Dune HD Homatics Box R 4K Plus
Είπαμε μόλις το στρώσω, εκτός και αν το θέλεις οπωσδήποτε τώρα οπότε σου το στέλνω άμεσα (όχι αύριο αλλά χθες).
Btw Τον player τον δοκίμασες?
Hello,
For Dune HD Homatics users, here are some news from Dune HD, thanks to them for keeping us informed.
Initial support for playback of DVD-Video images (ISO and VIDEO_TS) is already implemented and will be part of the next Dune APK, which is expected to be released very soon.
This initial support will allow only direct (Lite) playback of the movie, without DVD-Menu yet.
Google Play Store is still in the process, some negotiations with Google continue, time to finish is unpredictable, it could be from 1 day to many days.
We hope for the best.
We think we are very close to success here.
Besides, we have the following good news :
Our joint development with Amlogic and the vendor of the ATV platform for Dune HD Homatics Box R 4K Plus model was very successful, and we are now very confident that we will be able to successfully implement these new features:
1) Our AFR/AR implementation will support not only fractional (23.976, 29.97, 9.94), but also and non-fractional (24.0, 30.0, 60.0) framerates.
2) Our AFR/AR implementation will support not only file playback, for also any Android apps.
ETA for software update (new Dune APK) with these new features is June.
This support will be available in Dune HD Homatics Box R 4K Plus model and in Dune HD Premier 4K Pro model (these two models are based on the same ATV platform).
See you soon
OlivierQC
Νέα έκδοση του Dune HD media center.
Here is the changelog :
13-230601_1453 (beta)
  • Added: Initial support for media tags (such as 4K, 3D, etc) for video files. Currently, media tags are detected by filenames only. Media tags are currently shown only in the movie information in the "Netflix-like" view. Media tags are supported for both My Collection and file browwer. The following types of media tags are supported: resolution such as SD/720/1080/4K, file type such as Blu-ray/DVD/ISO/MKV, framerates such as 23.976, dynamic range such as DV/HDR10, video codecs such as HEVC/H.264, aspect ratio such as 2.35:1, audio codec such as DTS-HD MA, number of audio channels such as 7.1. Most commonly used ways to represent such media tags in the filename are supported, for example: Terminator.1984.UltraHD.HDR10+.HEVC.DTS-HD-MA.7.1.Blu-ray.iso
  • Added: Initial support for playback of DVD-Video images (ISO and VIDEO_TS). Playback from SMB and NFS shares is supported. Auto framerate and auto resolution, chapters, audio tracks, subtitles, external subtitles, online subitltes are supported. Remembering and resuming playback position is supported. Only direct movie playback ("Lite" mode) is currently supported, DVD menu navigation is not supported.
  • Added: When sending a debug dump from the "Support" menu, if Internet is not accessible, the dump is saved in the internal flash memory and can be sent later (when Internet becomes accessible).
  • Fixed: In the top menu, some characters in some languages were wrongly shown as lower-case instead of upper-case.
  • Fixed: File copy from Windows PC to SMB server could fail with errors.
  • Fixed: Protect code (parental code) support for plugins was broken.
  • Fixed: Connecting drives with specific symbols in volume label could lead to some problems.
  • Improved: Improved GUI performance in some cases.
  • Improved: Improvements to better support some plugins.
  • Improved: Improvements to better support the new Dune HD Premier 4K Pro model.
  • Updated/improved UI translations for some languages.
  • Some other internal changes.
Full Blu-ray menu
Με κάθε επιφύλαξη αφού δεν προέρχεται από επίσημη πηγή.
Under development by Dune HD.
Will be available with an update to the Dune HD media center.
ETA: June/July 2023.
DVD video playback
ETA: May/June 2023.
AFR for file playback
Currently available and functional
(implemented by Dune HD as part of the Dune HD Media Center).
AFR for Android apps
Under joint development by Dune HD and Netflix certified platform provider..
