Minidsp+dac/streamer+Dirac σε μια συσκευή.
Από το πρόσφατο newsletter της miniDSP:
"Introducing the Flex HT: The Flex HT is miniDSP’s answer to our customers looking for a pocket-sized multichannel processor with HDMI ARC/eARC capabilities. Our team was able to cram a full eight channels of DSP power and a wide range of I/O into the unbelievably compact enclosure. Eight-channel audio input is via linear PCM over USB Audio or HDMI eARC. Additional stereo input is supported over SPDIF and TOSLINK optical.
Internally, we’ve provided a full suite of miniDSP's flexible routing and audio processing features: advanced bass management, parametric EQ, crossovers, advanced biquad programming and delay/gain adjustments. In addition, the miniDSP Flex HT is software-upgradable with full-frequency multichannel Dirac Live®, the world’s premiere room correction system. The eight-channel analog RCA outputs feature class-leading low noise and distortion figures. With HDMI eARC/ARC, control of your whole AV system from the TV remote has never been easier thanks to CEC integration. Please note that the Flex HT does not support bitstream (e.g. Dolby/DTS) decoding – the connected HDMI device must be able to output linear PCM (LPCM) for multichannel support over HDMI.
Last but not least, the Flex HT is miniDSP's first product to include WiSA (“Wireless Speaker and Audio Association”) capability. WiSA is designed specifically for low-latency multichannel audio – a perfect match for the Flex HT! The WiSA transmitter we build into each Flex HT can losslessly transmit all eight output channels to WiSA-compatible speakers and subwoofers. After a simple pairing procedure, you're good to go!"
Επίσης, δίνεται η δυνατότητα σε κατόχους συσκευών Flex, Flex Eight ή DDRC-24 που δεν έχουν Dirac Live, να αναβαθμίσουν τις συσκευές τους, εγκαθιστώντας το Dirac, αφού αγοράσουν τη σχετική άδεια, μέσα από μια απλή διαδικασία.
Εάν ήταν balanced...
To miniDSP Flex balanced το έχω εδώ και 1 εβδ περίπου. Έχουν βελτιώσει το "περιβάλλον" σε σχέση με το απλό miniDSP (το είχα επίσης 1 εβδ) αλλά νομίζω είναι ακόμη στην αρχή το software/firmware και θα υπάρχουν συνεχώς αναβαθμίσεις. Προς το παρόν δεν αντιμετώπισα κάποιο σημαντικό πρόβλημα.
Το νέο Flex έχει αρκετά πλεονεκτήματα σε σχέση με το απλό, αλλά κάνει και τα 3πλά σχεδόν χρήματα. Ένα από αυτά που το είχα εκτιμήσει δεόντως στον Devialet, είναι η ασύρματη μεταφορά ήχου υψηλής πιστότητας. Στο Flex bέβαια πρέπει να πάρω και ένα Bluetooth συμβατό για να το χρησιμοποιήσω (WiFi/Ethernet ο Devialet, Bluetooth το Flex). Αυτό θα βοηθήσει πολύ στις μετρήσεις και γιατί όχι κάποιες φορές στην ακρόαση προγράμματος.
Ο Devialet προφανώς είναι άλλο επίπεδο σε κάποια πράγματα.
Σταύρος Λαγκαδιανός
Το αγοράκι με τα σπίρτα
Διαβάζω όμως ότι υπάρχει θέμα με την υποστήριξη αφενός και αφετέρου με τον συγχρονισμό αν θες να περάσεις σήμα από την τιβί.
Σε τι αναφέρεσαι;
Edit: Εάν αναφέρεσαι στο miniDSP, δεν υπάρχει κάποιο θέμα με την υποστήριξη. Η εταιρεία έχει μια τάχιστα ανταποκρινόμενη ομάδα υποστήριξης, ενώ το μηχάνημα δέχεται τακτικά ουσιαστικές αναβαθμίσεις (με την πιο πρόσφατη κάπου μέσα στον Δεκέμβριο του 2023, εάν θυμάμαι καλά).
Το πρόβλημα με το σήμα από την TV δεν το αντιλαμβάνομαι.
MiniDSP SHD ή MiniDSP Studio, αναλόγως των πηγών (αριθμός /είδος) που έχεις.
Από που μπορεί κανείς να αποκτήσει αυτό το θαυματουργό,όλα σε ένα, μηχανηματάκι; Από ότι καταλαβαίνω, μπορεί να χρησιμοποιηθεί και σαν pro με δύο αναλογικές εισόδους.
Προσωπικά το πήρα από την ελληνική αντιπροσωπεία. Το βρίσκεις και στο εξωτερικό (εντός Ε.Ε.). Είναι πολυμηχάνημα (προενισχυτής, DAC, streamer, crossover, με δυνατότητα DSP μέσω Dirac) με πληθώρα αναλογικών και ψηφιακών εισόδων κι εξόδων.
Υπάρχει σχετικό thread για αυτό και με την ευκαιρία , παρακαλώ κάποιον moderator, να μεταφέρει τα τελευταία posts (από το #31 και μετά) εκεί.
roberto_portale
