EverSolo Audio - Ελλάς
Ultra Audio
Και επίσημα, έως 3/6 θα αναβαθμίζονται όλα τα A6 & A8 με νέες δυνατότητες, KKBOX, ROON για Α8, κλπ κλπ κλπ…
NEW FIRMWARE V1.2.95 FOR DMP-A6 / DMP-A8 RELEASED
Changelogs:
1. Added separate adjustment for left and right channels in EQ
2. Added lyrics theme to playback details interface
3. Optimized album sorting function
4. Added year and composer modules to the music library (To use this function, you need to rescan the music library)
5. Added genre-based album categorization (To use this function, you need to rescan the music library)
6. Fixed the issue of artist album tracks not being filtered
7. Optimized the display of the playback queue interface
8. Added embedded lyrics feature to tracks
9. Optimized the function of adding tracks to the playback queue
10. Improved French language display
11. Added seamless CD playback feature
12. Fixed occasional issue where CDs could not be ripped
13. Optimized incorrect CD playback status
14. Fixed incorrect order in playlist queue
15. Optimized occasional issue where music services do not display on the main interface
16. Added one-click account reset feature for music services
17. Optimized cloud drive playback functionality
18. Fixed occasional issue where UPNP device content does not display
19. Optimized the global information prompt interface
20. Fixed occasional issue where deleting a device also deletes the playlist
21. Added EQ feature notification
22. Fixed the issue with incorrect display of the number of artists
23. Improved radio playback compatibility
24. Optimized the music library reset function
25. Fixed occasional crashes on the CD interface
26. Added artist sorting feature
27. Fixed display of external storage volume labels in file management
28. Fixed issue with certain USB DACs not outputting DSD
29. Added album year display in artist interface
30. Fixed issue with certain DSD audio files not playing
31. Fixed occasional stuttering issue with certain audio in optical outputs
32. Resolved occasional issues with Apple Music showing a “cannot use” prompt
33. Fixed external storage formatting functionality
34. Optimized Cast feature
35. Optimized filter characteristics feature
36. Fixed occasional issue with EQ configuration renaming not succeeding
37. Added global search functionality (This feature is currently offered on the device screen. It will be available in the mobile app within the next few weeks.)
38. Added KKBOX to music services
39. Fixed occasional Squeeze synchronization issue
40. Optimized the navigation bar display
41. Added the function of clearing data from the main interface
42. Added Roon Ready functionality (DMP-A8)
43. Fixed occasional display issues with FIR curves (DMP-A8)
44. Optimized system stability
Official firmware update will be pushed online from June 3rd in stages to avoid server congestions.
Model:DMP-A6
Model:DMP-A8
Control APP
Android : v1.12.57
iOS : v1.1.12
DMP-A6 / A8
1. Optimized music library sorting function
2. Added year and composer modules to the music library
3. Optimized display of devices list in the music library
4. Optimized music service module
5. Fixed some known issues
bretsos
Μπάμιας
Changelogs:
Model:DMP-A6
Model:DMP-A8
Control APP
Android : v1.12.57
iOS : v1.1.12
DMP-A6 / A8
Ενώ έγραψες ότι η διάθεση θα ξεκινήσει από 3/6 έχω κάνει σήμερα 3 αναζητήσεις μήπως και υπάρχει κάποια αναβάθμιση, έτσι χωρίς λόγο :roflmao:
vlasis
Φωτογράφος!
το περασα σε στικακι και το Α8 μου το ρουφηξε το update με την μια κυρΜπρετσε μου!!!!
Παντως δυο Γιωργηδες τα τσιμπησανε τα COS τους.!!!!!.....εεεεεεε Γιωργη???:dance2::dance2::D:D:laugh::laugh::laugh:
Ultra Audio
Οι αναβαθμίσεις γίνονται σταδιακά ανά χώρα κλπ….
Όποιος δεν μπορεί να περιμένει μπορεί να τις κατεβάσει και να τις κάνει από στικάκι σε αυτό το site:
Με δική του ευθύνη όμως,!
Θα συστήναμε όμως να περιμένει, να κάνει την αναβάθμιση όταν του το «προτείνει» η συσκευή του.
bretsos
Μπάμιας
Υπομονή έχουμε!!
Επειδή διαβάζω και τα ξένα φόρα, τι καημός και αυτός με το κάθε νέο update?
Γιατί κάνουν έτσι?
Μθα χαρά λειτουργεί το εργαλείο, δλδ τι το παραπάν να κάνει, καφέ να σιάξει? :biggrin:
Ultra Audio
Υπομονή έχουμε!!
Γιατί κάνουν έτσι?
Ορθώς εμίλησες, αν και καθήμενος.......
Πιο πολύ σημασία έχει το Roon ready για το Α8....για τους Roonάδες... :hi:
bretsos
Μπάμιας
Μα με έχει κάνει μεγάλη εντύπωση όλο αυτό, ανακοινώνουν ότι θα κυκλοφορήσει αναβάθμιση και όλοι είναι στα νύχια. Γιατί να τραβήξω τέτοιο ζόρι, το μηχανάκι λειτουργεί μια χαρά αφού!!
bretsos
Μπάμιας
Κοίτα, από προσωπική εμπειρία στα κινητά τηλέφωνα μετά από κάθε firmware update κάτι σιάχνουν και κάτι χαλάει.
Το ίδιο και εδώ συμβαίνει, όλοι στα ξένα φόρα γκρινιάζουν, δεν δλέυει το ένα, χάλασε το άλλο, το τάδε φορμάτ έχει θέμα κλπ.
Εγώ τρέμω κάθε φορά, αφήνω σε όλες τις περιπτώσεις να τα φορτώσει το ευρύ κοινό και άμα είναι όλα καλά, σε βάθος χρόνου τα φορτώνω και στη θκιάμ συσκευή, αλλιώς περιμένω το επικαιρεποιημένο firmware
Decembered
Μαϊμού
... που λες (συντροφε) Μπρετσ-νιεφ ... ο κοσμος σημερα προφασιζεται ενα σορο πραματα για να εχει κατι να λεει, ή ακομα (και εν προκειμενω) για να ανεβαζει στο διαδικτιο, αυτο ως γενικο φαινομενο *ασφαλως μπορει και να σφαλω. (...)
Παμε ολοι μαζι εν χορω "misery loves κοπανοι" και αναποδως "κοπανοι λοβ μιζερυ". :king: :angel:
Decembered
Μαϊμού
:king: χωρις κιθαρα και χωρις φωνη ειναι καλητερο παντως :angel:
-παλι καλα που το (**ever)σολο το παιζει (τουλαχιστο) το σεκσοφουνο-
θενκζ.
(**για να ειμαστε λιγο ταχαμου εντος θεματως)
  • rose.athens
Κ.Κωνσταντίνος