(only on Dune HD boxes, will work with Dune HD Media Center support).
Possibly June 2023.
Support for more HDMI frequencies
Under joint development by Dune HD and certified platform provider Netflix.
(not just 23.976, which is already supported, but also the less common 24.0)
Will be available with a Dune HD media center update and a firmware update.
Possibly in June 2023.
DTS X / DTS HD passthrough
The Netflix certified platform provider has promised that it will be available
in June 2023... We will see.
Android 12
The Netflix certified platform provider promised it would be available
in August/September 2023... We shall see.
Ο Ιούλιος τελειώνει και τίποτε από τα παραπάνω δεν έγινε. dune mamiesai.
Ενα σύννεφο να πέσω..
Μπάμπη, αν τα κάνει όλα αυτά τότε ποιος θα αγοράσει τα media player που παράγουν?
Η συσκευή κυκλοφόρησε για να υπάρχει εκεί εξω και τίποτα άλλο.
Γι αυτό και επελέγη ήδη υπάρχουσα υλοποίηση και οι ίδιοι πρόσθεσαν απλά ενα app..
Στείλτο στον @K. ROMPOTIS για να του κάνει crash test 😈 :tongue:
Σταύρωσε το προηγουμένως και ράντισε το με μπόλικο Αγιασμό. :roflmao:
Μπάμπη καλημέρα, μιας κι ο αδερφικός μου φίλος απ την Κέρκυρα ψάχνει για real vision αλλά δε βρίσκουμε, τι έγινε μ αυτή τη συσκευή εδώ; Εννοώ σε σχέση με το real vision που υπολείπεται και σε τι βαθμό;
Κώστα εικόνα καλύτερη από το nvidia pro. (Εχω καταράκτη 8-) )
Εξακολουθεί όμως να έχει πρόβλημα με τα DTS HD MA και DTS X ( τα περνάει σαν dts 5.1.)
AFR και auto resolution δουλευουν.
DV,HDR 10, HDR 10 PLUS νεράκι.
Dolby surround, Dolby surround + Dolby truehd 7.1 /Atmos το ίδιο.
Το My Collection το έχει προεγκατεστημένο. (η έτσι νομίζω επειδή δεν θυμάμαι να το εχω εγκαταστήσει)
Σου παραθέτω screenshots για συγκριση με το real vision που εχεις.
Όσον αφορά τον ήχο ναι.
Όσον άφορα την εικόνα ( AFR και auto resolution ) όχι.
Καλημερα,
Χτες αγορασα το box απο Amazon. Τελικα το εφτιαξαν το AFR/AR για το Netflix και τις λοιπες android εφαρμογες?
Όχι, ακομα περιμένουμε.
Πως μπορεις να τεσταρεις αν δουλεβει το AFR/AR στα steaming apps (netflix, disney κτλ) στο box? Εχει info Panel το οποιο σου δειχνει frame rate, resolution? Υπαρχει καποια εφαρμογη? Απο την TV μου (Sony Bravia KD-65XE8596) για τις πηγες HDMI μπορω να δω resolution αλλα οχι frame rate.
Σε streaming services μόνο μέσω τηλεόρασης, σε local streaming έχεις την δυνατότητα να το δεις μέσω dune media player .
Έχω στημένο έναν Plex server με αρκετές 4k ταινίες σε TrueHD και DTS-MA. Φαντάζομαι ότι δεν χρειάζομαι Plex Client και το My Collection αρκεί.
Τι λιγότερο ή περισσότερο έχει σαν features από τον Plex Client;
Η homatics κυκλοφόρησε σε πολύ λίγους bera testers το νέο firmware V14.8.3717.
Όποιος ενδιαφέρεται μπορει να το κατεβάσει από τον παρακάτω σύνδεσμο.
Το αν θα το εγκαταστήσετε η όχι ειναι αποκλειστικά δίκη σας απόφαση.
Manosmathiou
