χωρίς ενεργειακές χαράδρες στις χαμηλές οκτάβες.Όσο λιγότερο επιβαρύνεται η δράση του DSP τόσο ανώτερη διαφάνεια θα έχει η τελική απόδοση και όσο λιγότερο παρεμβατικά τα φίλτρα τόσο μικρότερη η έκπτωση στο δυναμικό εύρος.Με τα ενεργά και ειδικά σε σύστημα με subs, απλά ξέχνα το dac. Minidsp και καθάρισες. Ψάξε στο youtube να δεις videos που σετάρουν συστήματα με subs χρησιμοποιώντας το minidsp και θα κααταλάβεις κι εσύ πόσο αναγκαίο είναι για τη σωστή ενσωμάτωση των subs στο σύστημα. Για να σου κεντρίσω το ενδιαφέρον, τεράστιες κοιλιές στη καμπύλη απόκρισης τακτοποιούνται με προσθήκη χρονικής καθυστέρησης ( συνήθως στα πιο γρήγορα μεγάφωνα που είναι αυτά των δορυφόρων ) ούτως ώστε να υπάρχει χρονική ευθυγράμμιση μεταξύ όλων των ηχείων ( δορυφόρων και subs ). Και αφήνεις τους άλλους να κάνουν βόλτες το ή τα subs τους μέσα στο χώρο.
Το dac του minidsp είναι επαρκέστατο, το minidsp έχει ενσωματωμένη λειτουργία ρύθμισης της έντασης όλου του συστήματος. Αν παίξεις και με κανένα μηχανάκι με dirac live ( π.χ. ddrc24 που στο πακέτο παίρνεις 4 αναλογικές εξόδους - μέσω RCA όμως - dirac live και το μικρόφωνο μέτρησης umik1 ), άντε γεια. Και κοστίζει κάπου στα 400 ευρώ, όσο ένα "αξιόλογο" dac Κινεζικής προέλευσης.
Τα δε subs είναι απαραίτητα γιατί με απλά λόγια, συνήθως εκεί που ο χώρος επιτρέπει την ορθή αναπαραγωγή των χαμηλών, δεν μπορούν να τοποθετηθούν οι δορυφόροι. Μια χαρά μπορεί να λέει ένας κατασκευαστής ότι το τάδε ηχείο κατεβαίνει σε τρελά χαμηλές συχνότητες. Στη πραγματικότητα όμως και στους συνήθεις χώρους ακρόασης, αυτό είναι ανέφικτο, εκτώς αν μπουν subs στο σύστημα.
(γι'αυτό και εξερράγην λίγο παραπάνω, δεν είναι δυνατόν έμπορος να λέει τέτοιες μπούρδες )
FUBAR εις τον...κύβον.Ο άνθρωπος σετάρει sub array χωρίς DSP και μετρητικά δεδομένα,υποστηρίζοντας κιόλας ότι χάρη στον τρόπο σύνδεσης με την έξοδο ηχείων από τον ενισχυτή και λίγο παίξιμο με το ρυθμιστικό φάσης όλα τα μεγάφωνα θα κινούνταν συγχρονισμένα προς την ίδια κατεύθυνση...!; Θα πιστοποιείται δε με τις χαμηλές ν'ακούγονται δυνατότερα...Δηλαδή δεν θα υπήρχε καν περίπτωση εντονότερης διέγερσης ιδιορρυθμού που θα τα έκανε ν'ακούγονται έτσι...
"Let the power supplies charge up overnight if you want..."Εγώ θέλω το άλλο.
6 subs με το αυτί.
Yes doctor!! Προφανώς δεν το διατύπωσα σωστά, αλλά ας του ανοίξω την όρεξη και θα βρει τις λεπτομέρειες στη πορεία.Πρέπει όμως να επισημανθεί ότι ακόμα και παρουσία miniDSP χρειάζεται ψάξιμο για τις θέσεις ηχείων-sub με τη βέλτιστη απόκριση - και κυρίως χωρίς ενεργειακές χαράδρες στις χαμηλές οκτάβες.Όσο λιγότερο επιβαρύνεται η δράση του DSP τόσο ανώτερη διαφάνεια θα έχει η τελική απόδοση και όσο λιγότερο παρεμβατικά τα φίλτρα τόσο μικρότερη η έκπτωση στο δυναμικό εύρος.
Όνειρα...overnight ."Let the power supplies charge up overnight if you want..."
Τί ζούμε ρε μλκς!...
